Ganzey's Build thread - Dodge Cummins Diesel Forum
 9Likes
post #1 of 157 (permalink) Old 10-21-2015, 08:37 PM Thread Starter
ganzey's Avatar
I should have started this a long time ago, since my truck is barely even the same as it was 4 months ago, but anyways im finally getting around to it, and i will update as i do more stuff to it.
I bought this truck back in June, it was a 1 owner from a guy who was aprox. 75 years old. He maintained it meticulously, with all records for every single thing done to it from oil changes to repairs.
I purchased it with 282k miles on the clock, it was bone stock minus a 4" MBRP stainless exhaust, Edge EZ, and industrial injection VP44. Based on the service record, in the last 5k miles it had the vp44 installed, a new radiator, water pump, batteries, clutch, alternator.
My goal for this truck is somewhere in the neighborhood of 600hp over the next couple years. i bought it as a daily driver/pulling truck. i live half a mile from work so DD'ing a pulling truck isnt an issue for me LOL.
So far, ive done a bit of work to it, some of the parts ive put on it are:
Edge juice w/attitute and CTS2 monitor, with hot unlock
Fass 150
DAP 125hp vco injectors
ARP Head Studs
Crazy Carls BHAF
Scheids Street Lightning turbo (nothing special, just a 57/65/14)
Kenny's Pulling Parts Triple Disc Street Puller Clutch
2" Wheel Spacers
2.5" Leveling kit
I've done some other stuff to it while installing all that stuff, like a rear main, trans fluid change, 3rd gen rims, 35" tires, ball joints, etc
I will update as i do more stuff to it, but i doubt much will happen over this winter
Anyways, time for some pics
This is the day i brought her home
and how she sits right now
'02 2500 ECLB, 4x4, NV5600 EJWA(hot)/Smarty, Industrial Injection HO VP44, FASS 150, DAP 7x.011's, ARP Studs, 64.5/68/14 SX-E, Kenny's triple disc, 110# springs. 291k and still ticking. 526/1152 as of dec '16
ganzey is offline
The Following User Says Thank You to ganzey For This Useful Post:
TURBOLVR (10-22-2015)
post #2 of 157 (permalink) Old 10-21-2015, 10:42 PM
TFaoro's Avatar
Not sure if it's just me, but I can't see any pics....
02 QCSB, nv4500 - G56
, SB DD3250, Fass 95, TST PM3, smarty s03, Quadzilla, Industrial 62/65/12 over s475/96/1.32, Mishimoto Intercooler, DAP 7x.013 sac, O ringed, hardened exhaust seats, 104# springs, chromoly pushrods, studs, hammilton 188/220, fluidampr, .020 over ceramic marine pistons, Carl's horn, home-built traction bars
614/1215 (before twins)
05 QCLB, UDC by me, 62/s475, custom traction bars, nv5600, SB DD, Fass 150, 100% exergy, 85% over CP3, ARP studs, 115# springs, manton pushrods, S&B intake horn 808/1319
TFaoro is offline
post #3 of 157 (permalink) Old 10-22-2015, 12:48 AM
Marq92's Avatar
Pics aren't working for me either.
Mike
2001 QCLB 3500 47RE 4x4 3.54 Carli 3.0 TheRetroShop Projector Retrofit VLEDS
Marq92 is offline
post #4 of 157 (permalink) Old 10-22-2015, 07:52 AM Thread Starter
ganzey's Avatar
fixed the pictures
ganzey is offline
post #5 of 157 (permalink) Old 10-22-2015, 09:59 AM
Nice looking truck! How quickly does the turbo spool? Does it keep the EGT's in check with those injectors?
2002 QCLB 4x4.Auto.4.10 gears.Edge JWA.Garmon's Diesel Performance Stage 2 Transmission.FASS 95 Platinum & FASS 5/8" pick-up.DAP reman VP44.Rebuilt HX35W with billet compressor wheel and port matched turbine housing.4" Banks Monster Exhaust.
Piperpilot3tk is offline
post #6 of 157 (permalink) Old 10-22-2015, 10:05 AM Thread Starter
ganzey's Avatar
Thanks! it spools almost as quick as stock, and highest egt's ive seen are around 1400 even while pulling a sled. cruising at 65 they stay around 750-850. highest boost ive seen is 43 lb's
ganzey is offline
post #7 of 157 (permalink) Old 10-22-2015, 11:55 AM
Hey how do you like the 2" spacers on the truck with the 3rd gens?i have 3rd gens on mine with 35-12.50 tires kinda interested in how the 2" spacers look cant notice it too much in the pics though
01_USACummins is offline
post #8 of 157 (permalink) Old 10-22-2015, 11:57 AM
gh0stman's Avatar
Hows that triple disc feel on the street?
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is online now
post #9 of 157 (permalink) Old 10-22-2015, 11:57 AM
I looked at the Scheid web site and there isn't much info for that turbo. Is that basically the same S300 that BD calls a Super B? I was considering a Super B if I go with some slightly larger injectors.
post #10 of 157 (permalink) Old 10-22-2015, 12:31 PM Thread Starter
ganzey's Avatar
i love em, ill try to find some more pics of how they sit, they do stick out a bit, but without them the tires rubbed on the upper control arm, then after i put them on the tires rubbed the fender, so in came the leveling kit
Its a little grabby taking off, and nearly impossible to put it into 1st or reverse when its running, but ive been told it may get better when its broken in, only 75 miles on it so far, but man this thing grips like you wouldn't believe. only noticeable gear rollover is in 6th gear under 50mph
from looking at specs, yes they are basically the same turbo, except this one is may have a different comp cover, all it says on it is 'schwitzer', unlike the super B's
ganzey is offline
post #11 of 157 (permalink) Old 10-22-2015, 12:31 PM
jlbayes's Avatar
its the same s300g that just about everyone sells.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
The Following User Says Thank You to jlbayes For This Useful Post:
post #12 of 157 (permalink) Old 10-22-2015, 05:02 PM
zacjohnson's Avatar
Except at a higher price
02 qcsb, 4x4 auto, edge juice with attitude, 5" mbrp straight pipe exhaust, pusher intake, fass 150, isspro gauges, bd rad box, 110lb springs, hd pushrods, arp headstuds, 7x.11 dap injectors, 62 fmw n/g
zacjohnson is offline
