Old 11-04-2009, 01:24 PM   #13 (permalink)
kjpcummins's Avatar
Theres a few things i always do on injectors. Remove the rear bracket for pulling the engine and put it in the glove box where it belongs. I keep the valve cover on so i can lean on it and get to #5 and #6 easier. Take the lines off in two sets of three(19mm or 3/4inch). You will have to take line hold down on 5,6 off and 1 they are 8mm. 1,2,4 go together and 3,5,6 go together. Then pull the valve cover(10mm) take all 6 injector hold downs off(8mm) and pop the connector tubes part way out. Then pull the injectors using the valve cover bolt. Make sure to get the washer out. Then put it all back together. When i put them back it i put the hold downs on but dont tighten them push the tubes in and screw the lines on the tubes and vp44. Tighten the tubes then vp44 and then injector hold downs. Leave 3,4 cracked and crank over till fuel comes out. Tighten them up and start it up.
I usually do a injector swap in 30min.
2002 2500 4x4 6 speed
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Southern Diesel Extreme Injectors
kjpcummins is offline   Reply With Quote
Old 11-04-2009, 01:26 PM   #14 (permalink)
m_reynolds's Avatar
Well, you all are giving me more confidnce to just grow a pair and just try it myself....
01.5 2500 QC 4X4 6spd, DRAG COMP, KENNY DD CLUTCH, Hardened Output Shaft, RSD 5" exhaust, AEM Bruteforce, FASS 150/150, HTT Exhaust Manifold, ISSPRO (FP, boost, pyro), Thanks to James at Rollin Smoke Diesel....
m_reynolds is offline   Reply With Quote
Old 11-04-2009, 01:33 PM   #15 (permalink)
m_reynolds's Avatar
how do you go about torqueing the injector line ends to the proper torque?? Can't get a socket on there....
Old 11-04-2009, 01:38 PM   #16 (permalink)
kjpcummins's Avatar
i just tighten them down tight. you can get a crow foot wrench for a torque wrench if you wanted to torque to specs
Old 11-04-2009, 02:02 PM   #17 (permalink)
BlackedOut02's Avatar
you realy dont need a torque wrench at all to do injectors
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 11-04-2009, 02:07 PM   #18 (permalink)
Carolina Coal Rollers
stevewes2004's Avatar
heres a little writeup i posted a while back that might help ya....
24V Injector Install Tips
2002 6spd H.O. Drag Comp | DDP 200s | HE351/HT3B Twins IN PROGRESS | 5" Ex. | ISSPRO Guages | Leveled=325/60/18 | Raptor 100 | SB Hydros | SB Con OFE
http://www.gorowan.com/2002ram/
stevewes2004 is offline   Reply With Quote
The Following User Says Thank You to stevewes2004 For This Useful Post:
m_reynolds (11-04-2009)
Old 11-04-2009, 02:44 PM   #19 (permalink)
m_reynolds's Avatar
thanks for the write up man....
Old 11-04-2009, 02:48 PM   #20 (permalink)
m_reynolds's Avatar
The way i take it, by looking at stevewes2004's write-up a and pictures....you cannot see the connector/crossover tubes even with the valve cover....????
Old 11-04-2009, 02:58 PM   #21 (permalink)
razocow's Avatar
They are inside the head, only time you will see them is when you pop them out a little to remove an injecter, also check the o-rings on the connector tubes for damage or wear as they will not seal right and you will have starting issues if they are.
I have done about 8 to 10 second gen injector swaps and it gets easier every time, just take it slow, be meticulous and watch the the injector tips. You will be fine.
2000 quad cab short bed-looks stock...
B!tch Slap Of Truth
razocow is offline   Reply With Quote
Old 11-04-2009, 03:05 PM   #22 (permalink)
yup, just take your time and like razocow said, be meticulous. the last set i installed, the copper washer on the rear injector fell off when i was installing it. when i went to tighten the cap, it tightened........but i noticed the gap between it and the head was a lot smaller than the others. i was suspicious so i took the injector back out finding out that the washer fell off and was laying beside one of my valve springs
Old 11-04-2009, 03:14 PM   #23 (permalink)
bahdiesel2001's Avatar
so it wouldnt be any differnent installing 240s or 200s than stock ones and would it be different install a 66/71/14? you guys think i can do it if i take it slow?
01 2500 Reg Cab 4x4 | Built Goerend Trans | smarty | .093 tubes & lines | 4inch to 5inch stack | ISSPRO gauges | II hotrod pump | boost fooler | FASS 150 | BHAF
bahdiesel2001 is offline   Reply With Quote
Old 11-04-2009, 03:18 PM   #24 (permalink)
razocow's Avatar
^^^yes you can do it, make sure the turbo is clocked correctly first.
And nope install for all injectors is the same.
B!tch Slap Of Truth
