Old 06-08-2009, 02:40 AM   #25 (permalink)
burtonboarder's Avatar
One question through what do you use for a shut off on those pumps? Is there a way to rig up the 12v shut-off solenoid in a 24v? [/quote]
yes. you wire up a solenoid. one cable from the battery into the solenoid, one into the white wire from the solenoid, a wire from the solenoid on the starter to the small post on the solenoid for the shut-off, a key-on power to the red wire, and ground the black wire. damn that sounds complicated. pm me if you need a picture.
1967 Ford 4x4 with a twelve valve
burtonboarder is offline   Reply With Quote
Old 06-08-2009, 03:02 AM   #26 (permalink)
Explosives87's Avatar
Thanks for the pics makes me want to do a p pump swap even more. Whos cam are you going to run?
01 2500 QCLB Straight pipe,6 spd,Stock for now
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd amendment
Explosives87 is online now   Reply With Quote
Old 06-08-2009, 08:25 AM   #27 (permalink)
01Cummins24v's Avatar
yes. you wire up a solenoid. one cable from the battery into the solenoid, one into the white wire from the solenoid, a wire from the solenoid on the starter to the small post on the solenoid for the shut-off, a key-on power to the red wire, and ground the black wire. damn that sounds complicated. pm me if you need a picture.[/quote]
Sweet I always wondered about that... Man I want to swap now just need some money lol...
1997 4x4, 5spd, Valair 13" single disk, 4k GSK, BHAF, #100 Plate, AFC tweaked, 6" Mitre Cut Stack, Autometer Gauges, KDP tabbed, leveling kit. 35's, Moto Metals
Ohio Coal Rollers
01Cummins24v is offline   Reply With Quote
Old 06-08-2009, 09:06 AM   #28 (permalink)
has anyone figured out what this will cost in parts?
01 1ton
dm1tonram is offline   Reply With Quote
Old 06-08-2009, 09:07 AM   #29 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Originally Posted by Explosives87 View Post
Thanks for the pics makes me want to to a p pump swap even more. Whos cam are you going to run?
Maxspool 2.5 cam with bolt on gear
Thanks for all the compliments guys
2000 QCSB, built auto, P7100, 131 dvs, 4gsk, .084 lines and tubes, 7 x .014s, 22*s, maxspool 2.5 cam, 110# valve springs, 125ft lb head bolts, 66/74/.9
ohiocoalrollers.com
mathews8pt is offline   Reply With Quote
Old 06-08-2009, 09:09 AM   #30 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
I will list all the parts needed and what the cost for everything was when i get time and the rest of the parts.
Il have time later this week considering I have to go to michigan for training for the next 3 days
ohiocoalrollers.com
Old 06-08-2009, 09:24 AM   #31 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Just noticed this was a sticky, thanks guys i think it will really help other guys that are thinking of doing this
ohiocoalrollers.com
Old 06-08-2009, 09:34 AM   #32 (permalink)
Super Administrator
BBRam's Avatar
Your welcome. And Thank you, Great write up!
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 06-08-2009, 11:51 AM   #33 (permalink)
cmns2500's Avatar
so, what are ya gonna do when ya first turn the key on and the IP lights up like a christmas tree w/ all the CEL's and what not?
also, do you HAVE to change cams?
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link
02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up...
Old 06-08-2009, 11:56 AM   #34 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Il let you know what codes i get since it will be unplugged, probably not much more than what i have now, but the truck will run Plus my egt gauge is on the steering column and i cant even see the check engine light while im driving it anyhow
You dont have to change the cam if you are not running a stock 12v lift pump on the block. You do have to pull the cam to get the gear case off, so thats why most put an aftermarket cam in while they have it apart.
ohiocoalrollers.com
Old 06-08-2009, 12:11 PM   #35 (permalink)
booost yooo
mahdey's Avatar
oh no, its a sticky now...great.
where are you doing this, i want to stop by and poke at it.
2000 2500 QCLB AT, 4x4. Auto to manual to auto swap, Goerend Transmission,150hp sticks, 5" Exhuast, AD 150, ADR/Pulse, twins in the works.
Thanks to Coaltrain Diesel Performance, Rollin Smoke Diesel
Ohio Coal Rollers
mahdey is offline   Reply With Quote
Old 06-08-2009, 12:45 PM   #36 (permalink)
TECH SPECIALIST
mathews8pt's Avatar
Im gonna be fielding questions about this all the time now
Il be working on it this weekend if you wanna come by, its at my parents in cardington
ohiocoalrollers.com
