Old 11-05-2009, 06:01 PM   #49 (permalink)
BlackedOut02's Avatar
Originally Posted by RollinCole View Post
Is anyone a member on comp d if so you should post this up and keep us posted
i am! sorry but im still useless. maybe start a thread?
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 11-12-2009, 04:14 AM   #50 (permalink)
So I could run an quad adr and a smarty if I keep the smarty on say 6 or 8?
awdxtc is offline   Reply With Quote
Old 11-12-2009, 07:42 AM   #51 (permalink)
GA VP...so close to 500hp
patracy's Avatar
anyone got any more info on the timing ordeal with running bigger tubes and lines and such
Are you talking about it reducing the injection event timing? There's a lot of variables to that question.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is offline   Reply With Quote
Old 11-12-2009, 09:08 AM   #52 (permalink)
milesdodgeboy's Avatar
If running bigger lines and tubes reduce timing, could a person just add more timing to compensate from another timing box or is it not that simple?
01 SO with bad engine knock. replacement 24 valve should be here this week www.myspace.com/milesthehulk for my page
milesdodgeboy is offline   Reply With Quote
Old 11-12-2009, 11:16 AM   #53 (permalink)
RollinCole's Avatar
Yeah thats exactly what im saying ........If by going to tubes and lines retards the injection process couldnt you just add some timing with lets say a smarty and bring it back to where it should be
2001 2500 4X4, 47re, Adrenaline/Pulse, HTT 66, Bd Rad, BD 3 piece exhaust manifold, banks high ram, 5" strait pipe, BAMF INTAKE, Mallory comp fuel pump, billet TC, Lock up switch, suncoast VB, 0.093 tubes, level kit, 35s & 20s..
RollinCole is offline   Reply With Quote
Old 11-12-2009, 12:26 PM   #54 (permalink)
yes sir
Old 11-12-2009, 12:30 PM   #55 (permalink)
he is talking about retarding timing mechanicaly (with big lines, tubes, and injectors). so you can compensate with a little more timing electronicaly.
Old 11-12-2009, 12:33 PM   #56 (permalink)
you would need some type of fuel/timing box stacked with a smarty revo. what you would do is add a bit more timing to an even number program through the sub setting. your not going to be able to add both the box and smarty.
Old 11-12-2009, 12:46 PM   #57 (permalink)
how much more power can you expect by stacking with a smarty than by just running the quad adr by itself?
Old 11-13-2009, 05:54 PM   #58 (permalink)
not alot, it has been known to actualy hurt your dyno numbers. it helps the butt dyno though
Old 11-13-2009, 06:31 PM   #59 (permalink)
samuel64200's Avatar
So what boxes out there add extra fuel without a pump tap? Already have a fuel/timing box that taps the pump wire, and want to stack a drag comp on it as wel, but that also taps the wire. Any input on this?
2000 5spd Reg cab, Edge Drag Comp. stacked with a Bully Box, jammer 150's, boost and pyro gauges, straight 4in, Holley Blue, AFE intake, lost the sliencer ring. Need more
samuel64200 is offline   Reply With Quote
Old 11-13-2009, 06:33 PM   #60 (permalink)
RollinCole's Avatar
no need for extra chips or programmers just shoot a little nitrous and you will fine .............
