Build Thread, By NotSoNicely. - Dodge Cummins Diesel Forum
 47Likes
post #1 of 176 (permalink) Old 04-06-2017, 04:44 PM Thread Starter
NotSoNicely's Avatar
ALREADY OWNED:
2 10" SUBS & BOX?
600 WATT AMP ?
Snap on diesel puller- ($20)?
TOOLS:
FTLBS TQR WRENCH
INCH LBS WRENCH
FUELER GAGUES - $200 TOTAL
Snap on diesel puller- paid for ($20)?
( currently waiting to Fix head gasket and head studs.) ~April 26th / 17
Build Thread in progress.
STAGE 1
Fixing truck soon : 4/6/17 current date -
ARP HEADSTUDS $425- free shipping
Gasket $55 free shipping
Possible machine work
Clean up engine
Make Boost tester
Fix boost leak ( hopefully boost tubes)
Realignment
New front passenger side tire
New stock injectors- Paid
5" - $362. Paid
After I get my truck to working shape, I'll be starting here.
Steering pump-
New acuater set to 27psi. -
Reseal back end-
Ball joints -
Shocks-
Change transmission fluid at 305k miles
Gauges - $300-400?
Bhaf - $50
Quadzilla - $600
300% + alternator upgrade $300
6"9" Rockford Fosgate $200
5.25" Rockford Fosgate $100
Amplifier - $200
2 12" subs $300
Amplifier $200
New head unit $100
DASH POP OUT PIECES $100-? (Anyone know where to get dash pieces?)
STAGE 2:
Fass lift pump - $250
Regulated diesel pump ( Fass) 150 GPH - $650 - $200/300 for instal.
Fass fuel heater kit- $150
ARP HEADSTUDS - $450 [ will have in about 2 weeks ]
If your making power your adding heat, use the best and only Mishimoto RADIATOR and intercooler kit. They have a lifetime warranty, there made from aluminum.
(Personly experience with there products, never had a problem)
Mishimoto RADIATOR - $750
Mishimoto INTERCOOLER KIT - $1250
STAGE 3
Injectors - $400 150hp sticks
Turbo $1,500+ (62/65/14) [ 150-175 hp injectors recommend ]
New clutch- stage 3- $1,500-2,000 {dual disk, 650hp}
Upgraded 5 speed - $2,500 {when needed}
CUSTOM THINGS TO DO:
Things to consider but not do till I've got everything else done.
Lift 6"+ $1,750- $3,500
Custom 20" rims: $200- $1,000 per rim
Lower gearing
35" rubber $1,200-1,600
possibly custom stack(s) Free?
Plasti dip kit sexy blue -$250
NotSoNicely is offline
post #2 of 176 (permalink) Old 04-06-2017, 05:32 PM Thread Starter
Pictures of my ugly dodge
And a picture of me sitting in my uncles cummins, while I was in texas. They went into the gas station, I hoped up on there tail Gail and enjoyed the 55* weather
ID:	634777   Click image for larger version
ID:	634785   Click image for larger version
post #3 of 176 (permalink) Old 04-06-2017, 09:07 PM Thread Starter
My father took my truck down to have it a tire put on it, the whole front end is fudged.. so I'll be getting ball joints and everything else done to the front end. Looks like things are moving smoothly
post #4 of 176 (permalink) Old 04-06-2017, 09:40 PM
Stormin08's Avatar
You need to restructure your path...
Get it running, make certain fuel pressure is adequate.
You need gauges & lift pump as a priority stage 1.
Once everything is running as designed, move to performance upgrades.
b+barandgrill likes this.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #5 of 176 (permalink) Old 04-07-2017, 04:21 AM
gh0stman's Avatar
I wouldn't worry about a "upgraded" 5 speed. I would put in a G56 before I did that.
Also I would leave the stock radiator and intercooler in place as they can handle the power you are planning on adding to it.
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops, DAP HD Pushrods
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is offline
post #6 of 176 (permalink) Old 04-07-2017, 09:00 AM
jlbayes's Avatar
You gonna be mad when the inter cooler and radiator DO NOT change anything.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
post #7 of 176 (permalink) Old 04-07-2017, 12:15 PM Thread Starter
@storming08, thank you for pointing that mistake out for me, that was supposed to be in stage 1, and have the quadzilla in stage 2. Simple error ?
post #8 of 176 (permalink) Old 04-07-2017, 12:51 PM Thread Starter
I'll get a front end price by the end of the day, I'm sure it'll be $1,000+
My other question, with the 62/65/14 it will give me the DD I want, however with 150 sticks, will I be able to smoke out a entire street, or should I upgrade to a bigger exaught housing?
post #9 of 176 (permalink) Old 04-07-2017, 01:03 PM
gh0stman's Avatar
I would leave the exhaust housing alone. It will smoke till the turbo lights. You should be able to do the front end for about a 1/3 of the price if you do it yourself. Should be able to do the whole front end yourself. It will take about a day to get it done if you replace it all.
gh0stman is offline
post #10 of 176 (permalink) Old 04-07-2017, 02:24 PM
grantw1221's Avatar
You look like a 12 year old kid, take some advice here.
2005 QCSB 4x4- Goerend tranny, 12v Rods, ARP head studs, Hamilton 188/220 cam, Hamilton pushrods, Hamilton 103# valve springs, 125HP DAP injector nozzles, Arson 3 kit, 62/65/14/S475 twins, FASS 150, and tuning by Coffman Customs
grantw1221 is offline
The Following 2 Users Say Thank You to grantw1221 For This Useful Post:
b+barandgrill (04-07-2017), jlbayes (04-07-2017)
post #11 of 176 (permalink) Old 04-07-2017, 03:13 PM Thread Starter
Thanks for your humor, I'm already aware of the fact i look young, I was also slightly drunk in that picture ? I cleaned out there entire fridge, it just sits on there back porch. It was nice and cool there that time of year. They Said someone probably should. So I went ham, from 12-4. There all light nasty beer. But I was rolling pretty good.
post #12 of 176 (permalink) Old 04-07-2017, 03:15 PM Thread Starter
I'm well aware of everything that needs to be done with this truck. Before I dump money into it. I ain't scared to be oil field trash and power threw it. Then upgrade my damn dodge. I'll get it done, and this forum will build in time I promise.
