A couple of weeks ago some bozo rear ended my truck and took out the wiring pigtail for the trailer hook-up. Instead of getting a factory replacement (The connector for the 7 pin hook up was smashed) I'm going to cut and splice with an aftermarket, but I've got an extra wire and trying to figure out what it is.
Are there two black grounds? Here's what I've traced so far, and correct me if I'm wrong. And if anyone knows where I can find a schematic online it'd be appreciated.
Purple/Black = Reverse Light
Orange/Black = Parkin/Tail Lights
Green/Purple = Left Turn Signal
Red/Black = Right Turn Signal
Bluish Green = Brake Light/Brake Switch
Red = Hot/Auxillary
2 Black = Ground?
'99 2500 SLT 4x4 QC SB, 5 spd, Valair 13"6spd Flywheel w/Kevlar Face, Stage II Monster VP44, Hurricane II Injectors, .093" lines, ED 66/74/13 Turbo, Fuel Boss LP w/big line kit & straw, BHAF, 5" exhaust, Skyjacker 2" level kit 285/75R15's...
my 01 had 2 black wires which were both grounds according to my service manual.
I had to replace mine recently because the housing was cracked and it finally fell apart. I had a brand new ford plug and harness collecting dust so i just spliced it in; works great. I just hope the ford part doesn't make my truck run badly or start eating parts
on my 07 the diagram showed 2 black ground wires so i assume it may be the same
07.5 Black 6.7 Cummins ..... 4 Door 4x4 BADP Gen 1 5" TBE, EGR/Cooler delete, B&W gooseneck, Prodigy P3 .. custom made shift knob and much more to come hopefully
I just did and had the same problem. It was a plug from car quest.
The extra black is a ground. If you have a ohm meter you can verify this pretty quickly.
Hope this helps.
2001 3500 DRW, Quadcab,NV-4500 with Torque King main shaft and 1 3/8 input shaft(after broken mainshaft and 5th gear failure), Edge juice with Attitude,4in exhaust,100hp Injectors.
The two black 14 gauge wires are both grounds. If you trace them back, they both go to the same 12 gauge chassis ground. Here's a chart (trailer tow relay output means running/taillights) :
2000 3500 4x4, auto 4.10,BHAF, 4" MBRP, Power Puck, Converted to SRW, Dual Walbro 392's w/2 mic Cat filter, DiPricol FP, PSC DSS, billet trans
The Following 3 Users Say Thank You to edcasey For This Useful Post:
would anyone have a wiring diagram with the colors of the wires before the plug in. i have no trailer lights. i bought the truck as a repo and someone cut the wires off up by the frame before the plug. i have either 13 or 14 wires and not sure where they all go. its a 2001 2500 4x4 automatic
