2WD front suspension overhaul - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 05-29-2013, 08:48 PM Thread Starter
Enough with the periodic repair of failed suspension components...I'm going to do a complete overhaul of my truck's front suspension. If it moves, I'm replacing it! This may sound a bit extreme, but I drive 50K+ per year and time is $$. My question revolves around the upper and lower control arms. Since the replacement units come with bushings and ball joints installed, which mfg. produces the quality parts these days? I've been looking at RockAuto for ideas, but I'm not up to speed who builds the good stuff. Any suggestions?
1999 Dodge Ram 2500, QC/SB, 2WD, RV275s, Edge w Attitude, AFE Stage 2, AirDog 150, big line kit, BioDiesel, Suncoast TC and VB, Mark Wilson HD trans, Bilstein Shocks, B&W turnover hitch, Firestone airbags, RDS toolbox/60 gallon tank combo
gator_grabber is offline
post #2 of 9 (permalink) Old 05-29-2013, 09:10 PM
I have heard a lot of good things about Moog parts. That is the brand that everybody uses when replacing the ball joints and they are supposed to hold up better than the stock ones.
2001 Dodge Ram 2500 2WD Auto 5.9L Cummins: Raptor 150 w/ full 1/2" line kit, DTT Sump, Hypertech 3 Stage programmer, BD Boost Fooler, blocked wastegate, BHAF, 5" RSD exhaust, ISSPRO EGT, boost and fuel pressure gauges.
2001 Hypertech Cummins is offline
post #3 of 9 (permalink) Old 05-29-2013, 09:13 PM
CGCampbell07's Avatar
I have moog, i pretty much did a over haul as well but forgot to do the coils. trust me replace coils
2015 Ram 2500 Auto 4x4 CCLB
2000 Dodge ram 2500 5spd, Airdog 150, 2wd with 353300 miles, 90hp injectors, and triple gauge pillar pod
CGCampbell07 is offline
post #4 of 9 (permalink) Old 05-29-2013, 10:52 PM Thread Starter
That's good to hear. I've used Moog on the past on race vehicles, so it's refreshing to hear that they still make good parts. Coils are on the list; did you go stock or add some spring rate to them?
BTW, does anyone know what the Moog 'R' series is??
post #5 of 9 (permalink) Old 05-29-2013, 11:10 PM Thread Starter
Hmmm, not finding upper control arm assemblies on Moog's own site. Did you use another mfg. for these?
post #6 of 9 (permalink) Old 05-30-2013, 08:40 AM
I bought everything from rockauto, and used a coupon from retailmenot.com
I never replaced my coils that was the only thing i didnt do , going to buy some and replaced them soon. When you do let me know what kind you got if stock or stronger.
post #7 of 9 (permalink) Old 05-30-2013, 09:59 PM Thread Starter
You don't happen to recall the Moog part # for the upper control arms? All I'm seeing are units from other mfgs.
post #8 of 9 (permalink) Old 05-31-2013, 12:49 AM
MikeRodrig27's Avatar
Make sure you look into Moog. I've read a couple negative reviews on here recently. If you're looking for overkill, check out carli:
Dodge Ram Suspension, Dodge Suspension and Ford Super Duty Suspension Systems - Carli Suspension, Inc
1998.5 24v Auto 2wd, 5" straight, FASS 125, 180 p-pump, .084 lines, 4k GSK, Mack Rack, ISSpro gauges
MikeRodrig27 is offline
post #9 of 9 (permalink) Old 05-31-2013, 07:30 AM Thread Starter
I've also seen a few negatives, still the trend seems positive. I checked out Cali but only see 4WD parts.
