1999 dodge no heat!! - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 11-22-2013, 02:45 PM Thread Starter
silverpearl99's Avatar
I have a 99 dodge cummins I know almost everyrhing about truck. Its blows only cold air and its 20 degrees here. Ive flushed heater core nothing im stumped and it needs to be fixed!! Anyone know or had this issue on 2nd gen before I cant gwt any heat what so ever its runs right at 200 degrees all day.
silverpearl99 is offline
post #2 of 6 (permalink) Old 11-22-2013, 03:54 PM
Change the heater core. Check the blend door first.
.02 Cummins HO / 6spd / 4x4 / LBQC / Edge JWA / BD /200* T-Stat / Homemade HIGHIDLE /
cummins6sp5.9 is offline
post #3 of 6 (permalink) Old 11-22-2013, 05:15 PM Thread Starter
Is there a way to check blend door without tearing into dash? Is it electrical or mechanical? I dont think its heater core I have a hot line and cool line usually when a cores out I thought both hoses would be engine temp "hot"?
post #4 of 6 (permalink) Old 11-22-2013, 08:19 PM
ChuckNTruck's Avatar
if one heater core hose is hot and one is cold you have a plugged heater core. i would try to back flush it first but you might end up having to change it. Both hoses should be hot.
2001 2500 HO 6speed 4wd 3.54s ext cab long bed, MBRP 4in, BHAF, Edge comp, ISSPRO Fuel Pyro Boost gauges, FASS 150, Valair Organic DD, RV275 injectors.....SOLD
2015 2500 CCSB Auto 4wd Laramie.
ChuckNTruck is offline
post #5 of 6 (permalink) Old 11-23-2013, 08:22 AM
Azelgin's Avatar
The blend door is electrical. Mine is screwed up, too. I only get all hot, or, all cold. Ir was stuck in the cold position for a long time. Ok, when you live in AZ during the summer. It finally freed up when I continually switched the control from hot to cold. I only get one extreme, or, the other, but it works. It reacts slow, but it still works. It still take a lot of back and forth to get it to respond. Who knows, you might get lucky, too.
The AC guy told me it is accessable from the passenger side. Not sure he knows what he's talking about and I haven't looked, since mine started working. By the way, its been this way for about four years.
2001 4x4 QCLB, H.O. 6spd, Edge Comp, Pyro/Boost/FP gauges, MBRP 4" SS Exhaust, AFE, Bilstien 5100s, 285/70/17 Michelin LTXs, 170k miles on original VP, JEGS $90 LP
Glad this site has an "Ignore" function
Azelgin is offline
post #6 of 6 (permalink) Old 11-23-2013, 08:37 AM
turbowine's Avatar
my blend door was messed up too somebody before me changed the heater core and something elses cause they took the box out and when they put it back together the a/c evap line was hitting the blend door causing no heat
94 12v (gone but never forgotten
01 24v reg cab 6spd, bhaf, edge ez (sold)
turbowine is offline
