Old 11-17-2009, 11:39 PM   #1 (permalink)
dieselfurry's Avatar
Best injectors 11 hole?
Whats the cleanest best 200hp injector out there to work with a SO pump..... I hear Industrial injection 11 holes are amazing???? true false what are your thoughts?
NEW truck 02 4x4 auto edge drag comp HOT,air dog 150 , super b special, bd rad, tq convertor lock up switch, full billet tranny, 7x12' fbd injectors Sold: 01 5sp pulse/adrenaline, airdog 150,valair, 150's FBD,leveled.
dieselfurry is offline   Reply With Quote
Old 11-18-2009, 12:11 AM   #2 (permalink)
2001cumminsman's Avatar
F1 injectors, run clean
01 2500, S&B, ISSPRO, FASS 150, Mach 5s, Leveled, built "Floor It" transmission, lockup switch, Quad ADR, Smarty,RAD, Super B Special, ARPs, 5in exhaust Water/Meth.... 530hp 1070 ft lbs of torque... Diesel Crew
2001cumminsman is offline   Reply With Quote
Old 11-18-2009, 01:20 AM   #3 (permalink)
ckassen's Avatar
I HEAR that f1's run a little cleaner than ddp's, I am wanting to dyno my ddp's then maybe borrow a set of F1's and dyno them also. But honestly thinking about getting some F1's just to try them out.
02 2500 QC SB HO 2WD 6SPD, Super B Special, DDP 200's, Pulse/Adrenaline, Valair Ceramic Single, Airdog, HB torqued to 130ft/lbs....Ran a 13.98 at 104 with a 2.6 60ft with lots of wheelspin: 520HP 1093TQ on HO pump---1 NV5600 down
ckassen is offline   Reply With Quote
Old 11-18-2009, 07:07 AM   #4 (permalink)
Gixxer_750's Avatar
i wonder how smokey a jammer would be if they made a 200 hmm????
anyways, to the original question, my fbd 240's and special are super clean with no box on...they only smoke down low while the turbo is trying to light when you mash on it...wasnt sure if you were gonna try another injector but i know i can keep my setup super clean if i want (and the price is super hard to beat)...
'01 4x4
Gixxer_750 is offline   Reply With Quote
Old 11-18-2009, 07:45 AM   #5 (permalink)
cummins724's Avatar
I ran dragon flow 10 holes with a 64/65, then with a 62/65. They were smokey all of the time & were absolutely no fun to drive. I switch to Dragon fly 150's & they were a clean, smooth, smoke free injector. The power felt identical, but the smoke disappeared. I'm talking exactly the same feeling powerwise. I did 476hp on Dunbars dynojet with the flies & a 62/65/12, edge comp. I switched to M5's last winter & a 62/71/14, did 534hp at Hybrid dynamics dynojet with a 70% tune in my Adrenaline. This spring, I switched to a BD Super B Special and did 611hp at 57psi boost. I run 62psi on the street. The M5's are literally a clean injector unless I have the box on kill. I tow 18k# with this setup quite often & have no egt issues at all. I don't think there is a injector out there which compares to F1. All of my vids are on youtube, just click link in my sig.
99 QC 4x4, 5 speed, M5's, Super B Special, 3rd Gen E-Brake, ADRENALINE/SMARTY/Redline, AFE, Iron Giant, Fluidamper, Airdog, ARP, Orings, HD springs, DSS & 3rd Gen Bar, 607hp/1141lbft http://www.youtube.com/watch?v=XmQhCXQbedg
cummins724 is offline   Reply With Quote
The Following User Says Thank You to cummins724 For This Useful Post:
jmd025 (11-18-2009)
Old 11-18-2009, 09:02 AM   #6 (permalink)
mjd91's Avatar
From what I've read, more holes = more smoke
Mitch 2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, Quad Adrenaline, AirDog II 165, AutoMeter Cobalts, Peak intercooler boots
mjd91 is offline   Reply With Quote
Old 11-18-2009, 09:46 AM   #7 (permalink)
Steveo24's Avatar
Was that 611 with all your boxes stacked including the redline??
98.5 3500 2WD dually 4:10's lFull Auto Meter lByrds intakel64/71/14 lGHDlARPl150 horse sticks l.093 tubesl Smarty lEdge Comp HOT lStage 2 snow kitlAir Dog lAmsoil lGeorend trans l VP intercooler boots 536/1175 10/17/09
Steveo24 is offline   Reply With Quote
Old 11-18-2009, 11:00 AM   #8 (permalink)
kjpcummins's Avatar
If you want to rebuild your engine because you broke a tip off the II injectors run them. What they do is the utilize the factory holes and then edm more holes right above them casuing the nozzles to be week. This causes overlapping spray patterns and bad atomization. I think there was a 1hp difference between a 11-hole and 7-hole injector on the dyno of the same size but the 11-hole ran hotter and caused alot more smoke.
2002 2500 4x4 6 speed 2.5 towrig / 1997 2500 4x4 5 speed 2.8
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Smokem Injectors
kjpcummins is offline   Reply With Quote
Old 11-18-2009, 11:02 AM   #9 (permalink)
kjpcummins's Avatar
Injectorparts are the same as jammers and you can buy a 200hp from them. I believe thats what powermad is running on his truck.
Old 11-18-2009, 11:07 AM   #10 (permalink)
National Chapters President
Broke Down's Avatar
kjp can you please find 1 person on here where someone has lost a tip off of one of those injectors which was not fault of his own. i swear i will back you up on it later
DUKE<-- 2000 4x4 3/4 ton ex cab lwb ATS converter,suncoast heavyduty rebuild kit,ATS valve body, edge EZ, straight piped, 3rd gen cromeclads, isspro pyro boost fuel, FASS , coaltrain 150's, TST PM2, tunnel ram intake manifold, dukie pipe intake, leveled on 35x10.50x17 Super Swamper SSR's
Broke Down is offline   Reply With Quote
Old 11-18-2009, 11:18 AM   #11 (permalink)
kjpcummins's Avatar
I have seen 5 local guys break or crack tips and many others with the II 11-holes just saying it could happen. I know they are on other sites but not sure about this one.
Why would it be the persons own fault if you crack or break a nozzle tip. I guess it was their fault they were running them.
Old 11-18-2009, 11:24 AM   #12 (permalink)
Broke Down's Avatar
fair^ not bustin balls is their any way you could get a pic and pm it to me. i'm not trying to make you look foolish but i have never seen or heard of such. i will delete this when a response is made
what if it was damaged in shipping or dropped thanks
