Injectors EDM VS Extrude Honed? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 04-01-2006, 07:40 AM Thread Starter
skitzo's Avatar
I was wondering what the difference between the two are? I have supposedly 125hp nozzles and was looking to go with maybe 150's now I have the comp box and Fass II installed. Any suggestions?
Thanks,
2006, 2500, Bright Slvr, QC, SB, Auto, 4x4, Bully Dog PMT, MBRP 4" exhaust, AFE stage 2, Boost fooler, Bushwacker fndr flares, KMC 22x11 Monsters(Blk), 325/60R22 BFG allterrains, Top Customz 8" lift, Superlift Dual steering Stablizer, Bilstein shocks
skitzo is offline
post #2 of 18 (permalink) Old 04-01-2006, 10:00 AM
woodsrat's Avatar
EDM = lasered
Extrude Honded = drilled
Edm process provides a smoother more accurate tip than the extruded honed.
You will see less smoke in normal driving, but there if you want it, More usuable power, and with the 150's in my truck im showing a mpg increase.
woodsrat is offline
post #3 of 18 (permalink) Old 04-01-2006, 12:48 PM
oldsmokey94's Avatar
There ya go Chuck!!!
School him in on your injector philosophy!! lol!
Still waiting on my buddy so i can get the d*** 435's!!
twins, rpm, fuel and some small extras.
COMPETITIONDIESEL.COM
oldsmokey94 is offline
The Following User Says Thank You to oldsmokey94 For This Useful Post:
98cummins1500 (12-10-2010)
post #4 of 18 (permalink) Old 04-01-2006, 08:05 PM
Sea01Cummer's Avatar
On the extrude honed i was under the impression they run a aggregate fluid through them and it hones them out.
Steve
[SIGPIC][/SIGPIC]2001.5 Dodge 2500 CTD, 6 Speed, Leather,Headache Rack, Edge HOT Juice with Attitude,BD 130 HP Pulse Injectors, 4 inch Exhaust, FE Clutch,Vulcan Big Line Kit, IIS Super Phat Shaft 62/14, Swanker Intake Manifold,ATS Exhaust Manifold,ARP 12 MM Head Studs, HB High Idle Kit, 12v Marine .020 Headgasket. .
Dynoed 505/1085 on 8/26/06 :woot2 with water-meth
Guns don't kill people.... Husbands that come home early kill people....
Sea01Cummer is offline
post #5 of 18 (permalink) Old 04-01-2006, 08:25 PM
Steve
My understanding also.
Liquid with microscopic abrasive is pumped though at high pressure that will enlarge the nozzle with precision control while also buffing them very smooth. More fuel can flow with less turbulence creating better fuel atomization
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #6 of 18 (permalink) Old 04-02-2006, 05:06 PM
Roy 31's Avatar
Skitzo, It looks like we have the same setup and I went with 150hp EDM injectors and I Love Them. The power is awesome and fuel mileage is even better. I got mine through Woodsrat.
2001 Qd Cab 4X4 Auto: Edge Drag, 95 HVFP, II SB, BD-RAD, Mach 6s, Helix 2, F1 Springs, Fire-ringed, Fluidampr, ARP, Nitrous Express, Mag Hy-tech, Goerends billet, 6" lift, 35" Toyo MT,
Roy 31 is offline
post #7 of 18 (permalink) Old 04-05-2006, 12:41 PM
EDM means Electrical Discharge Machining. An eletrical arc is used to remove microns of material at a time. This produces a perfectly smooth surface. I don't see why anyone would follow EDM with abrasive fluid because nothing provides a smoother finish than EDM.
02 QC SB 5spd, Drag Comp, 4" straight, BHAF, EGT/BOOST/FP gauges, 285 revo's. Walbro 392.
yarddog is offline
The Following User Says Thank You to yarddog For This Useful Post:
Clunk (09-11-2012)
post #8 of 18 (permalink) Old 04-05-2006, 07:40 PM Thread Starter
skitzo's Avatar
10-4/ I'm not a mechanic especially when it comes to Diesel so I appreciate your help(schooling as mentioned above). I like to be able to know in advance when making purchases especially when it comes to my truck that could leave me stranded in the middle of no where.
Thanks
skitzo is offline
post #9 of 18 (permalink) Old 04-05-2006, 08:15 PM
Former Staff Member
MR4WLR's Avatar
I'll disagree with you somewhat, the EDM process can create "rough" features....It all depends on how good a hole the operator wishes to make.
All EDM'd injectors are not created equal because of variances in speed of which the machine is ran and then there is also the consideration of the EDM machine tolerance ability as well.
Corey Ritter - Amity, OR
2016 Blue Streak SRW QCLB Laramie. Buckstop/Warn 12,000 lb, WeatherTech vent shades, DeeZee tailgate assist, DeeZee tool/fuel combo with GPI pump
SOLD '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd 151K
MR4WLR is offline
post #10 of 18 (permalink) Old 04-05-2006, 10:30 PM
FozSweet53's Avatar
I have never heard of anyone doing both. It's either extrude honed or EDM, but as far as which is better I've been told both ways. I have extrude honed and I like em fine.
99 2500 White with Gray stripe Sport-Centurion pkg, BD-trans-t/c lock up,4" inline exhuast brake, SuperPhat Shaft 62/14, Edge Juice with Attintude, IIS 2 flow injectors,Vulcan high flow with LP relocation kit, AFE stage 2, Snoperf. Water/Meth stage 2, Ali Arc front bumper, and a big ol nasty 53 on the block. 7-21-06 506.10 HP, and 998.54 ft lbs TRQ at 42 psi.
FozSweet53 is offline
post #11 of 18 (permalink) Old 04-05-2006, 11:39 PM
extruded honed have a lot of smoke. I want the EDM'd 435 for better milage along with more power
post #12 of 18 (permalink) Old 04-06-2006, 09:02 AM
SpicyJam's Avatar
The EDM process does leave an edge, I have used the machine before, so I know..........the abrasive fluid used to hone out an injector has been applied to some injectors after the EDM process offering a very smooth finished product.
2001 Quad Cab 2500 L/B
With some bolt on parts.
568hp 1064fpt at Hitech Motors March 28th, 2006 with many new changes since
SpicyJam is offline
