Old 11-07-2009, 03:44 AM   #1 (permalink)
HX35 or HY35
I understand they are a little different when it comes to the wast gate but is there a benefit to one or the other and are the interchangeable?
I have a 01 with an HY and i have a spare HX with less miles sitting i my garage. This is why i am asking.
Thanks for the input in advance.
Lowkey is offline   Reply With Quote
Old 11-07-2009, 04:11 AM   #2 (permalink)
razocow's Avatar
HX has a slightly larger exhaust housing allowing better egt control over the hy, also the hx can handle slightly more boost, but it is still limited to about 32-35psi before pushing hot air and over speeding, I would not try to push a hy past 30.
I say swap it.
2000 quad cab short bed-looks stock...
B!tch Slap Of Truth
razocow is offline   Reply With Quote
Old 11-07-2009, 04:12 AM   #3 (permalink)
BuffaloLake's Avatar
I believe that the HY35 has a 9cm exhaust port and the HX35 is 12cm exhaust port, so the HX35 is a little bit bigger turbo. In the 1998.5-1999 years, all trucks got the HX35. 2000-2002 the stickshifts got the bigger HX35, while the autos got the smaller HY35. If you stay stock, the HY35 will spool faster (but run hotter), but if you upgrade your power at all the HX35 would be the better bet.
1998.5 24v 3/4 ton 4wd quad cab long bed 192,xxx miles, Airdog 100, BHAF, 6" Aussie stacks (thanks to FBD) with custom heat shield, auto trans rebuilt for towing, Hornblasters 240 Shocker, occasionally tows 35' 5th wheel...
BuffaloLake is offline   Reply With Quote
Old 11-07-2009, 05:16 AM   #4 (permalink)
Horse Power JUNKIE
Nitrous340's Avatar
Do the swap cause if you add even a little more fuel it will work better.
2001 2500 4x4
PDR HX-40, PSC brace, Hamilton 110 springs, Fluidamper, ARP studs, Adrenalin, DDP 150, custom intake, 4" straight pipe, AIRDOG 150, BD black FP, Suncoast billet trans, 3-disc converter, 3rd Gen Brakes, Thuren 3rd Gen track bar. RIP grandpa "Red" 10-11-08
WAGNAAR MOTORSPORTS
Nitrous340 is offline   Reply With Quote
Old 11-07-2009, 11:33 AM   #5 (permalink)
lay the two turbos side by side! the HX is larger. I switched my hy for hx and its a huge improvement over the hy in the EGT dept, spooling is no different.
It will be worth it to switch them over, it only takes an hour of your time to do
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Jun/09 455,000kms RETIRED Military Mechanic (20yrs)
nickg is offline   Reply With Quote
Old 11-07-2009, 11:49 AM   #6 (permalink)
Red
crccummins's Avatar
i question your years and what turbo they got. i have a 2000 auto and it came with an hx35. just thought i would let you guys know
2000 caps 24v cummins / 4x4 / ec / L-bed / 295-75 R16 A/T / Tow Mirrors / BHAF / Airdog100 / Edge juice with attitude / mbrp 4" turbo back exhaust.
crccummins is offline   Reply With Quote
Old 11-07-2009, 12:38 PM   #7 (permalink)
awsome. will be doing this next week.
anyadvise or parts i'll need besides a gasket or two?
Old 11-07-2009, 08:51 PM   #8 (permalink)
I may be off on the years. I keep forgetting whether it was 2000 or 2001 when they made the switch.
Old 11-07-2009, 08:55 PM   #9 (permalink)
while the HX can support a little more power. To deal with swapping them out, id rather just get a worthwhile upgraded turbo instead of just another stocker.
jmho.
Jason
2001.5 Ext. Cab Short bed 4X4-315 BFG AT's/AEM HD intake/MBRP 4"/Silencer ring M.I.A/Raptor 100/new VP44/Mag deep trans pan/Edge EZ/RV275's/Quad Commander/Kool-Vue power/heated tow mirrors
JasonY is offline   Reply With Quote
Old 11-07-2009, 09:00 PM   #10 (permalink)
Gixxer_750's Avatar
im pretty sure it was 01 when they started w/ the hy (not sure why they would start putting it on)...and to the original question, just do it...cooler egt's are always nice and the swap really wont take long at all...take a saturday afternoon and enjoy a slightly bigger turbo
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..."
Powered by FBD
Gixxer_750 is offline   Reply With Quote
Old 11-07-2009, 09:38 PM   #11 (permalink)
only one thing. Bigger turbo is $$$$ the HX35 is free becasue i have it already. i drove the truck i took it off of and it was super clean and turbo is in great shape.
Old 11-07-2009, 11:30 PM   #12 (permalink)
exactly, if its free its a nice upgrade, and if you had to get one cheap its a nice upgrade, I paid 100$ for my HX and it was worth every dollar, with the HY I would spike the EGT before I hit 60mph on any level above 3, now I can use level5 and just start to trip the egt warning at 80-90mph
And I have a HE351 (from a 05) sitting on the bench, when I get time it will be my next upgrade, and it cost 100$ as well!
