Old 11-19-2009, 10:24 PM   #1 (permalink)
trx450rrider's Avatar
wierd thing happens when i shift and nail it sometimes... ADRENALINE??
well everyonce in a while when i go through the gears fast in my truck i will floor it in a gear and the tires will spin or i will hit the limiter usually the tires are spinnin then i shift and get on it and the truck pauses like its not doing anything then the power kicks back in. only every once in a while it does this.. maybe i dont get back on the gas fast enough or what i dono.... its almost like its a automatic with reeeeaaallly badddd defueling at shift points. anyone else have this problem??? its a 6 speed.. maybe the pumps poopin out???
01 6spd reg cab 2wd---Quadzilla ADRENALINE, airdog100, FBD 5" exh., BHAF, 3-4inch beltech drop kit, flame paintjob, valair dual disk, hamilton 110 springs, arp studs, hx35/ht3b twin setup, 200 sticks!
trx450rrider is offline   Reply With Quote
Old 11-20-2009, 07:13 AM   #2 (permalink)
milesdodgeboy's Avatar
Could be a number of things. What's your fuel pressure? Have you checked your codes so as to have a starting point at least in diagnosis?
2k1, 55block replacement swap underway. Ready to go on: adr/pulse, 150 sticks, hx35/ht3b, valair 600hp single disc clutch, getting ready to order smarty. baby! www.myspace.com/milesthehulk for my page
milesdodgeboy is offline   Reply With Quote
Old 11-20-2009, 10:32 AM   #3 (permalink)
what do u mean codes? my engine light isnt on or anything it seems like it only happens if i ride the gear out and shift and not get on it fast i was just seeing if anyone else has this problem and i dont have a fuel pressure gauge i will buy one this week
Old 11-20-2009, 10:35 AM   #4 (permalink)
P-pumped 24v Guy
mathews8pt's Avatar
Is it the fact that you have to build boost again after the shift and since your not getting back in the throttle right away it takes longer...???
What are your gauges doing when this happens?
2000 QCSB with a p-pump, typically broke and always stealing $$ from me
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 11-20-2009, 11:40 AM   #5 (permalink)
HI H.O. SILVER's Avatar
Sounds like your clutch to me.
Silver 02, quad cab, short bed, 6" lift, 385 70 16 Nitto Mudgrapplers, AFE sage 2 intake, 5" MBRP exhaust with 6" tip, Cobalt fuel, pyro, trans, boost guages, new SO VP, Quad Adrenaline W/ Pulse, airdog 150.
HI H.O. SILVER is offline   Reply With Quote
Old 11-20-2009, 07:25 PM   #6 (permalink)
its not the clutch i put a dual disk in it isnt reving up then it kicks on like a switch and takes off. i havent checked the gauges i bet its because i lost boost because i know when i really shift fast and get on the gas while letting out the clutch it doesnt do it. my friend said theres a thing on the pump where if your not putting out a certain amount of boost it wont fuel untill that boost is made so it must just be that?
