| 98.5-02 Performance Parts Discussion Discussion of Performance Parts For the 98-02 Trucks No Advertising ...NO ADVERTISING |
raptor 150 install gone bad
Well i gotta all of it done except disconnecting the fitting from the gas tank. Well I pushed and pullled on the clip while depressing it and I snapped the metal elbow clean off the sender unit! So wheres the cheapest place to buy a sending unit?
98.5 (2wd) (ext.cab. black) 3:55 gears, the legendary hiperf 53 block, 5 speed, edge juice w/ attitude- full mbrp exhaust- ats intake manifold, kn intake, raptor 150 |
#2 (permalink) |
wow that sucks...i thought i was going to break mine though...i guess i just got lucky. if it was me i would just look for a way to plug the hole and not worry about it. on mine i just used a rubber plug that fit over the metal part tightly and put a zip tie around that and it holds(doesnt leak).
98 cummins 148K miles 4x4, compleatly built tranny by DTT diesel performance transmissions, tranny temp, egt, boost guages. Airdog 150!
#3 (permalink) |
Location: lower central NY but in the sunshine state right now
looks like it is time for a draw straw now
99 3500 auto 2WD DRW mosty stock 5" straight pipe 100 raptor fuel pump silencer ring m.i.a.261k and counting http://myspace.com/jitt08 and my email is jitt08@myspace.com
#4 (permalink) |
what are my options? I dont know if i have enough to run a hose off of the existing half broken piece? draw straw I could just plug that hole and drill a hole for draw straw right? Do i have to drain the whole tank to drill the draw straw hole cause of the shavings?
#5 (permalink) |
i just installed my raptor last week , had the same problem i tried everything and couldnt fix it , save yourself time and just get a draw straw ..
99 3500 dually 24v 5spd 4x4, k&nfilter. xzt+,raptor 100 , silencer ring MIA ,B&W turnover ball and a cow bell
#6 (permalink) |
when i drilled the hole in my tank , i held a cup under where i was drilling and caught all the shavings,
#7 (permalink) |
its easier to lift the bed then it is to drop the tank isnt it? 6bolts?
#8 (permalink) |
drop the tank , theres only 2 staps holding that tank up,how much fuel is in your tank , have someone to help you drop it
#10 (permalink) |
the tank strap goes right up beside it .. you are going to need a deep well socket
#11 (permalink) |
when i dropped my tank i had no issues with that cross member , you need to get that fuel out of your tank..
#12 (permalink) |
is there anyway i can make a drawstraw myself? There is no one local i know of that would have one or i have to wait till next weekend and order one today. thanks.
