2001 dodge 2500 turbo diesel - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 02-06-2017, 10:23 PM Thread Starter
started perfect yesterday. had a hard time starting this morning and now it will not start. it cranks perfectly.i have an airdog 2 lifter pump i think its fairly newer but im not sure. new filters for the air dog. no codes at all. any help would be greatly appreciated.
gabesullivan13 is offline
post #2 of 9 (permalink) Old 02-06-2017, 10:35 PM
Fern's Avatar
What's your fuel pressure at? Do you hear the lift pump if you bump the starter?
01 Sport 4x, Quad w/ PV2, Smarty, PhatShaft 62/65/14, 4" turbo back, FASS, Amsoil, 100hp DFI's, TunnelRam, H2 alloys, 5" lift, HD steering, Posi-Lok, Inglewood Trans w/ billet parts. "My work truck"
Fern is offline
post #3 of 9 (permalink) Old 02-06-2017, 10:49 PM Thread Starter
negative. i do not hear the pump at all. and my gauge has been saying zero for like a week but its been running so i thought that the gauge just went bad or something like that.
post #4 of 9 (permalink) Old 02-07-2017, 12:14 AM
Fern's Avatar
If you run your VP dry, you will add the cost of a new one to your list. Expensive.
Where is your lift pump located? Is it still in the stock location on the engine block, in-tank, or on the frame rail by the tank.
You can run a hose into a bucket from the lift pump to see if you are flowing fuel.
Fern is offline
post #5 of 9 (permalink) Old 02-07-2017, 12:29 AM Thread Starter
its mounted to the frame. the gauge just cut to zero like a week ago. so im thinking it might be a blown fuse??? im going to check in the morning.
post #6 of 9 (permalink) Old 02-07-2017, 12:59 AM
Cummins_freak777's Avatar
Could be a blown fuse burnt up pump motor or a bad relay in the Air Dog wiring harness. It doesn't take very long to trash a vp44 pump running it without fuel pressure.
02 6 speed QCSB, leveled, cowl hood, 6000K HIDs, drag comp, DAP 7x.010 SAC sticks, SB 3250 dd clutch, 5in exhaust, AFE intake, Fass 150, glowshift (EGT,boost,FP), chrome 20x14 xd riots, 33x12.5x20 toyo m/t, follow me on instagram for truck pics @pr0ject_blue
Cummins_freak777 is offline
post #7 of 9 (permalink) Old 02-07-2017, 06:51 PM Thread Starter
so i found the problem sort of.... my fuse was blown put a new one in it and now it just keeps popping them so theres a ground or loose connection somewhere
post #8 of 9 (permalink) Old 02-08-2017, 09:36 AM
Fern's Avatar
A fuse popping would either be a grounded out wire or and internal short in the fuel pump motor.
Fern is offline
post #9 of 9 (permalink) Old 02-09-2017, 03:20 PM
greybeast's Avatar
I had a very similar problem a couple months ago with my lift pump. There's an internal seal within the lift pump that had gone out between the motor and where the fuel flows that causes the pump to pull lots of power. Mine was blowing 40 amp fuses as fast as I could feed it. Is your pump under warranty?
02 2500 4x4 HO nv5600 Custom Flatbed and bumper, MBRP 4" turbo back, S&B intake, Raptor 150, Edge Juice w/att CTS2, Silencer ring MIA More to come...
greybeast is offline
