Old 11-06-2009, 12:37 AM   #1 (permalink)
03 Brake swap
I am thinkin of swapin disk brakes onto the rear of my truck and was just wonderin how big the rotors off the newer truck are. So i know if I would need 17" wheels or not. Tried searchin cause i know this has been talked about before but couldn't find it. Thanks for the help.
99 2500 4X4, Edge drag comp, 150 sticks, Arp Headstuds, oringed head, Fass 150, Hotrod VP 44, he351/S475 Twins, ATS arcflow, Full billet ATS race trans D70 in the front......now
Twinguy is offline   Reply With Quote
Old 11-06-2009, 12:55 AM   #2 (permalink)
SCRRRP
ruidosododge's Avatar
the 3rd gen calipers will require at least a 17" wheel. 16" wheels will not work... hope that helps
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
ruidosododge is offline   Reply With Quote
Old 11-06-2009, 09:16 AM   #3 (permalink)
nbaca's Avatar
i know that some 17s are a little thicker and wont clear so it will depend on the wheel
2001/NV5600/TWINS/200hp STICKS/ARP STUDS/110lb SPRINGS/QUAD ADRENALINE/RAPTOR 150/ISSPRO GAUGES/DEVILS OWN METH INJECTION/5in EXHAUST/SBC3600 DD/SBC HYDROS/IN SEARCH OF 600HP AND BUILT WITH DIESEL AUTO POWER PRODUCTShttp://www.southwestcoalrollers.com/
nbaca is offline   Reply With Quote
Old 11-06-2009, 11:57 AM   #4 (permalink)
00BRam's Avatar
This question may be off topic but how hard would it be to switch from drum brakes to disc brakes on the rear??
00 Cummins....slightly modded.
00BRam is offline   Reply With Quote
Old 11-06-2009, 08:57 PM   #5 (permalink)
well it wont be if two people have the same question...i have been wondering if it is even worth it or not.
98 cummins 148K miles 4x4, compleatly built tranny by DTT diesel performance transmissions, tranny temp, egt, boost guages. Airdog 150!
smokin 98 cummins is offline   Reply With Quote
Old 11-06-2009, 10:21 PM   #6 (permalink)
nbaca's Avatar
i would personally find a rearend from a disc truck and swap it over.
Old 11-07-2009, 12:02 AM   #7 (permalink)
I'll let ya know, as I'm hoping to have the parts soon to switch my drums out to disc, parts are for a dana 80 and I'm going to see if they fit on a Dana 70, should have an answer in a week or two
2001, 2500 Edge J/A Hot unlocked,Magna flow exhaust. Jammer II's. BHAF, Airdog 150,DSS,3rd gen Track Bar. Carli Suspension, 3rd gen Brake upgrade, transgo Shift Kit. Firestone AirBags May 07 297,000kms Jun/09 455,000kms RETIRED Military Mechanic (20yrs)
nickg is offline   Reply With Quote
Old 11-07-2009, 12:07 AM   #8 (permalink)
00BRam's Avatar
I have been tryin to keep my eyes open for a disc rearend. I did a complete overhaul on my drums and they still suckazz. LOL
Old 11-07-2009, 12:27 AM   #9 (permalink)
conversion kits:
EGR Performance Brakes, rear brake conversion kits
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100.
Dracozny is online now   Reply With Quote
The Following User Says Thank You to Dracozny For This Useful Post:
00BRam (11-07-2009)
Old 11-07-2009, 01:02 AM   #10 (permalink)
Thanks I knew the fronts I would need 17s but i didn't know if the rotors on the rear were the same size. I hear that the swap is easy from drum to disk just pull everything off includin the backing plate and i hear it will just bolt up but thats just what i hear.
Old 11-07-2009, 09:04 AM   #11 (permalink)
HidalgoGT's Avatar
If they stop better then the drums then it would be worth it to me as 38"s don't like to stop rolling to fast. Sunscribed...
2001 Dodge ram 2500 Quad cab. 5spd,Cold air intake,4" exhaust,5.5 fabtech suspension,38" Mickey MTZ's,Smarty tuned lvl8 with tweaks,Drag Comp. Soon to be worked and tuned by Disturbed diesel performance.
HidalgoGT is offline   Reply With Quote
Old 11-07-2009, 12:30 PM   #12 (permalink)
00BRam's Avatar
That EGR kit looks like a good kit, I'll probably go that route unless I run across a rear disc axle setup before I build up the funds. How hard and costly is it to put 3rd gen rotors and calipers on the front??
