Old 07-02-2007, 09:52 PM   #1 (permalink)
RamRollinCoal's Avatar
Arrow SRE Custom Fuel System
Well everyone, I finally had the weather last sunday to put our custom fuel system on the truck. Went pretty smooth.
SRE Custom Fuel System:
Vulcan Draw Straw
3/8 Marine Diesel Fuel Line
Racor 460R Fuel Filter Water Separator(60gph 10micron, 90gph 15micron filter cartridge available(490R)
Holley Black Fuel Pump, 120gph @ 9psi (rated)
Vulcan Full Flow Fitting.
Price: roughly $210
Here are some (sorry, a bit dark) pics of it installed:
The Filter:
The Pump:
Both:
What you can see from the outside:
All in all, it took about 5 hrs, including lunch
RESULTS:
At first, pressure was 15psi, dropped to 4 under WOT, but as the air got worked out of the filter, as my brother drove to work this morning, he made a drastic discovery, the guage was pegged over past 15, dropping 1/2 a psi under WOT!
Im going to turn the pump pressure down, it has the flow, no reason to have all that pressure, its just going to wear out the springs in the pump that hold the valve shut in there when its under 15 psi, my worries: they wont close, and it will drain the fuel from the pump when it needs it, but maybe thats just me.
- Neil
2000 3500 4x4,Blue,5spd,53BLOCK!,Drag Comp,RV's,Valair 13" OFE,Amsoil 4510,4" SRE Turbo Back w/ 6" Tip, 90 GPH SRE Custom Fuel System,Pillar Mount:EGT, Boost & Fuel Pressure, S/S Bed Rails, Cummins Flaps,Nerf Bars,2" Cowl Hood - 267,000+Mi.
RamRollinCoal is offline   Reply With Quote
Old 07-03-2007, 08:31 PM   #2 (permalink)
Here are some clearer pics:
This thing is allready starting to collect sediment in the bottom of the filter bowl, im rather impressed!
Old 07-17-2007, 05:57 PM   #3 (permalink)
DIESEL HEAD
Nice work.
2005 RAM 3500, QUAD-CAB, 6-SPEED, 2WD, 50K MILES, MUFFLER IS MIA
1-TON is offline   Reply With Quote
Old 07-25-2007, 01:50 PM   #4 (permalink)
what was the max psi he reached?
02 dodge,5 spd,custon stacks,6x.13 injs,trick stage 2 vp, stage 2 afe cold air,silencer ring MIA,isspro boost/egt/fuel psi guages,bd stealth cover,FASS 150/150.plannin on twins and water/meth mabe nos special thanks to Gus at Farmboys Diesel
diesel junkie is offline   Reply With Quote
Old 07-25-2007, 02:00 PM   #5 (permalink)
Well like I said, the guage was pegged over, but that pump just died on us, so we picked up a replacement from summit for 80 bucks and its forking great. The last one seized a main bearing and scored the shaft, like it got some sort of debris in the oil groove of the bearing and it just locked up one day, wouldnt even start. If I needed to, I could limp the truck home with minimal IP damage, with the primer button you see on top of the fuel filter, I can pump the system up to 10 psi, and I suppose you could stop every so often and re pump it up.
But anyways, the new pump and spring setup has the guage at an estimated 18 psi at idle and around 14-13 WOT. The thing just flows a ton of fuel.
Old 07-25-2007, 06:40 PM   #6 (permalink)
good deal man . i just finished shopin for my new fuel system and i was gonna go with the holly black then found this 140 gph. im fixin to get one of the monster pumps and wanted to keep the line psi 15 min and 20 max
Old 07-25-2007, 06:45 PM   #7 (permalink)
Pushing the limits
WICKED DIESELS's Avatar
The high pressure cooks the bearings, especially in the knock off pumps(cheaper components).
02 2500 Sport SB 3850, DRAG COMP, 2 TURBOS, BIG STIX, BIG PUMP, STUDS, SPRINGS, CAM, WATER INJ, ARB AIR LOCKERS, O RINGS, LIFT 35'S
05 2500 Sport 2 TURBOS, CAM, SPRINGS, STUDS, BIG STICKS, DRAGONSLAYER CP3, C5 MP8 AND PROGRAMMER, BILLET TRANNY, LIFT 37'S
WICKED DIESELS is offline   Reply With Quote
Old 07-25-2007, 07:20 PM   #8 (permalink)
Thats what I figured, in fact im gonna go and drop the pressure a bit so the guage doesnt peg over when you first fire the truck up, I figure 15 at idle, 10 at WOT oughtta be good, and thats at the pump, without banjo fittings, so lotsa flow there.
Old 07-25-2007, 07:22 PM   #9 (permalink)
Pushing the limits
No less than 8 psi at wot will be ok
Old 07-25-2007, 07:38 PM   #10 (permalink)
Farmboy's Diesel
farmboysdiesel's Avatar
It certainly pays to invest in a nice fuel system!!
Farmboy's Diesel Performance
FBD BUDGET EXHAUST
Products By: FBD, AirDog, Blue Chip, DDP, Smarty, TS, MaxSpool, HaloMax Springs, Grand Rock, Fluidampr, AFE, Edge, TST, MBRP, Industrial Injection, ARP, Auto Meter and More
704-290-2289
1999 Dodge 2500 4x4 II 66/FBD2 TWINS, 7in Stack, HTS/FBD Tranny, DDP Inj's, FBD Trik 3VP, HaloMax Springs, MaxSpool, NX SD2, Fluidampr, DragTST
Check out www.farmboysdiesel.com
farmboysdiesel is offline   Reply With Quote
Old 07-25-2007, 07:49 PM   #11 (permalink)
Pushing the limits
I concurr
Old 07-25-2007, 08:07 PM   #12 (permalink)
Damn salesmen.... but its true, thats why I researched what to get, I just didnt know about that pump. Its also pretty versatile, I can put any pump I want back there, whether it be a walbro or aeromotive a1000.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
