Cold air intake - Dodge Cummins Diesel Forum
 6Likes
post #1 of 53 (permalink) Old 01-21-2017, 03:44 PM Thread Starter
Cold air intake
Was looking to up grade my cold air intake on my 99 2500 24v quad cab...was thinking about going with the banks, looking for opinions from people who have upgraded already and what you went with and why...any imput will be greatly appreciated
drillerlife23 is offline
post #2 of 53 (permalink) Old 01-21-2017, 04:31 PM
Depending on the power level you are at, you likely won't see any gains at all from a Cai. A bhaf is more than plenty for the majority of us
99 2wd ext cab lb SRW. Quadzilla adrenaline, DAP 7x.009 (100hp sticks) big air filter. Valair Single Disk organic clutch. FASS Platinum 150gph. Jacobs exhaust brake. 232k miles
b+barandgrill is offline
post #3 of 53 (permalink) Old 01-21-2017, 04:48 PM
krs
krs's Avatar
I would recommend the S&B. I've installed and used them for all generations of Dodge, the fit and finish is good. The service is excellent!!!!! Can't go wrong.
PS Make sure to buy the pre-filter with it and a spare air filter so you don't have your truck sitting there when the filter is drying while cleaning it.
15 Ram 5500 CC60" SLT AS69RC 4.88, Brutus Deck, Maxilift 330.4, BD PAS, RaceMe Ultra Twister Resonator Stack, Toyo
14 Ram 3500 CCLBDRW Laramie AS69RC 3.73, Espar, TrailReady Fr FabFours Rr Bumper, Rigid, BD PAS, RaceMe Ultra Twister Resonator, Fox 2.0, 1-pc DS, Toyo
06 Ram 3500 CCLBDRW Laramie 48RE 3.73 Espar, ARB, Kenwood, Miller, BD PAS
14 Ram 3500 CCLBSRW Laramie 68rfe 3.42, RaceMe Tuning with Edge CTS w/ pyro, CCV/EGR/SCR/DPF delete, StrPipe, GoodYear
krs is offline
post #4 of 53 (permalink) Old 01-21-2017, 05:36 PM
KATOOM's Avatar
S&B always seems to have a nice product.
I have the old school aFe Mega Cannon with an outer pre-filter cover for years, and its still doing fine. When that filter gets old and grungy then I'm sure I'm going to pop on a BHAF. The idea of "cold air intake" isnt always what people think, and these year trucks dont need a true CAI, nor do they do as well with one during around town driving with a CAI. The only time a CAI seems to offer any benefit is when towing in the summer heat as it can reduce the EGT's around 100*.
KATOOM is offline
post #5 of 53 (permalink) Old 01-21-2017, 06:46 PM
i have the s&b also it bolted right in nice. only thing you have to keep retightning the hose clamps for a bit.
stubss is offline
post #6 of 53 (permalink) Old 01-21-2017, 07:15 PM
Stormin08's Avatar
The key is MORE, better filtrated air...not cold air.
Cold intake air can hurt your fuel mileage...roughly 140 degrees F is ideal IAT.
02 Sport / 47re / 4" MBRP TBE / DAP 75hp sticks/ HX35W / GDP FUEL BOSS / DDRP02 / 3rd gen brakes / 4th gen steering / 2" Thuren / MC ARMS / 5100's /285/75/17
Stormin08 is offline
post #7 of 53 (permalink) Old 01-21-2017, 07:43 PM
Western WA President
jigabop's Avatar
or you can just use a fooler to trick the IAT into thinking it is getting 140F air
your trucks turbo is going to heat the air up anyway just by compressing it.
Just avoid oiled filters.
Mopar1973Man likes this.
00 24v powered by the high performance "53" block and "Unicorn Injectors" 576hp/1285tq 8/10/2013
2004 Jetta TDI 5spd Malone S1 + dyn EGR/idle tune
Originally Posted by DieselDon16 View Post
my truck is literally full of Panties already...
Originally Posted by 'strokeThis_'07 View Post
I'll admit, I was sitting here giggling like a little girl
jigabop is offline
The Following User Says Thank You to jigabop For This Useful Post:
Mopar1973Man (01-21-2017)
post #8 of 53 (permalink) Old 01-21-2017, 07:52 PM
me78569's Avatar
Anything below *80 IAT causes a pretty dramatic timing spike. At this point I don't think anyone should be running a cai that causes iats to be less than 100*f
me78569 is offline
The Following User Says Thank You to me78569 For This Useful Post:
post #9 of 53 (permalink) Old 01-21-2017, 08:06 PM
krs
krs's Avatar
I recommend getting better hose clamps with the big spring like the BD intake items such as the positive air shutoffs.
krs is offline
post #10 of 53 (permalink) Old 01-21-2017, 10:28 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Cold air is not helpful. Trust me when I get in to the minus numbers for outside temperatures and the IAT falls to mere +20*F it really kills the MPGs and makes the engine rattle excessively. Like @me78569 said any temp below 80*F at the IAT is too cold. Optimal is 100-140*F. Personally I say BHAF and not worry about brand names filter nor washable junk.
I've got a 2001 Dodge in my yard right now with washable (name brand filter) and the filter is passing dirt, dust, and the filter oil and ruined the turbo. Turbo is so bad you can rattle the shaft to hear the bearing jingle inside. Not to mention it doesn't even spin when the engine is running and produces ZERO boost.
Mopar1973Man is offline
post #11 of 53 (permalink) Old 01-21-2017, 11:23 PM Thread Starter
Why should I avoid the oil filters?
post #12 of 53 (permalink) Old 01-21-2017, 11:29 PM
krs
krs's Avatar
I have had zero issues with my oiled filters. But yes over oiling can cause issues. I have zero dirt or dust pass through mine. I have in the past had issues with the stock filter housing leaking. Very cheaply built. I trust hose clamps and an oiled filter for the dirt roads I have to drive on. But when I oil mine I let it sit in multiple positions before installing and wipe off any excess oil with a cloth incase I over oiled a spot. I have spares for each truck.
krs is offline
