Old 11-07-2009, 01:55 AM   #1 (permalink)
chromestackzach's Avatar
Advice on cams
Hey guys ive got a 99 24v taht i have put the edge drag comp, smarty programmer and edge jammer 150's and a banks high ram intake on, just recently i installed arp head studs and a marine head gasket and now im looking to install a bigger cam, i have looked at the ones from peakdieselperformance.com and wondering what yalls opinion is on them or have any other suggestions?
99' Dodge 2500 5spd with button ceramic clutch, edge jammer 150s, edge drag comp, smarty sx03, stock turbo, 5 inch stacks, mkw 20" wheels, dick cepek fc radial 2s, front leveling kit, cowl induction hood, projector head lights, smoked taillights,
chromestackzach is offline   Reply With Quote
Old 11-07-2009, 02:09 AM   #2 (permalink)
sstockton's Avatar
A cam will give you the most benefit in the higher RPM range. They aren't going to hurt lower RPM at all, but you won't get much gain from them until you are really winding it out. Thats when they start to shin. I would highly recommend a different turbo over a cam at this point based on what is in your sig.
The stock turbo can't provide the air that your engine requires as of now. You will notice much much larger gains from a turbo than you will from a cam right now.
With that said, there are a lot of factors that go into making a cam a good cam and personal preference. Lift, Duration, and lobe seperation all play a big part in how a cam performs. I run a helix 2 and like it. Fletcher's cam also seems to be very popular at this point. As is the Max spool 2.5.
Sean
2000 2500 Reg. Cab 4x4. Built trans, Twins, Edge drag box, Sticks, Studs, cam, Gauges, etc...
09 2500 6.7L QCLB 4x4, G56, all stock for now.
sstockton is offline   Reply With Quote
The Following User Says Thank You to sstockton For This Useful Post:
chromestackzach (11-07-2009)
Old 11-07-2009, 02:20 AM   #3 (permalink)
Alberta Pres
mattyboy72's Avatar
yup cam wont do nothing for u till u get a turbo on, i know on mine even though its a third gen it runs so smooth at wot almost too good lol
04.5 3500 laramie,DDP 64mm,50's,cam,springs,S&B stage2,Diablo Predator,Edge juice with attitude,4inch into quad stacks,glowshift gauges,mickey t's with dynapros,badass set of truck nuts
OIL COUNTRY COAL ROLLERS
PUBLIC DISTURBANCE
mattyboy72 is offline   Reply With Quote
The Following User Says Thank You to mattyboy72 For This Useful Post:
Old 11-07-2009, 11:50 AM   #4 (permalink)
kscumminsdriver's Avatar
echoing the priors, the return on investment on a cam is so low that it should only be considered as a last modification.... put a more appropriately sized turbo on your truck first.....
2002 QC, SB 4x4 6 spd 2500, I.I. HRVP44, FASS, TST Competition, Smarty, Mach 5's, Di/Pricol gauges, South Bend 3850DD, single 6" stack, BBT Super B/GT4202 twins, ATS exhaust manifold, F1 valve springs,ARP head studs, O-rings, Fluidampr...
kscumminsdriver is offline   Reply With Quote
The Following User Says Thank You to kscumminsdriver For This Useful Post:
Old 11-07-2009, 04:28 PM   #5 (permalink)
Sean
So the cams that u talked about..where do i find those? I was thinking that i would just put the cam n now while i got it tore down as far as i do now but do plan on puttin twins on it n the near future, i was gonna put the cam and new lifters and springs too
Old 11-07-2009, 05:15 PM   #6 (permalink)
Well, if you have the front of your truck and engine already off, then doing a cam now makes sense in at least the respect of having the truck torn down...
Helix II is an F1 Diesel product but I think they're sold out right now...
Fletcher's cam is from Diesel Pros... you'll have to call them to discuss and/or order...
Maxspool cams are a greg hogue product...
I'm going to be running a Scheid cam in mine soon...
chromestackzach (11-08-2009)
Old 11-08-2009, 02:41 PM   #7 (permalink)
Hey thanks guy for the info i didnt know there was so many different cams available for my truck so this definantly will help me with researching these cams
