what are the signs of a bad map sensor? - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 10-08-2010, 06:36 PM Thread Starter
DavidRasch17's Avatar
alrighty guys
well the vp44 has about 25kish miles on it.
always had fass system on it. 15-17psi and 70% Of its life was with 2 stroke
the problem(s)
it kinda hestiates from a stop. sluggish then power comes on nice. im not building alot of boost either. 5 poundish. so i dont think its turbo lag.
in 4th gear ussualy around 2000-2100 rpms under WOT it feels like it falls on its face.....no power, like no fuel basically.... fuel psi is good. also. if i let out of the throttle then get right back in it. the problem does not exisit
also it lopes with the a/c on when putting the clutch in and letting it fall to idle
it will dip about 200rpms under idle then even rite back out.
my thoughts...
bad apps
bad map....
or possibly another vp44?
i have cleaned my map twice before so i dont think its clogged
truck did have a smoke switch on it for quite some time.
i just reset my apps. going to see if that solves my problem.
i also have no CEL on. and no scan tool to see if there is a code...
as far as my knowledge the symtpons show one of the 3 components are bad...
only other one i can think of would be ecm.
any help would be greatly appericated.
thanks
(bluefurd)1998.5 blue 2500 club cab, nv4500,quad 4k, nanofiber amsoil, afe torque tube, FASS150GPH, 5inch str8 to 7in mirte with fte mount, pusher intake, tunnel ram, cpps 7x.014, bd short throw kit, valair 650hp dd, 17x9 kmc revolvers wrapped in 33x11.5 terra grapplers, 66/74/14 batmowheel, hamiltion rods/springs, arp studs, tru-trac in rear, lukes link, DAP steering brace, hawk brakes, blisteen 5100's, amsoil bypass system, devilsown stage2, ccp traction bars, fluidamper with pin kit, hellman fuel sump, equal lenght SS jet hot coated header
DavidRasch17 is offline
post #2 of 17 (permalink) Old 10-08-2010, 06:47 PM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
Run to a autozone or some parts store and have them scan it to get a better idea of what's going on. Otherwise it's just shots in the dark.
patracy is offline
post #3 of 17 (permalink) Old 10-08-2010, 06:50 PM
agreed current codes will set you in the right direction
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #4 of 17 (permalink) Old 10-08-2010, 07:31 PM Thread Starter
guys at autozone said they scanner wont read unless theres a CEL .... lol
post #5 of 17 (permalink) Old 10-08-2010, 07:42 PM
DieselAutoPower.com
patracy's Avatar
Tell the stooge behind the counter to let him talk to the manager. There's a reason he's shuffling parts and not diagnosing & repairing vehicles.
patracy is offline
post #6 of 17 (permalink) Old 10-08-2010, 08:27 PM
oudive's Avatar
If they say the same thing again, tell them the instrument cluster has electrical issues and is not working properly. That should do it. On a side note, I was having low boost issues and no codes, turns out I had a boost leak and once I got it fixed, I was back in the normal numbers that I would see. Hope that helps.
oudive
2013 Lone Star- 3500 CC / DRW / AISIN / 4.10 / Renegade Front Bumper / Hellwig Bags w/wireless AirLift
oudive is offline
post #7 of 17 (permalink) Old 10-08-2010, 11:07 PM Thread Starter
the apps reset seemed to helped. but im not sure if its the whole issue. after i resetted it. it didint cut out in 4th at wot. could be luck or apps actually did something.
post #8 of 17 (permalink) Old 10-09-2010, 06:54 AM
DieselAutoPower.com
patracy's Avatar
You really need to scan for codes, otherwise you're just throwing stuff out in the dark.
patracy is offline
post #9 of 17 (permalink) Old 10-09-2010, 07:03 AM
dieselpower7.3's Avatar
most people dont understand the reason a cel light shows up on the dash..... the real reason that it lights up... is if any fault in the engine that the computer catches, compromises the emissions in the exhaust.. gas or diesel.... annndd when its flashing that means shut it down, for any of you who have seen that before
white 2010 cc 2500 4x4 g56 looking to get a lift soon
dieselpower7.3 is offline
The Following User Says Thank You to dieselpower7.3 For This Useful Post:
patracy (10-09-2010)
post #10 of 17 (permalink) Old 10-09-2010, 10:34 AM
not likely to ever see a flashing "check eng light" on a 98-2002 dodge CTD as it means the ECM has detected a miss fire and continued driving will damage the cat.
most folks panic when they see a check eng lite come on, dont panic, just means the PCM/ECM has seen a reading from a sensor that is outside the normal range, most times (not always) the veh will drive the same and there are no noticable driveability issues.
My two cents
nickg is offline
post #11 of 17 (permalink) Old 10-09-2010, 11:16 AM
slow01dodge's Avatar
yea its not really a good idea to keep driving a gas motor with the light blinking i have seen em roll into the shop and the cat cherry red from em missing that aint a good idea
FASS,Electric Fan,AFE Stage 1,ISS Pro EV2 In Custom Made Pods,Levelin Kit,Apline Headunit,1 12" Diamond D6,Alpine MRD501 Amp,Custom Made Grill & Bumper Inserts,PSC Brace,lil bit of fuel and a lil bit of air and sb DXD to hold it maybe
slow01dodge is offline
post #12 of 17 (permalink) Old 10-10-2010, 12:58 PM
bcbifoot's Avatar
DavidRasch17: Is the performance of the truck OK at higher rpms or is it just doggy on bottom end? Are you getting boost psi readings from your Edge? if so it is getting it's info from the Map sensor and may not be accurate if Map is bad.
2002 3500 4x2, QC, Adrenaline non wire tapped, Goerend Trans with 3 disc TC, billet input, RV275 injectors, lockup switch, 4:10 rear gears, Autometer gauges full set including fuel pres., fp100 AirDog, #56 block, 130,000 miles, IAT fooler.
bcbifoot is offline
