please post dyno results - Page 2 - Dodge Cummins Diesel Forum
 5Likes
post #13 of 1210 (permalink) Old 01-07-2010, 07:56 PM
Justin Price's Avatar
517/979
Edge juice/attitude
250+ injectors
hx40/ht3b twins (not tuned at the time)
2011 4wd LML Duramax
SOLD: 01 2WD DRW NV4500 600/1136
Justin Price is offline
post #14 of 1210 (permalink) Old 01-07-2010, 08:02 PM
my_samurai's Avatar
417/854
100hp sticks
edge juice with hot, and no the hot unlock added NO MORE power just raises defuel.
stock turbo drilled out
water/meth
damn good converter to make the power stick.
98.5 2500 QC LB,BHAF, Edge Juice Hot/Smarty,meth,DFI 7x.011, AD150, FMW62/68/14,ARP, Revmax Signature Series ,Metalcloak Arms, Thuren coils, 5100's
91 W250 FLATBED 6" lift , tuned pump, HX35 Revmax Converter
my_samurai is offline
post #15 of 1210 (permalink) Old 01-07-2010, 10:52 PM
491 hp 964 tq uncorrected 550hp/1078tq corrected on dunbar's
mach 5's
62/71/14
tst pm3/smarty stack
99 Reg cab 2500 5spd, ad100, 5"ex, smarty revo,TST , guages, Valair 13" ofe, Mach 5, 62/71/14, 491.43 hp 964.04 uncorrected western nc dyno day.
jp8819 is offline
post #16 of 1210 (permalink) Old 01-08-2010, 02:24 PM
MrNiceGuy's Avatar
as you can see my second run was 444.5hp and 943tq at the time my mods were...
S&B intake
4" exhaust
Fass 150
Quad Adrenaline ADR3000 tune
BD hi-performance VP44
DDP 110 hp injectors
Stock hx35 w/boost elbow (hit 43psi on run 2)
valair clutch
since then i have stacked a smarty, and added a 3 piece manifold, HTT 62/14, and 5" exhaust... im excited to see what it will do now
'02 6spd|Gauge Pillar|S&B Intake|5" TBE|fass|HR-VP44|110 stix|ARP studs|HTT 62/14|BD Manifold
Valair Clutch|Adrenaline-Smarty stack|BDS lift|20" BMF Novakane's|35" Rubber
MrNiceGuy is offline
post #17 of 1210 (permalink) Old 01-08-2010, 06:59 PM
353.7hp 938.2ftlb tq
Quad Adrenaline 3000G tune
SBC DD clutch
raptor 150
4" DP 5" exhaust
BHAF
I need more air
00 3500 dually, 5 speed, 4 door, Gauges, with Quad Adrenaline, Raptor 150 with 1/2inc fuel lines, 4inch DP 5inch exhaust, BHAF, SBC DD clutch, good for 353.7hp and 938.2ftlbs torque. and more to come. Update:HE351cw and CCP 150hp injectors
Number47 is offline
post #18 of 1210 (permalink) Old 01-08-2010, 09:37 PM
smkin6spd's Avatar
661hp 1400ish ft/lbs
monster VP
hurricane 2's
.093 billet cross tubes
edge drag comp
64/65/14 over s400
o-ringed head
FASS 150/150
south bend DD 3850 12cb rigid hub
snow performance water methanol
ported HTT manifold
AFE intake arc
2002 silver 2500 - 6spd w/ SBC 3850 12CB DD, ARB locker, AFE Bladerunner, FASS 150gph, Hurricane 2's, .093 tubes, htb2 64/14 & S400, 4in exhaust, Snow Performance stage 3, Edge Drag Comp, o-ring head, arp studs, MONSTER VP44! 727hp/1440tq-DKDiesel 4/9/10
smkin6spd is offline
post #19 of 1210 (permalink) Old 01-08-2010, 10:54 PM
24vman's Avatar
413/890ish
hrvp
mass diesel 150hp sticks
edge on max
smarty/revo on max
stock turbo!!!
98.5 5spd, 80k miles ,hpfp 150, hotrod vp44, 240 sticks, edge comp/smarty,66/74/14, sb3850, autometer cobalt fp, boost, pyro, stage two afe intake , 6" stacks. SOLD!!!
24vman is offline
post #20 of 1210 (permalink) Old 01-08-2010, 11:04 PM
463/1039
fbd 150s
raptor 150
lightning turbo 57/64/14
drag comp/smarty
valair single ceramic 3800#
aem intake
mustang dyno loaded for 8000lbs truck to load dyno better
1995 2500 4x4 handshaker
tuned afc and #10 plate
210k miles
cumminssmokeman is offline
post #21 of 1210 (permalink) Old 01-08-2010, 11:24 PM
cummins724's Avatar
iTrader Score: 23 reviews
Mach 5's, Adrenaline, Super B special, SOvp44, all stock internals except valvesprings, damper & head studs & orings.
cummins724 is offline
post #22 of 1210 (permalink) Old 01-09-2010, 12:01 AM
Oregon Chapter President
Electric_Cowboy's Avatar
I got a measly 279hp and 711tq.
315/75/R16's
50hp Injectors
Smarty
HX35
And secret ingredient was Cetane Boost from Napa.
THE S.O.L.I.D CREW and temporarily truckless.
Sold: 1990 Reg Cab, AT, 4x4, 197k, Chassis Unlimited Crossover kit, D400CS springs front, DIY4X shackle flip rear, Nitro shocks, home ground pin, and a ton of body work.
Electric_Cowboy is offline
post #23 of 1210 (permalink) Old 01-09-2010, 02:49 AM
Bleed All American!
Stevencritt's Avatar
413/828
150 stix
adr dyno tune
stock hx35
00 24 valve. Hot rod vp, 7X.012 air dog 150, adrenaline with I-QUAD, k&n intake, glow shift gauges with fuel pressure, . 4'' into single 6" stack. Super B Special! Studs, duel spring valve springs and O-ringed head from FBD. SOLD...
1995 camaro: lsx 408, custom carb, big ole cam and a lot of nitrous!!! 😈
09 Dirtymax, EFI live, 4'' turbo back, BDS 7'' lift on 35s
00 QCLB Comp Hot unlock, FASS 150, Fass sump, 5'' exhaust, NV4500 SB DD, SD twins 62/71/14 over s475, SD mani. arp studs, South bend DD, CPP 7x14s, auto meter gauges, 110# springs, II vp44. Push rods, 188/220,
Stevencritt is offline
post #24 of 1210 (permalink) Old 01-09-2010, 10:16 AM
Crayola spokesperson
farmboy458's Avatar
01 impala rides like hell but dosent have payments
farmboy458 is offline
The Following User Says Thank You to farmboy458 For This Useful Post:
LargeCar (04-05-2011)
