Coolant Bypass Kits - Page 2 - Dodge Cummins Diesel Forum
 4Likes
post #13 of 50 (permalink) Old 01-12-2017, 01:47 PM
jlbayes's Avatar
Actually another buddy and I were discussing that side of it as well. We agreed the opening pressure should be lower. Now we get into the issue "IF" it will cause warming issues. Someone needs to test it as all the other stuff I have read....no one has as far as I know. I would if I had a bypass on my truck.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is online now
post #14 of 50 (permalink) Old 01-12-2017, 02:03 PM Thread Starter
Samich24v's Avatar
I'll be the test pig then! Lol. I'll see what i can find for a 25-50 psi regulator. I also plan on puttin a gauge on my head by number six too see what it gets to ridin around. It will probably be a couple months before my truck is driveable though, sadly.
2001 2500 4x4 6 speed
WORK IN PROGRESS
p pump, some more fuel, some extra air
Samich24v is offline
post #15 of 50 (permalink) Old 01-12-2017, 02:03 PM Thread Starter
Samich24v's Avatar
So you are makin big power and dont have a bypass. Can i ask why?
WORK IN PROGRESS
post #16 of 50 (permalink) Old 01-12-2017, 02:56 PM
jlbayes's Avatar
I am not turning the rpm when the majority of the issues arise. And I am out of room with the wastegate on the manifold.
post #17 of 50 (permalink) Old 01-12-2017, 07:14 PM Thread Starter
Samich24v's Avatar
Ahh. I see
WORK IN PROGRESS
post #18 of 50 (permalink) Old 01-14-2017, 07:01 PM Thread Starter
Samich24v's Avatar
So i'm having an issue finding a 1/2" regulator that goes under 50 psi.
Gmanss
Where did you find your regulator?
WORK IN PROGRESS
post #19 of 50 (permalink) Old 02-06-2017, 04:38 AM
thatguy69's Avatar
what do you guys think about making a setup like this?doesnt seem to hard
http://www.ebay.com/itm/351709214566
Sent from my SM-T550 using Tapatalk
Black.1999.ECLB4x4.118k.BHAF.Edge Juice w/ Attitude.Fass Ti150.Full Manual Georend 47RE. DAP 150 stix.II 62/65/14. ARP Studs
thatguy69 is offline
post #20 of 50 (permalink) Old 02-07-2017, 11:26 AM
Watts 5300A Bypass Control Relief Valve
I chose the 5300a since it will regulate from 0-250 psi where as the cheaper watts 530c that some people use won't regulate below 50 psi. This is the cheapest one I could find. My truck isn't running so I can't attest to how well it works.
redpower is offline
post #21 of 50 (permalink) Old 02-07-2017, 11:30 AM Thread Starter
Samich24v's Avatar
Thank you for that part number. Been having trouble finding a half in pipe regulator below 50 psi.
WORK IN PROGRESS
post #22 of 50 (permalink) Old 02-07-2017, 11:33 AM Thread Starter
Samich24v's Avatar
How well does it clear everything behind the engine? My concern will be adjusting the valve with engine in the truck
WORK IN PROGRESS
post #23 of 50 (permalink) Old 02-07-2017, 12:02 PM
I would use hose and fittings to run it from between the head and firewall to locate the valve on top or beside the engine so you can adjust it or replace it easier. You have to plumb towards the thermostat anyhow.
redpower is offline
post #24 of 50 (permalink) Old 02-07-2017, 12:05 PM Thread Starter
Samich24v's Avatar
Very true. Why i didnt think that through, is a very good question. Lol.
WORK IN PROGRESS
