How do tell if my truck has a chip? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 09-22-2010, 11:49 PM Thread Starter
Hi all i recently became the owner of 02 6speed manual 4wd. this is the first diesel i have owned, the truck has a few upgrades on like winch and bumper, lift kit, pillar pod w/pryometer, boost, and fuel press gauges. How do i tell if it has a chip? to me it seem funny that the previous owner would put all that aftermarket on and not also chip it. I looked through all the stuff i got w/the truck but found nothing in the way of info if its chipped or not. dealer i got from was no help
'02 2500 6speed man 4X4 crew cab shortbed, 3-piller with gauges, 75k miles
Bryno is offline
post #2 of 13 (permalink) Old 09-23-2010, 12:00 AM
Clunk's Avatar
If your boost pressure doesn't get any higher than 20 psi, it's not chipped.
Stock boost pressure is 19-20 psi.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #3 of 13 (permalink) Old 09-23-2010, 12:07 AM
Rescue Tower
Shainer's Avatar
You can look to see if the injection pump wire was tapped. With everything that is on it is very likely it was chipped at one point. Not uncommon to remove those items prior to sale as it really does not help the resale value.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #4 of 13 (permalink) Old 09-23-2010, 12:07 AM
Check the usual places for power adders. Alot of them will use the map sensor (on drivers side of block near firewall) or the good ones will tap the injection pump. Easiest way to tell though has been mentioned in previous post.
2002 QCSB 6 Speed/ Quad Adrenaline 4k With PV2
/ Raptor 150/ Big Line Kit/ BHAF/ 4 Inch MBRP/ 285 75 Nitto Terra Grapplers
curtis026 is offline
post #5 of 13 (permalink) Old 09-23-2010, 12:11 AM
Won't be able to tell if its got a programmer on it though without asking the dealer
x MadMAX DIESEL is offline
post #6 of 13 (permalink) Old 09-23-2010, 01:35 AM
BVD
Does it smoke? My chip-less truck won't even smoke if I try. Don't worry though I'm in the same boat as you, I've had the truck a week and still don't know what all has been done to it, and if what Clunk says is true I need to do some more digging because my truck pulls 30 psi
2002 QcSb, 6 speed, SB ofe clutch, 4" straight pipe, FASS HpFp, Edge Comp Hot, Autometer Boost, EGT, Fuel Pres
BVD is offline
post #7 of 13 (permalink) Old 09-23-2010, 02:08 AM
Clunk's Avatar
If your not getting the overboost code, theres a chip/boost fooler in there somewhere,
P0234 Turbo Boost Limit Exceeded.
Problem detected in turbocharger wastegate.
Clunk is offline
post #8 of 13 (permalink) Old 09-23-2010, 03:43 AM
BlackedOut02's Avatar
1. check you battery terminals and fuse pannels for accessery wires.
2. check your map sensor, data plug, and pump wire.
i pluged my gate, and can pull 25+psi with a "stock" truck. all "19-20psi" will tell you is that you gate is working. (plus this assuming you have gauges already)
Under Construction
BlackedOut02 is offline
post #9 of 13 (permalink) Old 09-23-2010, 04:40 AM
If the wastegate was not tampered with boost will stay at stock levels even with a fueling box or programmer. Most programmers have boost foolers that prevent high boost codes but the 24 valves have a mechanical wastegate that must be modified to gain highter then stock boost. The boost fooler just prevents the ecm from throwing a code when the wastegate is modified.
mpw8679 is offline
post #10 of 13 (permalink) Old 09-23-2010, 11:58 AM
Western WA President
jigabop's Avatar
I saw 26psi before getting the boost elbow on my factory turbo with just the adrenaline.
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is online now
post #11 of 13 (permalink) Old 09-23-2010, 05:53 PM
99cummins5spd's Avatar
My truck was always at 30psi with the hy35 & auto trans @ 2200rpm....it was unchipped & un j-hooked....with my HX35 & 5spd trans I only get 25psi with the smarty on 9 & its re-porgramed to the wild setting...but it runs waaaay stronger now..
2002 24V CUMMINS QCSB NV4500,4x4,SB 3600 DD,CPP traction bars,SMARTY,HRVP44,CPP7X.012s,HX35,ARP studs,Airdog 165,FP,EGT,BOOST..p7100 pumped soon..Black 1995 12valve 4X4 RCLB 47RH auto work truck, KDP tabbed..stock for now, 1995 12 valve going into a blue monster
99cummins5spd is offline
post #12 of 13 (permalink) Old 09-23-2010, 06:06 PM
People sure are getting alot of different boost readings. Does anyone know if there was different boost pressure ratings depending on so, ho, auto or manual?
mpw8679 is offline
