Coolant Bypass Kits - Dodge Cummins Diesel Forum
 1Likes
post #1 of 38 (permalink) Old 01-11-2017, 12:37 PM Thread Starter
Samich24v's Avatar
Coolant Bypass Kits
Who all makes bypass kits for 2nd gens?
trying to decide which route to go, i like the temp regulator idea of the fleece, but i would rather not spend that much money, not against putting my own kit together, just looking at options.
2001 2500 4x4 6 speed
WORK IN PROGRESS
p pump, some more fuel, some extra air
Samich24v is offline
post #2 of 38 (permalink) Old 01-11-2017, 03:24 PM
gmanss's Avatar
This is how I did mine. I used an E.D. plate and bought the fittings from my local hardware store and used a generic watts valve. I built the Y section with pieces of galanized piping I had laying around.
[IMG][/IMG]
98 QCLB 12v he351cw over billet S475 5x.016, 7mm DV's 4kgsk, Walbro 450lph, 5" Exhaust, DPC Converter, Billet Input, Firepunk Competition Rebuild Kit
gmanss is offline
post #3 of 38 (permalink) Old 01-11-2017, 03:36 PM Thread Starter
Samich24v's Avatar
What pressure did you set your watts at?
WORK IN PROGRESS
post #4 of 38 (permalink) Old 01-11-2017, 03:48 PM
gmanss's Avatar
I set it about 45psi.
gmanss is offline
post #5 of 38 (permalink) Old 01-11-2017, 03:49 PM Thread Starter
Samich24v's Avatar
Whats your reasoning? What started this research for me is seein what everyone has set theirs at.
Why is that much pressure required?
WORK IN PROGRESS
post #6 of 38 (permalink) Old 01-11-2017, 04:00 PM
gmanss's Avatar
There was a thread on comps awhile back where someone had tested the pressure at various rpms. At around 4k rpm the rear port was seeing 90+psi which is where most guys pop the freeze plug so 45psi is half of that and theoretically should start to pop around 3k rpms based off of his test numbers.
gmanss is offline
post #7 of 38 (permalink) Old 01-11-2017, 04:02 PM Thread Starter
Samich24v's Avatar
Gotcha! Thanks. I havent been able to find any info on that. I think i am goin to put a pressure gauge in p port on the head on mine and see where it is at what rpm and decide where to set it from there.
WORK IN PROGRESS
post #8 of 38 (permalink) Old 01-11-2017, 09:27 PM Thread Starter
Samich24v's Avatar
I'm think i am going to set mine around 20-25, if not buy the fleece kit. I like the idea of it being open in the lower rpm range as well. Only time too much flow can hurt is warming up.
WORK IN PROGRESS
post #9 of 38 (permalink) Old 01-12-2017, 09:40 AM
jlbayes's Avatar
Which was a HUGE issue with the Fleece kit.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
post #10 of 38 (permalink) Old 01-12-2017, 09:46 AM Thread Starter
Samich24v's Avatar
I knew eventually you would find this thread. And hopefully can give a little more advice than the motards on facebook. (Justin Starnes here btw).
But what exactly was the issue with the fleece kit? Being open all the time?
WORK IN PROGRESS
post #11 of 38 (permalink) Old 01-12-2017, 11:15 AM
jlbayes's Avatar
I've been keeping an eye on it. I want to bleach my eyes after the nonsense on fb last night and this morning. So the fleece kits circulate based off of temp, ok cool until the thermostat fails. Which was the issue. The stand the Lindeman and Matt use introduce coolant before the thermostat using pressure. Which is what I would suggest. Say the watts valve ever fails either closed or open, you will not have the issues with the engine never warming up. This is strictly a pressure issue with the water pump and poor circulation at the back of the block.
jlbayes is offline
post #12 of 38 (permalink) Old 01-12-2017, 02:08 PM Thread Starter
Samich24v's Avatar
I see your point about the tStat failing. And it is a very good one. Whats your input as far as a lower pressure setting. Am i wrong in thinking it would work better set at a lower pressure. Say 25ish? in (my) theory it would be opening 1500-2000 rpm. Which would be a good rpm to keep it cooling well. I'm tryin not to overthink this as i seem to do that a lot, but i want to do whats best for my engine. I dont have the money to build it multiple times, so i want to do it RIGHT the first time.
WORK IN PROGRESS
