Quadzilla Adrenaline Lope Tune - Dodge Cummins Diesel Forum
post #1 of 56 (permalink) Old 09-24-2009, 07:17 AM Thread Starter
cumminsman01's Avatar
Exclamation Quadzilla Adrenaline Lope Tune
I just found a way to make my truck lope with the Quadzilla adrenaline ......i just put the torque tune in and then went to custom tuning and set everything to 0 except the pump stretch which i set at 1900...and it has a nice lope......dont think you will be able to drive with this tune but sounds really cool at a idle...mite be able to play with the parameters and make it drivable
2001 QC, SB, white, 150,000 miles, P-pumped, 160 pump benched at 455cc, .024 DV's, 4k gsk, mack rack plug, .084 lines and tubes, 8x.011's, Fletcher killer B cam, Maxspool dual valve springs with titanium keepers, ARP rocker arm studs, cat dual filter setup, S366 over S482 twins, NV4500 with 3850 dual disk and upgraded hydro's, 1 3/8" input, 7'' lift, 18x10 renegade 8's, 35-12.50 nitto mud grapplers
cumminsman01 is offline
post #2 of 56 (permalink) Old 09-24-2009, 10:01 AM
JIT
JIT's Avatar
nice... so you took the timing out and put the Can and Pump Min and Max fueling at zero? How touchy is the accel pedal?
2004 CCLB 4x4 Daily Driver
'99 P-pumped 24v "The General 01" Puller
JIT is offline
post #3 of 56 (permalink) Old 09-24-2009, 02:21 PM
puff11's Avatar
iTrader Score: 4 reviews
I have tried this, i had no luck at all, the lope was cool, but i cant even began to explain what happened wheni hit the throttle.
05 Tahoe z71 loaded, miss my noise maker
puff11 is offline
The Following User Says Thank You to puff11 For This Useful Post:
sawdustmaker (01-21-2012)
post #4 of 56 (permalink) Old 09-24-2009, 02:33 PM
APWCU's Avatar
Let's see a video!!!
96 4x4, NV4500, Valair Kevlar/Ceramic, 4k GSK,DDP 3 Injectors, 7MM DV's, HTT 62/65/13, BHAF, Studs
98 QCSB 2WD, Goerend, 63/475, 5x16, 100CC 7MM DV's 4K GSK, No Plate, Studs
APWCU is offline
post #5 of 56 (permalink) Old 09-24-2009, 02:43 PM
DieselRiot's Avatar
iTrader Score: 5 reviews
Yea def need a video
2008. EFI Live By Cummins-Tuner. Copilot. 5" TBE. S&B Intake With Scoop. GDP Mega-Flo With Boost Tube. GDP Pro-Gate. GDP CCV Delete. WCC Silencer Ring Mod. Rail Shim. Fass Ti 150. ARP 425's.
DieselRiot is offline
post #6 of 56 (permalink) Old 09-24-2009, 05:05 PM Thread Starter
yea the throttle is very touchy and its not streetable...ill try to get a video soon as possible...its raining rite now and i work nites kind of hard
post #7 of 56 (permalink) Old 09-24-2009, 06:28 PM Thread Starter
hey finally got to make a video...its from my cell so it isnt that good but you should be able to hear it....well any help as far as how to post a video would help...thanks
post #8 of 56 (permalink) Old 09-24-2009, 06:41 PM
SmokingFords's Avatar
I want to hear this.Do you have a photobucket accoount
2001 2500 6 speed BD High HP VP44 Adrenaline/SmartyRevo stack,.093 tubes DDP 200s HT64/65/14 turbo,SB street DD 3600 ,Tunnel Ram Intake,AD II,ScottieII Snow water/ meth,FBD 5in to 7in tip,35"fierce M/T Leving kit new 1997 3500 4x4
SmokingFords is offline
post #9 of 56 (permalink) Old 09-24-2009, 07:48 PM Thread Starter
no i dont but i do have a youtube account... could i post a link to go to the youtube video????
post #10 of 56 (permalink) Old 09-24-2009, 09:03 PM
DieselAutoPower.com
patracy's Avatar
What's the purpose?
patracy is offline
post #11 of 56 (permalink) Old 09-24-2009, 09:08 PM Thread Starter
hey guys i have done everything i know to do to get this video up and i cant even get it on youtube..the sound wont work..if you want to hear it pm me and ill send it to ya in a text or sumthin
post #12 of 56 (permalink) Old 09-24-2009, 09:30 PM
DieselAutoPower.com
patracy's Avatar
email me the file patracy @ gmail . com (take the spaces out)
patracy is offline
