Old 11-07-2009, 12:07 PM   #1 (permalink)
LilBlackTruck's Avatar
Diablo Sport Power Puck Question
hey, i just got a question about the Diablo Sport Power Puck and a smoke switch i see that many people do smoke switches with the edge or other brands but i havent seen anyone do it with the power puck i just wanted to know if it works with the power puck thanks.
LilBlackTruck is offline   Reply With Quote
Old 11-07-2009, 12:40 PM   #2 (permalink)
I don't think these electronic gadgets work too well on the mechanical 12 valve. They work on 24 valves though. You might try going up in years. I'm sure you will get better response.
RPegram is offline   Reply With Quote
Old 11-07-2009, 05:46 PM   #3 (permalink)
GA VP...so close to 500hp
patracy's Avatar
Put your truck details in your sig.
Why do you need a smoke switch?
Puck doesn't work the same as a fueling box. So you can't smoke switch it.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is offline   Reply With Quote
