| 98.5-02 Performance Parts Discussion Discussion of Performance Parts For the 98-02 Trucks No Advertising ...NO ADVERTISING |
#13 (permalink) |
I can't remember the thread it was in but if I come across it again I'll post it here.
2000 short, 4x4, 6 speed, 12.25" DD Valair, S.O.VP44, AEM Brute Force HD, FBD 5" with 6" tip, ADRENALINE!!!, AirDog II 165, AutoMeter Cobalts, 35" Mud Grapplers on 18" Black XD Diesels |
#14 (permalink) | |
. smarty timing + more timing = ![]() the first time i was playing with my smarty/drag comp (not knowing what i was doing) i tryed an odd number . it sounded like the overhead wanted to come through the hood.the vp will advance far enough to hurt the engine. i wouldnt run more than one timing adder on my truck. (jmo)
'02 | 2WD | 2500 | NV4500 ![]() "Diesels dont run away. Diesels over speed, mechanics run away"
#15 (permalink) |
Yeah I'm not speaking from experience nor would I try it but I'm just passing on a little info I've heard a couple times.
#16 (permalink) |
Check out the last post in this thread. Has anyone stacked the adrenaline with a smarty?
#17 (permalink) |
I don't see anything about that. Post #12 is BS in my opinion. 62lbs of boost with just a stack? Not possible. That takes injectors.
'98 24v. 5 speed. 4" exhaust. Some extra air and fuel here and there... The anti-Union. |
#18 (permalink) | |
#19 (permalink) | |
and it says adrenaline on kill (everything) and smarty with timing on 4.
#20 (permalink) |
It's in this thread too. comp box and smarty?
#21 (permalink) |
hua... id like to talk to that guy. he may have big lines, and tubes also. (which retard timing) so that might be why he can run his timing that advanced. he is mechanicaly retatding his timing, so he can electronicaly advance his timing.
#22 (permalink) |
My experience when stacking timing with timing was the truck rattled like it was 20* outside and it fell on its face at about 2000 rpm.....
99 2wd cclb auto Smarty, 4"exh w/banks elbow II S.O pump DDRP 02 4wd 6spd. H.O Silver bullet (RIP) Injectors from stock to +400 Fass 150 w/draw straw, studs, wasted motor for now
#23 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
BlackedOut02 poaching my spreadsheet huh? ![]() I had made a thread about this in the past. The spreadsheet is just a work of my best knowledge and advice from others. So don't hold it as the absolute truth on the matter. If anyone has suggestions/corrections, please let me know.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#24 (permalink) |
So when everybody puts bigger tubes and lines on and they say there was no power gain is that beacause they actually retarded the timing ...so when you put the bigger lines on and then bumped the timing back up where it should be you would probably notice a power gain ????? Let me know if this is correct or just bass ackwards
2001 2500 4X4, 47re, Adrenaline/Pulse, HTT 66, Bd Rad, BD 3 piece exhaust manifold, banks high ram, 5" strait pipe, BAMF INTAKE, Mallory comp fuel pump, billet TC, Lock up switch, suncoast VB, 0.093 tubes, level kit, 35s & 20s.. |
