Old 07-02-2009, 10:34 AM   #1 (permalink)
1/4 mile times
I was wondering if you could get a 6 or 5-speed to get to about low 11s or high 10s? And if you had the same truck with a manuel in it and put a automatic in, what would be the difference in times?
02 4x4 Auto, Stage 1 Jammers, BHAF, New VP44 pump, Fuel pressure gauge, Superchips Flashpaq & Straight Pipe
Codgedodger is offline   Reply With Quote
Old 07-02-2009, 10:48 AM   #2 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
It takes a LOT of power to get low 11s in trucks like ours, even if you could shift FAST I dont think the 5 and 6speed trannys would handle the power.
I know a guy with an auto truck, dyno'd about 730hp on the bottle and runs 11.80s pretty consistant on a good track. just a reference for ya....
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 07-02-2009, 12:09 PM   #3 (permalink)
BlackedOut02's Avatar
like mathew8pt said, its going to take a 800+hp truck to crack low 11's. (i have looked into it a little)
the reason why manulas are slower, is they shift slower, and they loose boost between shifts. the best solution i found (so far) is a procharger/turbo setup. the procharger should help prevent you from loosing boost between shifts. and doing 3ed gear boosted launches should help you too.
then the problem becomes holding it together
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
Old 07-02-2009, 02:07 PM   #4 (permalink)
okish's Avatar
Hes probably talking about getting in to the 10's in the 1/8th.
89 D250- G360, Bombed VE, BHAF, 4" turbo back, 60mm h1c/e hybrid, 16cm3 pdr housing, 2.5 inch crossover, dennyt pin, piston lift pump.
02 2500 QC LB 4x4 A/T AD100, NV241DHD, Quad Adrenaline, BHAF, FBD VP44, 7x.010 +.010 lift, 5" turbo back, 62/68/14 s300, dtt super single, FBD VB, billet accumulator and apply pistons, 4.2 apply lever...
Foreign Car Center, Vallejo, CA
okish is offline   Reply With Quote
Old 07-02-2009, 02:14 PM   #5 (permalink)
yoshi470's Avatar
thats why it says 1/4 mile times for the title???
2001 Dodge 2500 6spd, to much money and still not fast enough! HTT, Valair, DDP powered!
yoshi470 is offline   Reply With Quote
Old 07-02-2009, 05:43 PM   #6 (permalink)
murphy41's Avatar
Guy on pinks all out was runnin low to mid 11's with a 5-speed consistantly .......
97' 12v... II PhatShaft 71/74/16, II Dragon Flow 5x.018's, #100 plate, DDP .024 DV's, 4K GSK, 60# Springs,5" S&B Intake, 4" MBRP, Air Dog 150, & NOS..
Special Thanks to Kortney, And Toxic Diesel (546hp) 11/10/09
murphy41 is offline   Reply With Quote
Old 07-02-2009, 06:39 PM   #7 (permalink)
talking about that black, 12v, single cab, 4x4 with a single stack?? he made it to the finial 4 in ATL i think??
Old 07-02-2009, 06:54 PM   #8 (permalink)
Justin Price's Avatar
to have a truck that can run that fast your gonna be going thru transmissions like crazy. the problem is you can't do much upgrading to the internals of these transmissions. basically just input and output shaft
01 3500, 5 spd, edge juice w/attitude w/hot unlock, hx40/ht3b twins, bd intercooler boots, bd short shift kit, 250hp sticks, o-ringed head, pdi 3 piece manifold, 110 valve springs, billet push rods, arp studs, airdog 150. 517/979 on october 3rd 2009
Justin Price is online now   Reply With Quote
Old 07-02-2009, 08:00 PM   #9 (permalink)
Okay, thanks for the responses.
What does it take to get to 800hp? I know that as far as injectors go, you can get to 250hp injectors but what does it take to hold 800hp in the tranny.
Old 07-02-2009, 08:10 PM   #10 (permalink)
sledneck696's Avatar
ask Graphic Man, he will be there this summer
2001 q-cab 4x4 sport 6 speed swap, 3600SB clutch, SB hydraulics, B1/B2 twins, Mach 7's, Edge juice w hot, fire rings, ARP's, Rips Boot Kit, airdog, BD short shift, Hurst shifter, Dipricol Optix boost gauges, subs, dvd, Fabtech 5.5" dual shock lift, dual shock steering stabilizer, 5" curved top stacks
sledneck696 is offline   Reply With Quote
Old 07-02-2009, 09:04 PM   #11 (permalink)
murphy41's Avatar
Yes !!
Old 07-02-2009, 10:02 PM   #12 (permalink)
Yes !!
that was awsome!
i could of sworn that was an auto... but if it is a 5 speed, then there is hope!!
