he351/s475 twins? - Dodge Cummins Diesel Forum
post #1 of 30 (permalink) Old 10-03-2009, 08:02 PM Thread Starter
Smourj21's Avatar
iTrader Score: 4 reviews
he351/s475 twins?
My brother has his stock he351 from his '06....would the he351 be better than my hx40 in my twins setup? and i would assume i would have to run an external wastegate. is there anything else i would need to run this? would it even be an upgrade?
02 QCSB 6 Speed|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair Tripple Disk|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"Miter|Dana60/80|4.88|True Trac|35" Toyo MT's|
Smourj21 is online now
post #2 of 30 (permalink) Old 10-03-2009, 08:31 PM
yoshi470's Avatar
isnt the he351 smaller than a hx40?
2012 Dodge Ram 2500 Laramie Longhorn
H&S XRT Pro, MBRP 4" TB Exhaust, More to come!
yoshi470 is offline
post #3 of 30 (permalink) Old 10-03-2009, 08:42 PM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
HE351 is 60/60/9.
HX40 comes in dozens of sizes.
patracy is offline
post #4 of 30 (permalink) Old 10-03-2009, 09:20 PM Thread Starter
Smourj21's Avatar
the only thing i can see is the 9cm exhaust housing will limit top end but by how much? but im sure the spool up would be great!
post #5 of 30 (permalink) Old 10-03-2009, 10:59 PM
chevota84's Avatar
Doesnt Nathan wright base his twins off of the he351?
99 Dodge 24v 5spd, tst comp/smarty, 7x.014's, super b over s475, fass 95
chevota84 is offline
post #6 of 30 (permalink) Old 10-03-2009, 11:24 PM
nbaca's Avatar
gwhammy has a he351 over a ht3b. i know that the he351 spools fast and cools good but i would think that the 9cm turbine would be restrictive but i dont know too much about that turbo.
Diesel Pros, Maximum Diesel, Diesel Auto Power, Ultimate Diesel, OTT Performance, F1, Wicked Diesel, ARP and much more
nbaca is offline
post #7 of 30 (permalink) Old 10-04-2009, 09:15 AM
Spoolup is good with this setup. I'd say it will start making boost about 300 to 400 rpm's quicker than the 40. I can have around 12 to 15 lbs. of boost at 1500 rpm's. Drill the wastegate out to 1 inch to help make up for the small exhaust housing.
95 twd,sbrc,he351-ht60 twins 215 pumped tweaked,triple disk,extremestuds,air ride rear,01.5 qcsb,fwd,he341-3b,adrenaline,five disk,custom 19.5 wheels,air ride rear,02 almost stock
gwhammy is offline
post #8 of 30 (permalink) Old 10-04-2009, 07:44 PM Thread Starter
Smourj21's Avatar
so i would be back to my stock spool up i started to light at 1400, now i light at 1700.... you dont run an external gate? i thought the he351's are electronic wastegates?
post #9 of 30 (permalink) Old 10-04-2009, 07:51 PM
Cummins6speed's Avatar
External wastegate is needed. The HE351 will spool up faster than your stock turbo did.
My truck: 06 5.9 6-speed2/28/09-470hp/980tq Sold and missed
New 2014 Mineral Gray 68RFE - Current
Cummins6speed is offline
post #10 of 30 (permalink) Old 10-04-2009, 07:54 PM Thread Starter
Smourj21's Avatar
now if i were to go to this setup with an external gate, my top end wouldn't be effected would it? cooling and power wise
post #11 of 30 (permalink) Old 10-04-2009, 08:57 PM
DieselAutoPower.com
patracy's Avatar
External gate solves that.
patracy is offline
post #12 of 30 (permalink) Old 10-04-2009, 09:32 PM
Not if you tune it correctly
