Tyler's Build Thread - Page 70 - Dodge Cummins Diesel Forum
 11Likes
post #829 of 958 (permalink) Old 02-17-2017, 12:02 PM
thatguy69's Avatar
Originally Posted by thatguy69 View Post
7x13 sacs
Sent from my SM-N910V using Tapatalk
You beat me to it. Your not having any problems running without a coolant bypass?
Black.1999.ECLB4x4.118k.BHAF.Edge Juice w/ Attitude.Fass Ti150.Full Manual Georend 47RE. DAP 150 stix.II 62/65/14. ARP Studs
thatguy69 is online now
post #830 of 958 (permalink) Old 02-17-2017, 12:08 PM Thread Starter
TFaoro's Avatar
The freeze plugs inside the head are stuck in pretty good. It looks like the machine shop used a chisel to "mark" the edges in 4 spots on each plug. I'm not too worried about those. The rear plug is replaced with a billet tapped plug. Funny you bring that up because I'm considering making one while I've got the turbos out and I can reach that rear plug.
For those pondering the EGT issue, I forgot to mention I changed from a 75/83/1.1 to a 75/96/1.32 on the primary.
02 QCSB, nv4500 - G56
, SB DD3250, Fass 95, TST PM3, smarty s03, Quadzilla, Industrial 62/65/12 over s475/96/1.32, Mishimoto Intercooler, DAP 7x.013 sac, O ringed, hardened exhaust seats, 104# springs, chromoly pushrods, studs, hammilton 188/220, fluidampr, .020 over ceramic marine pistons, Carl's horn, home-built traction bars
614/1215 (before twins)
05 QCLB, UDC by me, 62/s475, custom traction bars, nv5600, SB DD, Fass 150, 100% exergy, 85% over CP3, ARP studs, 115# springs, manton pushrods, S&B intake horn 808/1319
TFaoro is offline
post #831 of 958 (permalink) Old 02-17-2017, 12:12 PM
thatguy69's Avatar
I'm waiting on the primary to get here but I'll be running 62/65/14, 475/96/1.1 and 7x14s. Maybe I should of went with the 7x13s
post #832 of 958 (permalink) Old 02-17-2017, 12:22 PM Thread Starter
TFaoro's Avatar
They will both outflow the VP. You'll just have more idle haze.
TFaoro is offline
post #833 of 958 (permalink) Old 02-17-2017, 08:36 PM
thatguy69's Avatar
i just ordered them from dap yesterday,called and changed them to 7x13's.luckily they hadnt sent them out yet
Sent from my SM-T550 using Tapatalk
post #834 of 958 (permalink) Old 02-17-2017, 08:46 PM
Cummins_freak777's Avatar
So did you have more of an EGT problem before or after you swapped the primary? Seems like it should be a little cooler now that theres less restriction. Wonder if swapping to a 14cm on the secondary would help any. Has anyone ever ran a t4 housing on their secondary on a vp44 truck? Just curious id say it would probably be too laggy doing that.
02 6 speed QCSB, leveled, cowl hood, 6000K HIDs, drag comp, DAP 7x.010 SAC sticks, SB 3250 dd clutch, 5in exhaust, AFE intake, Fass 150, glowshift (EGT,boost,FP), chrome 20x14 xd riots, 33x12.5x20 toyo m/t, follow me on instagram for truck pics @pr0ject_blue
Cummins_freak777 is offline
post #835 of 958 (permalink) Old 02-20-2017, 01:50 PM
jlbayes's Avatar
You have no control of the injector like you do with a common rail and a "low" pressure injection pump compared to the cr.
Jacob, "strictly business" 01 grumpy sob, Calibrated Addiction, Infinite Performance, Farrell Diesel, 97 rclb
jlbayes is offline
The Following User Says Thank You to jlbayes For This Useful Post:
jmd025 (02-20-2017)
post #836 of 958 (permalink) Old 02-21-2017, 02:04 PM Thread Starter
TFaoro's Avatar
Seems like they're slightly lower with the primary. I can let it have more power with the egts staying cool, but max effort is always super hot.
I've wanted to swap in a 14cm housing, but they're over $500 for just the housing. Finding a used one hasn't worked so well either. I won't go to a T4. I like quick spool!
This weekend I remade the mounting bracket for the primary turbo this weekend, cleaned up both exhaust housings and painted them, and re-shined my secondary compressor housing.
TFaoro is offline
post #837 of 958 (permalink) Old 02-21-2017, 08:15 PM
Mule Barn Proprietor
jmd025's Avatar
iTrader Score: 9 reviews
Why did you "remake"the bracket ?
This Machine Thrills Fascists
No more Cummings
jmd025 is offline
post #838 of 958 (permalink) Old 02-21-2017, 09:14 PM
I gotcha. I figured a 14cm housing would be within reason on a vp44 but Ive never heard of someone using a t4 in a twin setup on a vp44. Im sure it could work on a high flowing 12v or p pump 24v.
Are you planning on polishing the primary charger housing while you have it apart?
post #839 of 958 (permalink) Old 02-21-2017, 09:49 PM
thatguy69's Avatar
I have a 14 housing on mine, our setups are identical except I have a 47re. I'll be interested to see how it runs once I get it all put together but with the 62/65/14 as a single it was very easy to get under the turbo when locking the converter
post #840 of 958 (permalink) Old 02-21-2017, 10:58 PM Thread Starter
TFaoro's Avatar
As you can see the one I got with the kit was scabbed together pretty bad. The vertical piece on the left was a single piece, but it wasn't cut straight. The vertical piece on the right was scabbed onto it for some reason. It didn't make it any stronger though, so I'm not sure what its purpose was. It was also made to use the spacers on the stock exhaust manifold. I didn't want those on there with the new stainless manifold.
I'm sure it is within reason for some, but I can't justify the cost of a new one.
No, I'm not. It's not worth the work considering you can't see it without actually looking for it. It is painted though so it goes well with the piping / secondary.
That'll be interesting to see! Post up when you get it together.
I ordered a manifold, gaskets, mounting bolts, paid for the injectors to be rebuilt, and bought a rebuild kit for the 75. I'll also be building a coolant bypass while everything is apart. I'm working on figuring out what pressure I need a valve to be at. More to come on that later.
TFaoro is offline
