Old 05-07-2009, 08:29 PM   #13 (permalink)
s.k.i.t.s.o's Avatar
thanks man, oh and nice right up
white 02 quadcab 4x4 5sp/ ind. inj. hrvp/ rv275's/ airdog 150/ isspro gauges: pyro, fuel, boost/ valair kevlar-ceramic clutch/ silencer ring mia./ BHAF/ straight piped/ boost elbow/ custom shifter/edge comp hot/ 2-stroke oil SOLD ITnow have a 98 1500
s.k.i.t.s.o is offline   Reply With Quote
Old 05-08-2009, 03:22 PM   #14 (permalink)
farmboy458's Avatar
thanks for the input man easy to follow
99 24v extended cab..fass fuel system..4inch exhaust turbo back..k&n cold air intake....edge comp box...80 rear with detroit tru-trac/auto meter phantom 2 pyro and boost guage/sout bend 3250 12cb /new nv4500\ddp110's\431hp and 986tq on hurckstorf dyno http://i49.photobucket.com/albums/f2...image001-6.gif
farmboy458 is online now   Reply With Quote
Old 05-09-2009, 12:16 AM   #15 (permalink)
Tried this and still no luck.
Ok, Here is my problem. I have an 01 with an auto and changed out the turbo for a HX35. I put in a Van Aaken 65hp box and boost elbow on the turbo. The truck doesn't go beyond 22lbs of boost. Thats with the elbow full adjusted. What Is going wrong?
SofaKing is offline   Reply With Quote
Old 05-09-2009, 02:00 AM   #16 (permalink)
02 Cummins
Thanks to both Josh and Patracy for the simplified explanation!
02 qc sb 6spd 4whlr mostlystock, BD flow max fuel pump,low fuel pressure warning light, 4"exhaust, boost elbow, jacobs exhaust brake:
curly02 is offline   Reply With Quote
Old 05-09-2009, 11:57 AM   #17 (permalink)
nbaca's Avatar
i am not sure about the van aiken box but it would need to do boost fooling also to get your desired boost. hopefully someone will chime in that knows about this box. i wanna say that it does not do boost fooling.
2001/NV5600/TWINS/200hp STICKS/ARP STUDS/110lb SPRINGS/QUAD ADRENALINE/RAPTOR 150/ISSPRO GAUGES/DEVILS OWN METH INJECTION/5in EXHAUST/SBC3600 DD/SBC HYDROS/IN SEARCH OF 600HP AND BUILT WITH DIESEL AUTO POWER PRODUCTShttp://www.southwestcoalrollers.com/
nbaca is offline   Reply With Quote
Old 05-09-2009, 12:33 PM   #18 (permalink)
duddy4's Avatar
what about adjusting the rod on the wastgate, I'm only getting 27 psi with my setup will this help?? not sure if i understand i cannot j hook my wastgate??
99 4x4 guadcab need 4 powered by farm boy's diesel BHAF AMSOIL 4510, 5IN fbd straight pipe, fass 150, FBD 150 sticks, edge juice with attitude HOT, 18x9 rockstars with 33x12.5 toyo mt 14.7@90mph
duddy4 is offline   Reply With Quote
Old 05-10-2009, 12:03 AM   #19 (permalink)
Thismachinekillsfascists
jmd025's Avatar
Why couldn't you J-hook your wastegate? If you have a HY35 then yes you could.
You should see plenty more boost than your stock turbo will want with your setup once you get the wastegate right.
EDIT: I see you have a 99 model, which "should" have a HX35, so you would need a boost elbow, not a j - hook!
Louisiana Coalrollers!
VE-P-VP
My trucks are modded.
jmd025 is offline   Reply With Quote
Old 05-10-2009, 12:08 AM   #20 (permalink)
jmd025's Avatar
I don't have any experience with the Van Aaken's, so I can't really help ya there.
If you have the allen screw in the boost elbow screwed all the way in, and still can't get over 22 psi, then maybe the VA doesn't boost fool and the ECM is defueling. OR the wastegate acuator rod is incorrectly adjusted. I never had to adjust my rod.
VE-P-VP
Old 05-11-2009, 12:35 AM   #21 (permalink)
Checked the Programmer
Ok I checked the box the programmer came in and it's supposed to have a built in boost delimiter. So my next question is what's involved with adjusting the wastegate rod
01 2500 quad cab auto 4x4, hx35 swapped in w/boost elbow, Jammer stage 1, S&B intake, 4" S.S. HOGZ exhaust, Van Aaken 60hp, DSS, 2.5 Carrier Springs, AGR steering box, Isspro gauges: PYRO-BOOST-FUEL PRESSURE, AirDog 150, JDM Tails 315/70/17
Old 05-11-2009, 06:38 AM   #22 (permalink)
GA VP...so close to 500hp
patracy's Avatar
I believe the VA box is a timing box, not fuel.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is offline   Reply With Quote
Old 05-11-2009, 12:38 PM   #23 (permalink)
duddy4's Avatar
the boost elbow is the copper fitting that came with juice w/ att correct? if so than it's installed. shouldn't i be able to see more boost?
Old 05-11-2009, 12:49 PM   #24 (permalink)
skneeland's Avatar
my VA box plugs into the MAP sensor (on my 98), i would assume it does boost fooling.
also one other thing to take into consideration is..all things being equal if you throw more timing into the mix (which is what the VA box is doing) you generally see less boost
less boost doesnt actually mean less hp, so ask yourself why do i think i need more boost:
are the EGTs too high?
is there alot of smoke?
if you answered no, then you dont need more boost....
06 Laramie auto,5" lift,35"ToyoMT/18"AR wolverines, airbags,ladder bars,Smarty,TST,DTT billet trans,MPItwins, HTTman, AFE, ARPstuds, 5"pipe, CFMintake, 2micFuel system & more... 98.5 QcSb sport 5spd,3" lift,35"ToyoMT,VA box,60hp stix
skneeland is offline   Reply With Quote
