steering box upgrade ??? - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 07-21-2013, 01:14 AM Thread Starter
KYcummins5.9's Avatar
recently replaced idler and pitman arm and noticed the amount of play in the steering box....
this is a 2wd and i havent found much info...
its got the typical wander while driving down the road
upgrade info appreciated!!!!!
2001 Dodge 2500 SLT quad cab 2wd,5.9 24v Cummins, 5speed NV4500,KY SD clutch,HX35,FASS platinum 150, EDGE EZ,BHAF w/ outerwear
,4" MBRP exhaust,RedHead steering gear,Isspro EV FP+boost+pyro gauges
KYcummins5.9 is offline
post #2 of 18 (permalink) Old 07-21-2013, 11:21 AM Thread Starter
bump...........
post #3 of 18 (permalink) Old 07-22-2013, 02:47 AM
KY - this topic has been beaten to death, is profusely bleeding, and was pronounced dead at the scene...
To fix steering play/wander there are a few different things you can try:
- upgraded borgeson steering gear box
- upgraded borgeson steering shaft
- steering brace
- steering column bushings
Could be you only need a brace, could be you need everything in your steering system. If your replacing your steering gear box, I recommend going ahead and replacing your high pressure lines as well.
2002 Ram 2500 - 4x4 NV5600 - 4" MBRP Turbo Back - 1/2" Fuel system w/ Draw Straw - FASS DDRP w/ Big - Borgeson Steering with DOR Brace and Trackbar
smokin_dodge is offline
The Following User Says Thank You to smokin_dodge For This Useful Post:
KYcummins5.9 (07-22-2013)
post #4 of 18 (permalink) Old 07-22-2013, 10:17 AM Thread Starter
- steering brace
prob so but aint this a forum? All the threads ive seen lately are mainly 4wd steering questions. Guess i will jus go with the borgesson steering box...thanks
post #5 of 18 (permalink) Old 07-22-2013, 10:31 AM
Yes - this is a forum and is a place to openly share information.
However, I personally become very aggrevated when I see the same topic being discussed over and over and over - especially ones that have been covered so many times that nobody wants to reply to the post. Search is your best friend on a forum - the information is out there already, it just takes time to find it.
While you under your truck, check your steering shaft as well for play. The factory u-joints will wear out over time.
cumminsdog (07-22-2013)
post #6 of 18 (permalink) Old 07-22-2013, 11:35 AM Thread Starter
thanks....
post #7 of 18 (permalink) Old 07-22-2013, 05:01 PM
I had great results replacing all loose parts, including the bushing end of the track bar plus a complete by the book (FSM) adjustment (both of them) of the steering box. I also run as much positive caster as I could get and stiff sidewall E rated tires. Drives very well now.
RR
'01 QC 2500 long bed, 3:54 auto w/Dunrite VB & LU switch, untapped Comp, Scan gauge II, Raptor lift pump, fuel pressure gauge and trans temp gauge.
Russ Roth is online now
post #8 of 18 (permalink) Old 07-22-2013, 06:48 PM
i think the op's main concern is that his truck is 2WD and 99% of the topics relate to the 4WD steering. things that work on 4wd dont on a 2wd. for example the 98-99hd or the latest 09-up steering upgrade that everyone does will not work on the 2wd. I myself have a 2wd and have only done the steering box brace and didnt really see an improvement. im sure the steering box needs replaced, just dont drive the truck much anymore so its not a big deal. to the op. i would start by making sure the ball joints, tie rod ends and what not are tight with no slop. then look into the red head steering box as it seems that it is better than the borgeson. also as russ stated a good tire makes a world of a difference too. good luck and keep us posted so we can get some solid 2WD info going!
2000 2WD 2500 6spd 300k- Upgraded
2014 Laramie Longhorn CCLB SRW 3500 w/Aisin- RaceMe Ultra, Fully Deleted w FloPro. 90hp tune
onefastvw is offline
The Following User Says Thank You to onefastvw For This Useful Post:
post #9 of 18 (permalink) Old 07-22-2013, 10:14 PM
The truck won't steer until all of the worn parts are replaced. Determining which parts requires actually looking at the truck. Alternatively, figure all that haven't been replaced are either gone or ready to go. Mine failed in succession and almost all are new.
I have the 2010 setup on the living room floor waiting for me to finish the WhileImAtIt on the 84 300SD. Engine not shutting off turned into vac pods, vac pump, motor mounts, motor shocks, turbo drain grommet, oil change, air cleaner bracket, coolant flush & valve adjust. Must have missed something because $700 went for parts.
2000 LWB, Quad Cab, 4x4, NV4500, AirDog, Gauges, Thuren Track Bar, Lost crappy AGR and A1-Cardone steering boxes. RedHead is the best so far but truck has stopped returning to center. Hopefully, I'll get to it soon.
Junkman is offline
post #10 of 18 (permalink) Old 07-22-2013, 11:26 PM Thread Starter
thank you sir!!!!! best reply ive gotten so far, glad ya understand...
As far as slop, its my steering box. ball joints and tie rod ends are tight
i tried to hold my steering shaft while a buddy turned the wheel and it appears to be tight...
i will check into the redhead box...THANKS
post #11 of 18 (permalink) Old 07-23-2013, 02:21 AM
FtDavisDodge's Avatar
Go with a Redhead it's better than having to buy not only the steering box but the whole shaft as well. Also if you think it's in your steering box, try conferming it by tighting up your jam nut on the box and then test it out. If you havn't done it yet, it might tighten it up for now and that will get you by until your ready to spend the big bucks on the much desired much upgraded redhead steering box. Or it will absolutly do nothing for it and now it's very obvious that it's your steering box that went out. Be sure that if you do tighten it up and now your steering feels a little "too" tight as in now your starting to flex the muscles to turn the steering wheel, back it back off. Had a body try and tighten his steering thinking it was the box. He tightened it too much and drove it like that for a while. So now not only does he have to replace the steering box but the bushings as well and a few other parts. The other parts were out and he just "assumed" it was the box and tightened it all the way.
Good luck with it!
'02 2500, QCLB, Auto DTT DIY HD kit, 4X4, 235,000, Silencer MIA, CC breather relocated, ISSPRO EGT/FP/Boost/Trany Temp, BHAF/SHIELD, Raptor 150 BIGLINE, Power Puck, 2"+ Front Springs, Bilstien, Three Disk TC, DT Track Bar, CD Steering Stabilizer, 2012 Steering HD!
FtDavisDodge is offline
The Following User Says Thank You to FtDavisDodge For This Useful Post:
KYcummins5.9 (07-23-2013)
post #12 of 18 (permalink) Old 07-23-2013, 03:57 AM
I am fully aware of that. The same type of diagnosis is required, meaning checking for all loose parts and replacing them. I am only guessing the steering box is the same but even if it is not the adjustment I believe to be a real factor in most cases. BOTH adjustments need to be checked in the proper order per the FSM. Both were out on mine and by a considerable amount especially the one on the upper end of the box which is not the one everyone talks about adjusting.
RR
The Following User Says Thank You to Russ Roth For This Useful Post:
