Old 11-06-2009, 08:13 AM   #1 (permalink)
redline box?
how good are these boxes? i like how they claim they dont cut back fuel until desired i want to get into sled pulling more. it suggests stronger valve springs anything else i should do to the motor besides the normal. turbo, liftpump, injectors stuff like that.
thanks
02 cummins 6sp silencer ring MIA 3'' lift cooper discoverer stt 33x12.50 16 south bend dd 3850
02 cummins gen 2 is offline   Reply With Quote
Old 11-06-2009, 08:35 AM   #2 (permalink)
Go for Broke
Graphic Man's Avatar
i have heard good and bad on the Red line boxes.
here is a list....depending on the call you want to run in
Clutch
Timing/fueling box
L/P like a FASS or .......
bigger turbo (depending on class)
Injectors (depending on turbo size)
trac bars
drive shaft loops (if needed in that class)
valve springs
head O-ringed and studded
and i an sure i am missing a few things
08 Mega cab is on it's way
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline   Reply With Quote
Old 11-06-2009, 08:54 AM   #3 (permalink)
Overfueled N under-aired
johnyb59's Avatar
May want to look into a Fluidampner. It will be a little easier on the engine when is spinning the higher rpms
2001 SRW QCLB 150 hp jammer nozzles, 120 hp quad stacked w/ 65 hp xzt+, tst stealth plate, walbro lift pump, leveling kit, autometer has all the gauges covered, Valair ceramic, 4" straight pipe, stock turbo "If it weren't for the United States military, there'd be NO United States of America."
johnyb59 is offline   Reply With Quote
Old 11-06-2009, 09:46 AM   #4 (permalink)
Gixxer_750's Avatar
id say pass on the redline right now if you are looking to get into the sport....get a quality box like an edge drag, build from there, see how you like the sport, and then see if you want to take it further (you can still pull and have fun without the redline)...like mentioned above, you're gonna have to build your rig up to be able to handle it, so for the time being, im gonna say no to the redline
2001 4x4 - ACDC ..."i've got gauges so i'll race ya..."
Powered by FBD
Gixxer_750 is offline   Reply With Quote
Old 11-06-2009, 05:41 PM   #5 (permalink)
well i know i like the sport i pulled my bros dmax a few times. i got a dd clutch coming and in the process trying to find a local engine shop to oring my head when i take it off to head stud it no luck so far. i looked into the comp/drag boxes but still trying to find a good programmer to stack with it. i like your guy's info thanks
Old 11-06-2009, 05:43 PM   #6 (permalink)
by the way my truck came with the superchips and i'm trying to sell it.
Old 11-06-2009, 05:46 PM   #7 (permalink)
MOPAR MAN's Avatar
I have heard the Redline box is not reliable or streetable, Its wide open or nothing. But thats just what I have heard. I am looking for something that will RELIABLY get me to fuel 4k, & heard but dont know if its true or not, that smarty was going to be coming out with a 4k tune for the VP trucks. If it is true it may be worth it to waite till they do.
00 2500 4x4 5spd, Balanced & blueprinted, Rings&Studs CR Head W/P&P, All ARP, HD Big Stick, 110# Valve springs, Coated pistons & bearings, S&B, Intake horn, Header, 5" TB, Edge J W/A HOT, GT3788R, 120HP stix, FASS, ValAir DD, Fluidamper.
MOPAR MAN is offline   Reply With Quote
Old 11-06-2009, 08:44 PM   #8 (permalink)
cummins724's Avatar
The redline box is a all or nothing box for sure. I only use mine for pulling because it is too touchy for street driving. The box is very touchy when trying to launch as well. I gotta watch my rpm gauge very carefully, if I launch at 4200, it is fine. If the revs go over 4260rpm, it cuts off fuel & shudders. You can hear it in this video, I had to let out & start over a few times because it kept cutting off power.
YouTube - Listie Grove, 11-1-09; Jamie Lent
99 QC 4x4, 5 speed, M5's, Super B Special, 3rd Gen E-Brake, ADRENALINE/SMARTY/Redline, AFE, Iron Giant, Fluidamper, Airdog, ARP, Orings, HD springs, DSS & 3rd Gen Bar, 607hp/1141lbft http://www.youtube.com/watch?v=XmQhCXQbedg
cummins724 is offline   Reply With Quote
Old 11-06-2009, 08:55 PM   #9 (permalink)
kjpcummins's Avatar
Im curious if getting the upgrade to a unlimited box would fix that problem. They dont seem to have the fuel cutting problem and go 4300rpm+. Im gonna see what happens when i get the redline on the truck and stack it with the jim jessup tune thats on the ecm.
2002 2500 4x4 6 speed
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Southern Diesel Extreme Injectors
kjpcummins is offline   Reply With Quote
Old 11-06-2009, 09:31 PM   #10 (permalink)
cummins724's Avatar
I'm gonna get the unlimited upgrade before next season, but Chip said that I am probably already hitting my max rpm.
Old 11-06-2009, 09:37 PM   #11 (permalink)
kjpcummins's Avatar
Im gonna playing with it quite a bit in the next couple weeks once i fix the power to the airdog so the ecm doesnt cut fuel. I might just do it like yours so i dont forget to turn the airdog on thats all i would be worried about. I might give chip a call next week about the upgrade. I need to get ahold of monster mike and pick his brain about a few things but cant seem to get ahold of him maybe i have the wrong number.
Old 11-06-2009, 10:55 PM   #12 (permalink)
cummins724's Avatar
Adding the switch gave me a extra 100rpm. well worth the 10 minute install.
