Alright guys this is going to be the truck in my sig...I wanna put twin turbos on it and I want to know what I should do and what size turbos I will need for this truck. First off it is going to have 6" turbo miter cut stacks on it for exhaust, Hot rod vp44, smarty stacked with edge juice with attitude, Fass 150 lift pump, afe intercooler + polished intercooler pipes, full A-pillar gauge pod, cam, headstuds, cfm+ intake manifold, performance diesel coated 3-piece exhaust manifold, 200hp injectors, water methanol injection, propane, 50 shot of nos, and twin turbos. And I want to know if an AFE stage 2 intake will work with the twins if I buy one and put on the truck now? As far as the twins I'm undecided if I should go home made or super phat shaft, or aurora, or another brand. And I was wondering if I will need a custom setup...as I'm shooting for 850-1000hp. And I want to really roal the coal...
2002 24V CUMMINS QCSB NV4500,4x4,Southbend,CPP traction bars,SMARTY,HRVP44,HX35,ARP studs,Airdog 165,FP,EGT,BOOST..p7100 pumped soon..1995 12 valve going into a blue monster
first i wouldnt do the propane, second if your going to want that kind of power your going to need alot bigger sticks possibly a p-pump and or some more nitrous. as for the turbos if your going to stay with your power goal i would go with a 66 over an s480
I would go way bigger than 200hp sticks with all that.
Watch out for the CFM manifolds I've seen them blow up under high boost.
I wouldn't waste the money on a stage 2 intake because you will take it right out and use just a filter with twins.
Your going to have to use a monster pump if you want 800hp.
You will also probably have a hard time getting it there. I only know of a few 24v's with that much horsepower.
That's all I have for now.
If a Prius drifts is it called the
Electric Slide?
64/71/14 over and S480, big injectors 240+hp, a fueling and timing box of your choice and lots of nitrous, and posibly one of these fancy new VP44's. You can do 700+hp on an SO vp44 but it's not easy. I would recommend P-pump if you are already throwing that much $$$ at it. What do you plan on for the tranny?
__________________ 94 rcsb 2wd, Ported head, HD181/210, big shiny pushrods, valve springs, TRE 47rh, DPC converter, Cheetah shifter, caltrac's, AD150, stainless diesel manifold, Stainless diesel twins, CPP 7x.012" injectors, detroit locker, and..........
if i were you i would do A LOT of research before buying anything
08 Mega cab 6" lift with long arm kit, 2" leveling, flares, B/M, DPF delete, By-pass oil filter, cold air intake
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
