Quadzilla V2 Testing - Page 45 - Dodge Cummins Diesel Forum
 110Likes
post #529 of 719 (permalink) Old 02-17-2017, 12:34 PM
me78569's Avatar
Do you have the valve train mods specified as a requirement for the hardfuel file?
00 Dodge 2500 quad 5.9 Cummins, DFI 7x.009, he351ve arduino controller, homebuilt 47re revmax 3.5 messed with vb, Quad adr V2, 4",150 gph, studs/sprgs/psh rds
me78569 is offline
post #530 of 719 (permalink) Old 02-18-2017, 02:11 PM
me78569's Avatar
I don't think I ever said it over here, but the backdowns have ben rewritten to no change power levels rather it just starts pulling canbus fuel. This is significantly smoother than will do a much better job of keeping boost and or egt where you have the max set to. The Quad will allow for up to %80 of total fueling to be pulled, wiretap included.
Here's a data log from carb showing it work. It will spike beyond the limit then start pulling fuel until the limit is reach then try and hold that.
The more realistic your backdowns are the less of a overshoot there will be, however Tfaoro reported that even his truck was able to keep boost / egt in check with backdowns setup so I am calling it a win.
b+barandgrill likes this.
me78569 is offline
post #531 of 719 (permalink) Old 02-18-2017, 03:18 PM
I am very impressed with everything you have been able to accomplish with the v2 tuning in such a short amount of time. I absolutely love the way my truck runs now compared to the edge or the old quad tunes. Being able to use cruise is probably my favorite. Thank you for all the time and effort you and the beta testers have put into this. It is fantastic
99 2wd ext cab lb SRW. Quadzilla adrenaline, DAP 7x.009 (100hp sticks) big air filter. Valair Single Disk organic clutch. FASS Platinum 150gph. Jacobs exhaust brake. 232k miles
b+barandgrill is offline
post #532 of 719 (permalink) Old 02-20-2017, 03:34 PM
QuadzillaPower.com
QuadzillaPower's Avatar
Just so everyone knows. You should update to this latest version of the tuning. There is a new tuning variable as well as the backdowns.
Also, with the latest releases you can see your build date of the base level code. If you are running 20170213 or later you should be good. We are calling this one 2.3.1.
Please get the update from mopar1973man.com or you can send your box in to us for re-tuning.
Mopar1973Man likes this.
QuadzillaPower is offline
post #533 of 719 (permalink) Old 02-20-2017, 07:23 PM
thatguy69's Avatar
is there anyway to monitor boost at 2 differant points if we bought another pressure sensor for us guys with twins?
Sent from my SM-T550 using Tapatalk
Black.1999.ECLB4x4.118k.BHAF.Edge Juice w/ Attitude.Fass Ti150.Full Manual Georend 47RE. DAP 150 stix.II 62/65/14. ARP Studs
thatguy69 is offline
post #534 of 719 (permalink) Old 02-20-2017, 08:09 PM
me78569's Avatar
Use your fuel pressure sensor.
me78569 is offline
post #535 of 719 (permalink) Old 02-20-2017, 08:13 PM
thatguy69's Avatar
Nifty nifty that'll work. Does the sender have the ability to accurately read up to 70psi or so?
Sent from my SM-N910V using Tapatalk
post #536 of 719 (permalink) Old 02-20-2017, 09:04 PM
me78569's Avatar
It's a 0-100 psi sensor.
me78569 is offline
The Following User Says Thank You to me78569 For This Useful Post:
bleedcummins (02-21-2017)
post #537 of 719 (permalink) Old 02-20-2017, 09:04 PM
thatguy69's Avatar
great thanks
post #538 of 719 (permalink) Old 02-23-2017, 07:41 AM
norrisk66's Avatar
Trying to understand the cruise timing advance-
From the V2 custom tunes on MoparMan's site-
On the 3rd page, there are a list of custom tunes for stock injectors.
On the DAILY tune, for example, the cruise timing advance is listed as .5
My iQuad app (for iOS) will only let me enter whole #'s.
Am I missing something?
2000 2500 4X4 QCSB, 5-Speed. 250,000 Miles FASS 150, 4" Magnaflow, Quad ADR W/iQuad
1951 Chevrolet 3600 Pickup, 1953 BMW R67/2 Motorcycle
1966 Lincoln Continental Coupe, 2000 Cadillac DTS
norrisk66 is offline
post #539 of 719 (permalink) Old 02-23-2017, 08:31 AM
me78569's Avatar
Existing bug with iOS app. I wouldn't worry about the .5 the difference wouldn't be huge. I am sure if you where to do some track testing etc you might pick up power by adjusting timing to a decimal point but my butt dyno says things are fine with whole number.
me78569 is offline
post #540 of 719 (permalink) Old 02-23-2017, 02:21 PM
gh0stman's Avatar
@QuadzillaPower when is the diagnostic part of the app going to be working?
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops, DAP HD Pushrods
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is offline
