powerband characteristics of non-wiretap programmers - Page 2 - Dodge Cummins Diesel Forum
 11Likes
post #13 of 26 (permalink) Old 02-09-2017, 09:43 AM
KATOOM's Avatar
Oh its not just the VP I would be concerned with, but everything else as well. Clutch, transmission, tires,.....my safety.
KATOOM is offline
post #14 of 26 (permalink) Old 02-09-2017, 12:20 PM Thread Starter
smokinfire's Avatar
Originally Posted by Mopar1973Man View Post
Tapped now for over 10 years on the same pump. The whole wiretap is nothing but a scare tactic to make vendors money as they void warranties. I've ran both the Edge Comp for 10 years now going into my first year of Quad. Still tapped and nothing happened to the VP44.
Back to the OP. The problem I see with all other programmers on the market is the lack of adjustment for fuel vs boost and timing. Quadzilla is the only one now with way better control than Smarty or SuperChips could ever think of. Still in all Smarty being the most expensive tuner on the market dollar per HP but give so little control of fuel and timing. All programmers are limited to 60-65 HP period that's it...
Yup, that's the problem, no adjustability. I had a common rail tuned with the Smarty s06. I know it's not as good as what's on the market today, but it's leaps and bounds better than anything I've seen for the vp trucks. The s06 could change so many characteristics of the powerband, not just max output.
2002 2500 4WD EC LB. NV 5600. FASS DDRP relocated and big line kit. Lp gauge. 348K and counting. Hypertech programmer. 100 HP DAP injectors. Edge insight + EGT. Leveled on 285s
smokinfire is offline
post #15 of 26 (permalink) Old 02-09-2017, 12:29 PM
me78569's Avatar
Dunno about leaps and bounds better...
00 Dodge 2500 quad 5.9 Cummins, DFI 7x.009, he351ve arduino controller, homebuilt 47re revmax 3.5 messed with vb, Quad adr V2, 4",150 gph, studs/sprgs/psh rds
me78569 is offline
post #16 of 26 (permalink) Old 02-09-2017, 02:00 PM Thread Starter
smokinfire's Avatar
Dude, Me, you are way smarter than I am. Lol. That video explained so much.
So basically, the end result of what I'm looking for in a tuner is available, but only via v2 tuning.
Really my original question was answered in the last couple of minutes of the video.
Last question: can you have the v2 tuning and not wiretap? Basically just take advantage of the 65 horse of canbus tuning and adjust it how you want (think low smoke pre-boost).
QuadzillaPower likes this.
post #17 of 26 (permalink) Old 02-09-2017, 02:13 PM
Yes you can. Wiretap only comes in on levels 4+ you can leave it not tapped and the canbus will still be effective
99 2wd ext cab lb SRW. Quadzilla adrenaline, DAP 7x.009 (100hp sticks) big air filter. Valair Single Disk organic clutch. FASS Platinum 150gph. Jacobs exhaust brake. 232k miles
b+barandgrill is offline
The Following 2 Users Say Thank You to b+barandgrill For This Useful Post:
QuadzillaPower (02-09-2017), smokinfire (02-09-2017)
post #18 of 26 (permalink) Old 02-09-2017, 02:24 PM
me78569's Avatar
@smokinfire
Here's Tfaoro's truck, 7 x .013's at ~7000' altitude
Stock
EARLY V2 tuning ( its even better now)
Another compare of stock vs V2 canbus on his truck
Here's my truck 7 x.009's again 7000' altitude
Stock
canbus tuning only
With canbus tuning + wiretap
there is more in the V2 testing thread
me78569 is offline
The Following 2 Users Say Thank You to me78569 For This Useful Post:
post #19 of 26 (permalink) Old 02-09-2017, 05:05 PM
Dumb question...but what does one need to buy for the V2? Just the normal Quadzilla box and a cheap Bluetooth device?
02 2500 QCLB||47RE|4x4|4.10|HY35|Edge EZ|BHAF|FASS 150|DS 1|Isspro FP|Bilstein 5100|BFG A/T 285/75/16
gipperkid is offline
post #20 of 26 (permalink) Old 02-09-2017, 05:07 PM
me78569's Avatar
Buy a Quadzilla ADR with the Iquad and whatever device you want. If you want IOS then get the wifi iquad, if you want andriod then use the bluetooth iquad.
I would be shocked if most dont have an old phone laying around that works PERFECTLY as a screen.
me78569 is offline
post #21 of 26 (permalink) Old 02-09-2017, 05:13 PM
QuadzillaPower.com
QuadzillaPower's Avatar
You just need the Adrenaline kit with iQuad or iQuadBT depending if you want to use Apple or Android devices respectively.
I would post the links, but a quick internet search of IQUADBT1002 and IQUAD1002 will result in a better price than our online store.
Last edited by QuadzillaPower; 02-09-2017 at 05:13 PM. Reason: Quick update to part number for OP's year of truck.
QuadzillaPower is offline
post #22 of 26 (permalink) Old 02-09-2017, 08:12 PM Thread Starter
smokinfire's Avatar
@ the videos: holy cow, that's exactly what i was asking for. No wire-tap, low-to-no-smoke, and good power. I'm saving my pennies now! And I'm up for a cell phone upgrade from Verizon, so I'll just keep my phone for the screen, sweet.
post #23 of 26 (permalink) Old 02-09-2017, 08:15 PM Thread Starter
smokinfire's Avatar
You know what's really driving this for me is the retarded need to smog diesels here in California. I'd like to drive something with good power that's smog-able. Also the reason I really don't want to upgrade the turbo from anything that doesn't look stock.
post #24 of 26 (permalink) Old 02-09-2017, 11:33 PM
Monstermaker's Avatar
All the more reason to run a Quad.
'99 QC 4x4 Dually, Quadzilla not wiretapped, DAP 150hp VCO7x.010s, HX35, 47RE triple disc billet everything, lockup switch, 4.10s, Gear Vendors OD, Kelderman Air Ride, Alcoas, 4" pipes, BD brake, Fass Titanium 95, Hellwig sway, steering brace, airbags
Monstermaker is offline
