Old 11-02-2009, 07:24 PM   #1 (permalink)
turbo questions?
i want to run a custom s300 turbo and a smaller one for a primary but i dont know what works best i heard the stock hx 35 works well or a k31 but if anyone has had luck with other combos let me know. i want a weekend sled puller and still pull my gooseneck trailer. i got and 02 cummins 6 speed manual.
thanks
02 cummins gen 2 is offline   Reply With Quote
Old 11-03-2009, 09:33 AM   #2 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
What kind of power are you looking for? We need to know hp goals before reccomending turbo sizes.
With twins the primary is the larger turbo(bottom turbo) and the secondary is the smaller(top turbo).
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 11-03-2009, 03:07 PM   #3 (permalink)
id like 500 hp maybe a lil more i got a dual disc clutch and working on some gauges now and found a good streetable cam not quite sure on a hot rod vp44 yet. i wanted to stay away from nitrous. and water if i can
Old 11-03-2009, 03:09 PM   #4 (permalink)
i def want smarty and maybe an edge comp box to stack with. never built a cummins up before so not sure on whats good for the gen 2 24v's
Old 11-03-2009, 03:13 PM   #5 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Gauges
Liftpump
Drag comp
150hp injectors
62/71/14 or a small set of twins
That should be close to 500hp and still tow ok
Cam isnt really needed @ 500hp, but would help spool and egts some.
ohiocoalrollers.com
Old 11-03-2009, 03:23 PM   #6 (permalink)
nice thanks i guess i thought i needed more to get to that 500hp mark.
Old 11-05-2009, 11:29 PM   #7 (permalink)
Diesel Auto Power
jkidd's Avatar
62/71 will be good. you will be close to 500HP with the set up Matthews8pt suggested
www.DieselAutoPower.com Call Jacob at 951-377-4844 for best pricing
SUPER DEALS on Injection pumps, Turbos, Injectors & Programmers
SUMMER SPECIAL--8% off after REBATE(up to $200 off per transaction.)
When you buy from me on Ebay and pay with paypal you will receive an 8% rebate from Ebay in 60 days.
Call me for rebate coupon code or questions.
Example: Buy VP44 for $1000- 8% Rebate of $80= $920 after rebate
jkidd is offline   Reply With Quote
Old 11-06-2009, 12:30 AM   #8 (permalink)
I am runnin a he351 over a S475 and love it.
99 2500 4X4, Edge drag comp, 150 sticks, Arp Headstuds, oringed head, Fass 150, Hotrod VP 44, he351/S475 Twins, ATS arcflow, Full billet ATS race trans D70 in the front......now
Twinguy is offline   Reply With Quote
