Old 11-04-2009, 08:55 PM   #1 (permalink)
5.9 Coal Roller's Avatar
is it really needed?
i am gettin the juice with attitude, but i have been told that i need an airdog or fass before ANYTHING. I know it would be ideal but is it something that i really do need to do first? and i will admit that i dont wanna be replacing my vp!
thanks,
Ryan.
2000 2500 QCSB white, non 53 block! , 5 spd manual, MBRP 5" turbo back w/ muffler delete, Edge EZ, PacBrake PRXB, silencer ring MIA, HBS 2.5' keveling kit, Moto metal MO957 BLACK 17", Goodyear Wrangler Duratrac 33's, airdog and juice w/ att. coming soon.
5.9 Coal Roller is offline   Reply With Quote
Old 11-04-2009, 09:03 PM   #2 (permalink)
CumminsOrNothin's Avatar
Your going to wanna do it as soon as possible. But at least you can monitor your fuel pressure with the attitude. VP are not cheap. How many miles bro??
1999 4x4 Auto De-Chromed
Southwest Coal Rollers.Com(NM,TX,AZ,CO)
CumminsOrNothin is offline   Reply With Quote
Old 11-04-2009, 09:03 PM   #3 (permalink)
87poweram's Avatar
yes that is probably something you want to do first. I dont see gauges listed in your sig, but that comes with the attitude monitor. i would recommend the airdog first. but if you hook up the juice that will tell you your psi, but it will be hard to keep from going above stock levels, until you have a pump that can keep up with fueling that edge. so if you get airdog first you can use the juice as soon as its on, if you get the juice first, you probably won't be able to fuel it above stock until you put a new pump on. If i had to do one first, it would be the airdog then the juice.
98 24V qcsb. 4" mbrp, bhaf w/stainless shield, raptor 100, FlashPaq, isspro column mount fuel pressure.
87poweram is offline   Reply With Quote
Old 11-04-2009, 09:12 PM   #4 (permalink)
get the edge just set the fuel psi alert at 10psi, ya hear the beep immediately get your foot out of it. I cant go past level 3 or it will beep right away and i idle 15psi and can suck it down to 9 in level 3.
98.5 (2wd) (ext.cab. black) 3:55 gears, the legendary hiperf 53 block, 5 speed, edge juice w/ attitude- full mbrp exhaust- ats intake manifold, kn intake, raptor 150/draw straw 1
dieselsoon is offline   Reply With Quote
Old 11-04-2009, 09:13 PM   #5 (permalink)
little red cummins's Avatar
yea id do the FASS or AirDog first. i got my J/A first and saw that i was only pushin 10psi at idle.....
i got lucky and didnt f up my VP.
2002 2500 4x4 6spd. 3rd Gen. Recon Cab Lights. SB single disk. HOT edge J/A. FASS 150. BHAF and Outer Wear. Silencer ring MIA. 6'' aussies. leveled. 315 procomp m/t. B&W Gooseneck Hitch. Cobra 29 w/ dual 4ft Firesticks. Cumstom Front Bumper. Soon to have 4.10s
little red cummins is offline   Reply With Quote
Old 11-04-2009, 09:21 PM   #6 (permalink)
spend a few bucks and buy a test gauge then you will know for sure. as they say 10psi is your lower limit if its even 12 at idle I gaurantee its much lower on the highway. personally I say buy a raptor 100 or 150 if you plan to break the 500hp mark.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100.
Dracozny is offline   Reply With Quote
Old 11-04-2009, 09:35 PM   #7 (permalink)
raptor 150 going in friday, and a write up. Non drawstraw install. If you cant control your urge or can swallow your pride when a pos ricer revs it up and launches out of a light next to you then dont get the juice. I had severel chances but i controlled my self and didnt punch it. But after friday its game time!!
Old 11-05-2009, 01:18 AM   #8 (permalink)
i am at 206k 99% highway miles, but i dont think i could get my foot out of it with the juice so i better get the airdog first.
Old 11-05-2009, 02:41 AM   #9 (permalink)
The raptor does not include a filter system correct?
2007 4X4 QCSB 5.9 Gutted intake, Smarty Jr, muff delete, 285's
cattlepuncher is offline   Reply With Quote
Old 11-05-2009, 07:15 AM   #10 (permalink)
GA VP...so close to 500hp
patracy's Avatar
You need a lift pump STOCK.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is offline   Reply With Quote
Old 11-05-2009, 10:20 AM   #11 (permalink)
87poweram's Avatar
you are correct
Old 11-05-2009, 10:59 AM   #12 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
The AirDog has filter system and the Raptor doesn't...
Here is a AD150...
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
