Old 11-04-2009, 07:17 PM   #1 (permalink)
rjm11590's Avatar
Edge Comp Box
I JUST GOT AN EDGE COMP BOX AND INSTALLED IT AND CANT REALLY FIGURE OUT WHY ITS NOT SMOKING LIKE THEY SAID I DID NOT BUY IT FOR SMOKE BUT WANT TO FIGURE OUT HOW TO MAKE ALL THE AGJUSTMENTS
99 DODGE 2500 CUMMINS. 5 SPEED. EDGE COMP BOX. FASS FUEL SYSTEM. 100 HP INJECTORS. 8 INCH STACK. ATS EXHAUST MANIFOLD. GREENS INTAKE. ATS INTAKE MANIFOLD. BD BANJO BOLTS. GUAGES.
rjm11590 is offline   Reply With Quote
Old 11-04-2009, 07:18 PM   #2 (permalink)
DieselRiot's Avatar
read the manual. .
adjust the low boost fueling.
02 CTD. K&N Intake. MBRP 4" Straight Pipe. Banks HighRam. Isspro Gauges. Drag Comp. FBD 100hp Sticks. BD Rad. Raptor 100. DTT VB. Draw Straw 2/DSHF Upgrade.
DieselRiot is offline   Reply With Quote
Old 11-04-2009, 07:26 PM   #3 (permalink)
rjm11590's Avatar
I Read The Manual And Where It Says The Leds Will Go Crazy Mine Just Keep Going Crazy And Do Not Stop
Old 11-04-2009, 08:53 PM   #4 (permalink)
98whitelightnin's Avatar
You have to turn the box off to get it out of the low boost fuel setting. Set the power level were you want it then hold the power button down for a couple seconds and it will flash. Set the low boost fueling were you want it and then hit the power button again and turn it off. When you turn it back on it will be set like you want it.
98 24v, 2500 sc, auto, 4x4, LO 359hp/744tq
03 2500 4d, 6speed, 4x4,
"Well oil beef hooked"
98whitelightnin is offline   Reply With Quote
Old 11-04-2009, 09:08 PM   #5 (permalink)
not to make you mad but did you tap the pump?
Kyle2001 Dodge 2500 Cummins HX40, 150 Sticks, BHAF, Fass 150, Edge Drag Comp, Dual 6 in. Miter Cuts, Gauges, Billet Input, Billet Output, ATS Triple Disk, Valve Body, Deep Dish Pan, Clutches, Shift Kit, and alot of electronics that I don't want anymore
01Grizzly is offline   Reply With Quote
Old 11-04-2009, 09:29 PM   #6 (permalink)
rjm11590's Avatar
tap the pump you mean hook the wire into the injector pump and then ground the other wire
Old 11-04-2009, 09:31 PM   #7 (permalink)
yes sounds like you know what to do and you did. i just wanted to make sure you did that. if you wouldnt of then that could be your problem.
Old 11-04-2009, 09:33 PM   #8 (permalink)
rjm11590's Avatar
but how do i no i did it to the right wire
Old 11-04-2009, 09:34 PM   #9 (permalink)
well. i didnt hook mine up i watched someone hook it up. tomorrow if you havent fixed your problem ill try to get pics of my wires and post them.
Old 11-04-2009, 09:37 PM   #10 (permalink)
rjm11590's Avatar
okay thanks a lot. Does your blow a good bit of smoke? I feel like mine doesn't for the amount of power it has.
Old 11-04-2009, 09:44 PM   #11 (permalink)
i also have injectors and it blows ungodly amounts of smoke. honestly im sick of the smoke. even on level 1 it will blow some. yeah smoke is cool for like the first week. after that you get tired of it.
Old 11-04-2009, 09:44 PM   #12 (permalink)
edgecummins5.9's Avatar
is it only a decent puff then it clears up? if so thats normal.
99 2500 sport..auto edge juice
*HOT*, 4 inch turbo back, green air intake, bd valve body.. ats 5
95 pontiac firehawk #467 6spd, enough mods to get 470hp
edgecummins5.9 is offline   Reply With Quote
