QUADZILLA ADRENALINE for the 24v REVIEW - Page 3 - Dodge Cummins Diesel Forum
 17Likes
post #25 of 137 (permalink) Old 02-06-2017, 03:46 PM Thread Starter
1YC
1YC's Avatar
This is the tune that im currently running
power levels:11
timing limit:10
timing scaling:100%
maximum fuel stretch :1900 microseconds
tps pump max:70%
tps pump min:0%
tps can max: 70%
tps can min: 0%
boost scaling: 25psi
How do i physically plug into the computer. I dont remember seeing a cord that my computer would accept. Is it USB? Im on mopar1973man.com following the directions step by step right now and i will attempt to flash today i hope
2001 dodge ram 2500HO 4X4 24 valve 5.9 cummins nv5600 6 speed. S.O VP44, stock pipes, stock turbo, stock everything. Quadzilla Adrenaline with iQuad V2, 3" lift, 4th gen wheels, procomp es9000s
1YC is offline
post #26 of 137 (permalink) Old 02-06-2017, 03:51 PM
gh0stman's Avatar
It uses a mini USB cord. I think that is the proper term. Its not a common cord normally used.
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is offline
The Following User Says Thank You to gh0stman For This Useful Post:
1YC (02-07-2017)
post #27 of 137 (permalink) Old 02-06-2017, 03:54 PM Thread Starter
1YC
1YC's Avatar
ok so im a teacher at a high school and the computer im using wont let me download the netframe 3.5 until i get authorization which may take up to a week and this is basically my only source of internet other than my cell phone so i guess i will wait until then
1YC is offline
post #28 of 137 (permalink) Old 02-06-2017, 03:58 PM
me78569's Avatar
I can't say you should flash using your work computer, that seems like a bad idea in terms of permissions and legal rights.
I do know what is wrong with you tune though.
power levels:11
timing limit:4
timing scaling:100%
maximum fuel stretch: 1600 microseconds
tps pump max: 100%
tps pump min: 20%
tps can max: 100%
tps can min: 0%
boost scaling: 30psi
Run that and see how it acts you were running WAY WAY WAY WAY to much timing for your fueling and had all of your fueling between 0 and %70 tps and between 0 -25 psi.
I would also test for boost leaks if you haven't.
00 Dodge 2500 quad 5.9 Cummins, DFI 7x.009, he351ve arduino controller, homebuilt 47re revmax 3.5 messed with vb, Quad adr V2, 4",150 gph, studs/sprgs/psh rds
me78569 is offline
The Following User Says Thank You to me78569 For This Useful Post:
1YC (02-06-2017)
post #29 of 137 (permalink) Old 02-06-2017, 04:00 PM Thread Starter
1YC
1YC's Avatar
well im the automotive technology teacher so all i have to say is i need this software to use for vehicles and they will let me, i just have to wait until they have the time. The link at the beginning of this thread on v2 tuning only shows how to download the 3.5 stuff right? i dont see about the actual flashing, or am i looking over it? I will defiantly try that tune when i get off work, Thanks.
1YC is offline
post #30 of 137 (permalink) Old 02-06-2017, 04:03 PM Thread Starter
1YC
1YC's Avatar
Nevermind what i said about the link. I was looking over the flashing part, but i found it now
QuadzillaPower likes this.
1YC is offline
post #31 of 137 (permalink) Old 02-06-2017, 04:07 PM
me78569's Avatar
Yep, its all there, ensure you read the full post about it. the details are important. The details are the difference between it going smooth and it being a PITA.
What Version of windows is your computer on?
me78569 is offline
post #32 of 137 (permalink) Old 02-06-2017, 04:28 PM Thread Starter
1YC
1YC's Avatar
I have windows 10
1YC is offline
post #33 of 137 (permalink) Old 02-06-2017, 04:35 PM
QuadzillaPower.com
QuadzillaPower's Avatar
Originally Posted by gh0stman View Post
When I ordered mine Jkidd and I talked about it and he had the V2 tune flashed on it. And I got with ME and he showed me the phone beta app. Not to hard.
But flashing it over to the new tune and installing the beta app on the phone isn't that difficult. Worst case you can send it to quad and have them flash it.
We'll do that gladly. Especially if you are having issues with the stock tune. Just ask, we'll get it done.
QuadzillaPower is offline
The Following User Says Thank You to QuadzillaPower For This Useful Post:
1YC (02-07-2017)
post #34 of 137 (permalink) Old 02-06-2017, 04:46 PM
QuadzillaPower.com
Hey me78569, This may be a whole new can of worms, but is there a way to install the driver without the updated .net framework? I think the original way (much more complicated) didn't need the .net framework, but it will still require administrative privileges on the computer.
If you keep running into issues like this 1YC, just send it to me here at Quadzilla and we will update your box for you. Follow the directions in the directions of the link here: https://quadzillapower.com/adrenalin...dodge-cummins/
with the form filled out and specify the V2 tuning and we will update it for you.
Just for the record, the issues that you are having getting it loaded are exactly why we needed to pull the offer to have our users download the tunes from the web. It just became so involved that all we did was technical support all day and couldn't work on the products and new stuff for release. We are still working on it, but its just not available yet.
1YC (02-07-2017)
post #35 of 137 (permalink) Old 02-06-2017, 04:58 PM
me78569's Avatar
The Netframe work is needed for the actual flash process not the driver install.
I don't remember if windows 10 has framework 3.5 installed or not or if current netframe work is backwards compatiable.
me78569 is offline
post #36 of 137 (permalink) Old 02-06-2017, 05:00 PM Thread Starter
1YC
1YC's Avatar
Is there something i can do to check?
1YC is offline
