map sensor problems! - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 01-06-2010, 12:07 AM Thread Starter
8secride's Avatar
iTrader Score: -3 reviews
well when i put it to the floor it acts like its hesitating and missing. i ran the codes on it and two of them were map sensor codes. i cannot find one on ebay does anyone know where to buy one? or anything else i should check for? thanks
99' qcsb, 240hp injectors, edge comp, smarty, twins, ats trans, fass, highram,
2002 ram 2500, 6speed, 300+hp injectors, valair clutch,fass, dragonfire vp44,quad adren.ARP, head studs, 110 valve springs, afe intake,
8secride is offline
post #2 of 26 (permalink) Old 01-06-2010, 07:26 AM
johnyb59's Avatar
What were all your codes?
08' SRW QCLB
johnyb59 is offline
post #3 of 26 (permalink) Old 01-06-2010, 09:53 AM
NC4WD's Avatar
Got mine from Advance Auto for $90, been working great.
Y2K | NV4500 | NP241DHD | BHAF w/ prefilter | BD Wastegate | Edge Juice With CS Monitor | AirDog II | Dana 80 | Valair Clutch 500/1000 | NC4WD Flat Bed | GM Wheel Cylinders | 3rd Gen Wheels | 3rd Gen Front Brakes | Super HD Track Bar | Skyjacker Rear Springs | NC4WD Pre-Runner Bumper | Bilstein 5100's Front / 7100's Rear | 6" Grand Rock Stack | 35" KM2's | Amsoil Bypass Filter | North Country Rock Sliders | Cummins Coolant Filter | Lots of Ballistic Fabrication Parts | T-Style HD Tie Rod| Heavy 2 Stroke Diet | Updated 5th Gear Nut | Puke Bottle Delete | DSS Steering Stabilizer | Heavy Duty Lower Control Arms
NC4WD is offline
post #4 of 26 (permalink) Old 01-06-2010, 09:54 AM
DodgeMech's Avatar
the question is what were the other codes???
sounds like you either have a bad VP or APPS sensor
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #5 of 26 (permalink) Old 01-06-2010, 10:31 PM Thread Starter
8secride's Avatar
my local advance cant get one. i cant remember the codes but my diesel mechanic ran it and said they were map sensor codes.
8secride is offline
post #6 of 26 (permalink) Old 01-06-2010, 11:00 PM
Before you buy one try cleaning it first . Pull it off and give it a shot of brake cleaner, its probably all sooted up.
2001 cummins automatic 2500 x-tended cab , airdog 150, edge juice/w/attitude , mbrp 4'' need more
to keep going
wontgoslo is offline
post #7 of 26 (permalink) Old 01-06-2010, 11:29 PM
gassernomore's Avatar
MAP Sensor
99 2500 4x4 / Edge EZ / Isspro Fuel Gauge / Turbo Timer / Raptor 150 / Scan Gauge II
06 2500 4X4 / Edge Attitude / Straight Piped
gassernomore is offline
post #8 of 26 (permalink) Old 01-07-2010, 01:44 AM
dodge24's Avatar
Get it straight from Cummins if you can, or a heavy truck dealer. It will be waaaaay cheaper than going thru a parts store, believe me. Just get the part number first so you can make sure what you get is correct.
01 Dodge Ram 2500 4x4 Auto 35" Toyo MT on XD Hoss Wheels
High Tech Turbo - Dynomite Diesel Performance - Thuren Fab - AirDog - Smarty - SOLD
dodge24 is offline
post #9 of 26 (permalink) Old 01-07-2010, 11:48 AM
JustOutThere's Avatar
go to MAP Sensor it well help ... had the same problem and it was just dirty .
01 quad cab, 6 spd, 4x4, ho v44, bhfa with diamond plate heat shield, edge juice / attitude , airdog 150w/straw, ev2 3 gauge pod , 2.5 revtec lift, 315 big foots , 4" straight pipe , built trans
JustOutThere is offline
post #10 of 26 (permalink) Old 01-07-2010, 01:38 PM
Dodge_4by4's Avatar
I agree with dodge24. I had to get one and went straight to Cummins and they hooked me up and im not so sure it wasn't like around $60 or so. They told me anything that was "ON" the engine they can get for me cheaper than any dealer
1999 Ram Regular Cab Cummins! Straight Exhaust, Edge Juce With Attitude, BD Max Lift Pump and Custom Built Trans With ATS Conveter and Large Tires And Rims! New Custom VP!
06 Charger Daytona R/T
Dodge_4by4 is offline
post #11 of 26 (permalink) Old 01-08-2010, 08:39 PM
Rs2nV's Avatar
another for cummins dodge wanted 230 bucks and i'd have to drive 22 miles to the nearest dealership, cummins is 5 miles from the house and 1/2 mile from work, think it was 89 bucks, be sure to either have the PN and you engine serial before you go, i cleaned mine a few times and it would help for a bit, havent had the light since i put the new one in
06 Ram 2500- Sold
06 Hayabusa- 1441 stroker with a lil 2.5lb bottle
05 Roush stage II mustang
Rs2nV is offline
post #12 of 26 (permalink) Old 01-10-2010, 12:33 PM Thread Starter
8secride's Avatar
so im guessing the intake pressure sensor is basically the samething as the map sensor? found one on ebay if so. thanks for all the help
8secride is offline
