Torque Converter Lockup - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 02-13-2009, 12:05 PM Thread Starter
What is a torque converter lockup and how do I do it?
2001 Dodge Ram 2500 2WD Auto 5.9L Cummins: Raptor 150 w/ full 1/2" line kit, DTT Sump, Hypertech 3 Stage programmer, BD Boost Fooler, blocked wastegate, BHAF, 5" RSD exhaust, ISSPRO EGT, boost and fuel pressure gauges.
2001 Hypertech Cummins is offline
post #2 of 23 (permalink) Old 02-13-2009, 02:07 PM
Horse Power JUNKIE
Nitrous340's Avatar
You have a lock-up style torque converter, at a certian speed it will lock up and provide direct power just like a clutch in a manual truck. The factory setting is any where between 35-45 depending on what gears you have. The shifting pattern is 1st 2nd 3rd... than lock up and then 4th. You can get aftermarket controllers to adjust the speed at which you get lock up to any speed from 18mph up.
The lock up or "mystery" switch is just a switch to ground the tq circuit to achive lock up. But in 99 or 2000 and newer it will set off a check engine light. You have to pay attention though with a switch like that cuase the trany will NOT down shift with tq locked. Also if you try to come to a stop it will kill the motor just like a manual truck not pushing in the clutch.
Send me your email and I can send you instruction on how to wire one up with out the CEL coming on.
2001 2500 4x4
PhatShaft62
, DDP 150, TST Comp/Smarty, S&B Intake, PSC brace, Hamilton 110 springs, Fluidamper, ARP studs, 4" straight pipe, AIRDOG 150, BD black FP, Suncoast billet trans, 3-disc converter, 3rd Gen Brakes, Thuren 3rd Gen track bar. RIP grandpa "Red" 10-11-08
WAGNAAR MOTORSPORTS
Nitrous340 is offline
The Following User Says Thank You to Nitrous340 For This Useful Post:
jlfp73 (12-02-2010)
post #3 of 23 (permalink) Old 02-16-2009, 03:16 PM
dfairchild19's Avatar
Ive been meaning to do this, mind sending it to me too?
afrogs19df@aol.com
thanks,
derek
2001 4x4 QC short bed, afe, 5" FBD straight, Edge J/A, Airdog 150, Goerend tranny, FBD injectors, o-rings, arp studs, htt 62/71/13ss
OHIO COAL ROLLERS
dfairchild19 is offline
post #4 of 23 (permalink) Old 02-16-2009, 03:21 PM
Got P7100?
mathews8pt's Avatar
iTrader Score: 9 reviews
Its very hard on a stock tranny when you lug it good with the tc locked. just remember that when your blowin all that smoke
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s364/s480, tranmission built by me, AD150
11.23 @ 121mph
mathews8pt is offline
post #5 of 23 (permalink) Old 03-13-2009, 10:32 PM
tweeter270's Avatar
Hey kind of interested in this,, i have an 05 auto ,, please e-mail me instructions, tweeter270@yahoo.com thank you
2005 Dodge Cummins 4x4 2500 AUTO, black, Bully Dog Tripple Dog, edge juice w/ attitude,Diablo power puck, , K&N filter, 4 inch strait pipe with 5 inch tip, 51 gallon fuel tank/tool box combo, dual air horns, front and rear RANCH HAND bumpers
tweeter270 is offline
post #6 of 23 (permalink) Old 03-14-2009, 12:18 AM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
Actually I did a write up here about it.
TC switch howto (with pics)
patracy is offline
The Following User Says Thank You to patracy For This Useful Post:
Swish98 (09-18-2013)
post #7 of 23 (permalink) Old 03-14-2009, 07:09 PM
tweeter270's Avatar
Just installed the tc lock up switch. thought i had it installed right the first time but wouldnt do anything when i pushed the button,, so i put two 10 ohm resisters in and still nothing,, so i checked the wire i taped ,, i thought it was the right one but i guess i looked at the plug wrong.. so i read some more on this outstanding site and tapped the yellow with blue stripeand it works... just havnt got to go try it out yet... thank you guys very much for all the info
post #8 of 23 (permalink) Old 03-17-2009, 12:25 AM
noff's Avatar
i put a spring on the kickdown cable to pul some of the tension out of the cable and had a computer hooked up with it said i was getting more line pressure but it will change the way it shifts but holds lot better
2012 / CCSB / G56 / HID 6K / H&S Minimaxx /-CCV/ 4"TBE / Hell Bent 2'' / 35''toyo / 3.42s
04 / NV5600 / 5'' / TST /sold
96 / SB / 5spd / 0 plate / 3k / 37''MG sold
MegaCab / DTT / OPIE / TDC / EFI LIVE / Gauges / Raptor150 / HTTss62-71 / AFE/ Pusher / 5''ss / TGC8inLongArm / Fox / 38''MG SOLD
RED / 2005 / QCSB / G56 / TST / SmartyTNT /ETC... K.I.A.
noff is offline
post #9 of 23 (permalink) Old 03-19-2009, 02:45 PM
this post is just to BtT it .
A good friend of mine is going to need it. Thanks guys.
bellyup039 is offline
post #10 of 23 (permalink) Old 03-19-2009, 02:50 PM
Rescue Tower
Shainer's Avatar
Here is Nitrous340's write up guys. Someone else can toss it on bit torrent.
http://dl.getdropbox.com/u/42304/Mys...%20install.doc
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #11 of 23 (permalink) Old 08-28-2009, 01:40 PM
x42vice42x's Avatar
is these tc switches just for auto's
x42vice42x is offline
post #12 of 23 (permalink) Old 08-28-2009, 03:06 PM
DieselAutoPower.com
patracy's Avatar
Yup, unless you've got a TC in your manual somehow.
patracy is offline
AH1501 (09-16-2013)
