Old 11-03-2009, 08:54 PM   #1 (permalink)
truck wont start help
it all started with my starter being loose so i took it out cleaned it inside and out and instaled it. Now my truck wont start i check for codes, and it gave me crankshaft position sensor, i change it and it still wont start i check for codes again and it gave me nothing i check for fuel ive got plenty of fuel pressur i crack the line to make sure it was going in the motor. what else should i do or check.
thanks
2000 2500 ram sport with edge att /
4" str8 pipe just past the cab , bhaf, turbo silence ring MIA new I.P with 100 hp injectors thanks to DieselAutoPower.com
gates22 is offline   Reply With Quote
Old 11-03-2009, 09:53 PM   #2 (permalink)
MR.B's Avatar
does it click when you turn ignition. battery cables clean and good connection with wires on starter. Is the starter fuse blown. could you have damaged starter when cleaning. Starter solenoid contacts maybe.
2000 4x4 auto aem workhorse intake cfm+ s300 3rd gen track bar conversion bd steering stabilizer
4"exhaust rv275 fass 95 Adrenaline w/pulse
MR.B is offline   Reply With Quote
Old 11-03-2009, 11:11 PM   #3 (permalink)
there is a fuse inside if I remember right, I believe it is a 10A, but if you didn't disconnect your batteries chances are the fuse blew. Happened to me .If that is not it and everything looks good have the started tested.
2000/ 24V / 5 speed / custom replacement bumper / Engine just rebuilt stock/ pillar gauges/ dumped exhaust/ quad xzt+/ raptor 100
Double O Dodge is offline   Reply With Quote
Old 11-04-2009, 07:16 PM   #4 (permalink)
the truck turns over good just seems like theirs no fuel going in but theirs plenty of pressur
Old 11-04-2009, 08:03 PM   #5 (permalink)
MR.B's Avatar
Crack your ip lines on the head and see if you have fuel their while you try to start the engine. If you have good lp pressure and no fuel getting to the injectors it is not looking good for your ip.
Old 11-04-2009, 08:45 PM   #6 (permalink)
i just put in a new lp sunday and check to see its good, i crack the line at the block and its good too check all the fuses none are burnt.
Old 11-04-2009, 09:49 PM   #7 (permalink)
sstockton's Avatar
Check the cam lock wire connector, up on the fire wall above the valve cover on the driver's side. That has a tendency to get knocked for various reasons, and if it even comes a little undone, it won't start, but will exhibit exactly the same symptoms you are experiencing.
If that is fine, then start checking circuits. Something is bad and the VP isn't getting the signal that it should be.
Sean
2000 2500 Reg. Cab 4x4. Built trans, Twins, Edge drag box, Sticks, Studs, cam, Gauges, etc...
09 2500 6.7L QCLB 4x4, G56, all stock for now.
sstockton is offline   Reply With Quote
