Old 05-11-2009, 01:08 PM   #25 (permalink)
Thismachinekillsfascists
jmd025's Avatar
Originally Posted by skneeland View Post
my VA box plugs into the MAP sensor (on my 98), i would assume it does boost fooling.
also one other thing to take into consideration is..all things being equal if you throw more timing into the mix (which is what the VA box is doing) you generally see less boost
less boost doesnt actually mean less hp, so ask yourself why do i think i need more boost:
are the EGTs too high?
is there alot of smoke?
if you answered no, then you dont need more boost....
Great Post!
Louisiana Coalrollers!
VE-P-VP
My trucks are modded.
jmd025 is offline   Reply With Quote
Old 05-11-2009, 01:12 PM   #26 (permalink)
jmd025's Avatar
Originally Posted by duddy4 View Post
the boost elbow is the copper fitting that came with juice w/ att correct? if so than it's installed. shouldn't i be able to see more boost?
I my opinion, you should be able to push your stock turbo WAY out of its map with the 150s and Juice. You are getting the boost numbers from the Juice? I don't know why you are only seeing 27 psi.
I think you should be seeing A LOT more boost than that with your setup, BUT it would not be a good thing at all. You, like me, need a better turbo to use the fuel you are capable of.
VE-P-VP
Old 05-12-2009, 03:32 PM   #27 (permalink)
ckassen's Avatar
I have the stock HX35, with the standard wastegate my psi was hitting 25-26, I unhooked the wastegate and am now hitting 34-35psi(i remember hitting 36 once), is this maximizing the use of the turbo or should I hook up the wastegate with a boost elbow to open at 34psi so that there is less restrictive exhaust flow?
Or would the boost just go down immediately after the wastegate opens?
2002, 2500, q-cab, 2wd, short bed, HO, 6 speed, Super B Special, DDP 200's, Pulse/Adrenaline, Valair Ceramic Single, Airdog 150, AFE CAI, headbolts torqued to 130ft/lbs.....
Ran a 13.98 at 104 with a 2.6 60ft at lots of wheelspin
ckassen is offline   Reply With Quote
Old 05-12-2009, 03:40 PM   #28 (permalink)
jmd025's Avatar
Sounds like you are fine right where you are
VE-P-VP
Old 05-12-2009, 03:50 PM   #29 (permalink)
Lonno's Avatar
Anybody know if my Quadzilla Afrenaline w/ Pulse has a built in MAP fooler or do I need to get one separately???
Thanks,
Dave
2001 Quad cab 4X4, Airdog 100, 4" TB exhuast, BHAF, Stage 4 Jammers, Triple disc conv., valvebody, Jhooked, Quadzilla Adrenaline w/Pulse Runnin BETA 3000.GM 1 ton drum cylinders, Leveled on 35's........"Wandering" down the road.
Lonno is online now   Reply With Quote
Old 05-12-2009, 04:02 PM   #30 (permalink)
jmd025's Avatar
Thanks,
Dave
Adrenaline Boost Fools
VE-P-VP
Old 05-12-2009, 04:16 PM   #31 (permalink)
Lonno's Avatar
So then I need to J hook the wastegate?? Is there a write up on this because I can't get over 22#'s?
Dave
Old 05-12-2009, 04:57 PM   #32 (permalink)
jmd025's Avatar
Dave
J-Hook Assembly
http://www.tstproducts.com/pdffiles/PMInstr6.pdf Page 3, halfway down page, pics of (left to right) boost elbow on HX35, stock metal boost line on HY35, and HY35 with J hook installed. Also, installation intsructions for boost elbows and J hooks above and below pics!
The search forum function is also VERY helpful!!
VE-P-VP
Old 05-12-2009, 05:09 PM   #33 (permalink)
Lonno's Avatar
I read the whole thread. Not sure what you are referring to but thanks for the links.
Old 05-12-2009, 05:26 PM   #34 (permalink)
jmd025's Avatar
Sorry Lonno, I guess I didn't explain it well enough. You have to have control of your wastegate to make more boost than stock, This is assuming you have higher than stock fueling. The way to control your wastegate, for your situation, is by installing a J-hook
VE-P-VP
Old 05-12-2009, 05:28 PM   #35 (permalink)
Originally Posted by patracy View Post
Could we make an addendum?
Boost pressure is not indicative of cooling performance or power. Turbochargers have what is called a map. This states the efficiency of it's design. There is a finite amount of flow a turbocharger can produce without causing "hot air". Hot air is the excessive heating of the charge air. Once a turbocharger begins to exceed it's efficiency map, it increases the hot air. Hot air actually will begin to impede performance. Another portion of the map is the drive pressure and ratios. You may be able to fuel an HX35 into overspin to 50+ psi. But the hot air produced coupled with the extreme drive pressures tax the engine. Simply put, more pressure isn't "good". It needs to be done in moderation.
Generally accepted safe numbers for the HY/HX-35's are as follows:
HY35's are good to 32psi, and will begin to overspin at 35psi.
HX35's are good to 35psi, and will begin to overspin at 37psi.
Well put
Weldon Spring, MO
'08 2500 Mega cab SXT. 6 auto. Airraid, EGR delete.
'02 2500 HO 6 manual. Magna Flow 4", Airraid, MAP voltage manipulation.
Wies is offline   Reply With Quote
Old 05-12-2009, 09:43 PM   #36 (permalink)
red_2500_4x4's Avatar
awesome thread. Here's my question. i have everything in my signature plus an elbow and i can only on average see 25 psi. once i've hit 30 but that never happens on a regular basis. i'm open to any suggestions. possible boost leak?
02 Flame Red Cummins: FASS 150, Glowshift Gauges, 35x12.50 Nitto Terra Grapplers, AEM Bruteforce HD intake, HX 40, 4" TBE to a sinlge 5" miter and Quadzilla Adrenaline/Pulse
red_2500_4x4 is offline   Reply With Quote
