When the GB tranny got put in we had to take the sensor out and it wont fit in the new tranny b/c it has bigger servo's in it. Is there inything I can do besides putting it in the pan? Can I just cut the end of it off, or will that give me a messed up reading.
Thanks, PETE
__________________ 94 rcsb 2wd, Ported head, HD181/210, big shiny pushrods, valve springs, TRE 47rh, DPC converter, Cheetah shifter, caltrac's, AD150, stainless diesel manifold, Stainless diesel twins, CPP 7x.012" injectors, detroit locker, and..........
I wouldn't cut the end or install it in one of the service ports. Put it in the hot line. You will have to fabricate the line or have a new one made with the npt adapter in it. I don't tow so a 100% accurate reading was not needed so I put it in the pan. Plus my Mag-hytec pan was pre-tapped for it.
Cumnspwr
2001 2500 4x4 GB Full Billet Auto
HTT Prostreet 66/14, 7X.012's, Some headwork, FMS, Smarty.
How or better where have I too install the Tranny sensor ??? where woud i find some pictures of if ?
Dodge 2500 4x4 1998.5 Diesel
thanks cw
Year/Make/Model: 1998 DODGE RAM 2500
QUAD Body Style: 4 DOOR EXTENDED CAB PICKUP
Engine Type: 5.9L L6 DIR Manufactured In: UNITED STATES
check genos garage, they have a fitting that hold the sender and that fits tight against your hot line, giving you a more accurate reading than the pan.
__________________ '01 ETH/MONSTER VP.
billet wheels, and 33s
The easiest place is in the tranny pan, but the most accurate is in the hot line coming out of the transmission.
Cumnspwr
@all Thanx.
there is no hole in the pan ? right ? so i have to drill one ??
my i find this T- fittings
cu cw
Dude I could have used that like a month ago when I installed my tranny. Your supposed to keep me up to par with these products dude.
Ordered one cause I got lazy and just threw it in the pre-tapped hole in my mag-hytec pan. Didn't feel like running to All Hose for fittings and hasseling with it but I hate the slow response and no fluctuation of it being in the pan.
Thanks!:thumbsup
Cumnspwr
