vulcan draw straw 1 - Dodge Cummins Diesel Forum
Old 11-09-2009, 03:29 PM   #1 (permalink)
Banned
vulcan draw straw 1
Well i tried emailing vulcan tech and no reply. So I need your guys help. I snapped both lines off the sending unit while doing a raptor 150 install. So i figured I would buy the draw straw one with the two fittings on it, one for suction and one for factory return line. My problem is since the truck is 50miles from me in my parents garage. I wanted to know what size are the factory lines? I wanna just run a rubber hose with hose clamp to the factory return line that is left to the 3/8fitting given with the kit and then run the raptor to the 1/2inch fitting.
dieselsoon is offline   Reply With Quote
Old 11-09-2009, 05:28 PM   #2 (permalink)
Banned
anyone? bump
Old 11-09-2009, 06:17 PM   #3 (permalink)
lutz's Avatar
suction side is 3/8 ,return side is 5/16 ... someone correct me if im wrong....
99 3500 dually 24v 5spd 4x4, k&nfilter. xzt+,raptor 100 , silencer ring MIA ,B&W turnover ball and a cow bell,fuel pressure gauge in the works
lutz is offline   Reply With Quote
Old 11-09-2009, 06:57 PM   #4 (permalink)
Banned
do you think its possible that i get a hose that fits over the 3/8's fitting on the draw straw and clamp the out of the 5/16's return factory line?
Old 11-09-2009, 07:59 PM   #5 (permalink)
Banned
Draw Straw I 1/2 in. draw tube and 1/2 in. pushlock fitting
One of the option is
DrawStraw I Preassembled 1/2 supply & 5/16 OEM return connection [Add $5.00]
Is that what i need? 1/2inch for raptor fuel in, and 5/16 fitting to run with oem return correct?
"All necessary components are included*, no need to go shopping for extra parts and no tank drilling!"
"Uses OEM grommet, slight internal modification to fuel module required."
No tank drilling? internal modification to pump? um confused.
Would somebody chime in that has done this drawstraw please? I need to order something so i can fix it this weekend.
Old 11-09-2009, 11:22 PM   #6 (permalink)
lutz's Avatar
i may be wrong.. but i think the draw straw 1 might go in your sending unit.. im guessin you just pull those metal lines out and insert the draw staw .. i would call them just to be sure .. the draw straw 1 should come with directions
Old 11-10-2009, 03:21 AM   #7 (permalink)
Explosives87's Avatar
here is a link to the install of the draw straw 1 from vulcan. Vulcan Draw Straw Installation
01 2500 QCLB Straight pipe,6 spd,Stock for now
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd amendment
Explosives87 is offline   Reply With Quote
Old 11-10-2009, 03:22 PM   #8 (permalink)
Banned
I called vulcan today the guy said I actually drill the pump out where the return line and suction fit into. And it is a 5/16 for oem return line.
