What is the Best Mileage MPG PROGRAMMER ? - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 22 (permalink) Old 02-11-2017, 04:07 AM
If you want 30+ mpg buy an EcoDiesel.
2002 3500 QCLB DRW 4WD Bone Stock Automatic
93ls1rx7 is offline
post #14 of 22 (permalink) Old 02-11-2017, 04:53 AM
gh0stman's Avatar
I would recommend a Jetta over a ecodiesel. Why get 30 when you can be getting 50-60+.
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is offline
post #15 of 22 (permalink) Old 02-11-2017, 11:49 AM
You guys are lucky I'm excited to see over 15mpg on the highway or in town and I never drive my truck hard either but I didn't buy a 7000# truck for fuel economy
MitchB is offline
post #16 of 22 (permalink) Old 02-11-2017, 02:06 PM
Monstermaker's Avatar
Seems like you could pretty easily do better.
My hand calculated (not from the overhead "lie-o-meter") average on my last tank was 15 mpg and that was pretty much all slugging to work and back in horrible rush hour traffic, in a 4x4 dually. That even included about 50 miles in 4-Hi in the snow.
'99 Quad Cab 4x4 Dually Quadzilla Adrenaline, HX35, RV275s, 47RE triple disc billet everything, lockup switch, 4.10s, Gear Vendors OD, Kelderman Air Ride, Alcoas, 4" pipes, BD exhaust brake, Fass Titanium 95, Hellwig sway, Air Lift overloads, Mexican block
Monstermaker is offline
post #17 of 22 (permalink) Old 02-11-2017, 04:51 PM
crf450ish's Avatar
No kidding
KATOOM and Russ Roth like this.
2002 LBQC 4X4. DYNAMIC STAGE 3 47RE. MAG DD PAN. GOEREND BILLET FLYWHEEL. 4:10's. 285's. FASS 150 W/DRAW STRAW & BIG LINES. 5" TBE W/ 52" MUFFLER. BHAF. HX35. TIMBO APPS. AIRBAGS.MOPARMANHIGHIDLE. QUAD V2.
crf450ish is offline
post #18 of 22 (permalink) Old 02-11-2017, 10:06 PM
How far off are the lie-o-meter? Because that's what I'm going off
MitchB is offline
post #19 of 22 (permalink) Old 02-11-2017, 10:47 PM
Way off. I don't even look at it.
Always calculate your own MPG, the overhead panel thing is very well known as entirely unreliable.
And if you've made any mods at all, it's completely moot.
post #20 of 22 (permalink) Old 02-12-2017, 04:15 AM
gh0stman's Avatar
My overhead says 30+ mpg. Actual is in my sig.
gh0stman is offline
post #21 of 22 (permalink) Old 02-12-2017, 01:18 PM
KATOOM's Avatar
They can be off by a little or a lot based on the tire size and power modifications. The overhead is basing its calculations on factory parameters and is incapable of detecting anything aftermarket on the truck. So therefore because 99% of people dont have factory size tires or run factory power, the overhead is typically not accurate enough to bother using.
Hand calculating is best but really using the tripometer is not 100% accurate either, even with stock size tires. The best way is to calculate using a GPS. If you need to be any more precise than that in maximizing fuel mileage.....you bought the wrong vehicle.
KATOOM is offline
post #22 of 22 (permalink) Old 02-12-2017, 06:13 PM
Originally Posted by honestbest333 View Post
What would be the best programmer to buy for the best MPG ? Anyone?
I personally like the Smart S03 tuner. Then again I'm biased and have only had this tuner so far. I went from about 19MPG to 22MPG on the highway. Has timing added so it also has a bit of get up and go on the fuel saver mode when you need to pass or have a bit of fun.
1999 Dodge Ram 2500 Extended Cab, 47RE Auto, 4X4 ..... All Stock
2001 Dodge Ram 2500 Extended Cab, NV5600, 4X4, Smart S03, 4" Turbo Back Exhaust
Pryde is offline
