external voltage regulator install help - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 12-23-2012, 06:57 PM Thread Starter
I'm going to install an external voltage regulator and will be using Mopar1973Man's voltage regulator mod instructions from his website. In the instructions it states to get an ignition source from the output of the ASD relay. Where is the ASD relay located and how do I connect to the output?
1999 Ram CTD 2500 QC SB Laramie SLT 4X4 / Dipricol Gauges / RV275 Injectors / Edge Comp / Raptor 150
Vulcan Draw Straw I / Goerend Triple Disc / Hog Performance 4" Exhaust
Marky Mark is offline
post #2 of 17 (permalink) Old 12-23-2012, 07:14 PM
irish power mad's Avatar
The asd relay is in the pdc under the hood. Thats the fuse box if you like behind the drivers side battery. I don't know about connecting to it. I presume Mike means finding a live power source from the asd when the key is on and it goes dead with the key off.
Am I the only one who knows everything?
01 3500 Dually Q.CAB, Quad Adr.,pulse, 4" straight stainless exhaust, air dog FP 150 fuel preporator,
half inch draw straw and fuel lines.Rancho 5000 shocks rear, 9 way adjustable up front, 3.55 rear end.DIY built DTT trans, triple disc low stall Goerand tc,billet flex plate and input shaft, DTT shift kit, Holset HX40W 60/65/16 turbo(stock turbo propping the door open
)125hp DAP injectors pushing on the pistons, BHAF and more to come
irish power mad is offline
post #3 of 17 (permalink) Old 12-23-2012, 07:41 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Ok...
Just hook the blue wire of the regulator back to the blue wire of the alternator currently. Then the green wire on the alternator you remove and hook up the new green wire from the external regulator to the alternator. But make sure to ground the new regulator or damage to the regulator will occur.
Mopar1973Man is offline
post #4 of 17 (permalink) Old 12-28-2012, 05:16 PM Thread Starter
Mike, where does the +12V keyed wire get hooked up? Your instructions say the ASD relay. Also, what gauge wire should I use?
Thanks for your help.
post #5 of 17 (permalink) Old 12-28-2012, 06:06 PM
Mopar1973Man.Com
Blue wire of the alternator should work too. 16-18 AWG is fine.
As long as the blue wire is hooked to 12V key on it should work. Green wire should only be hooked to the alternator nothing else.
I guess I need to update that article... (updated!)
Mopar1973Man's Dodge Cummins Articles - Voltage Regulator Mod
Stock wiring...
post #6 of 17 (permalink) Old 12-28-2012, 10:03 PM Thread Starter
Thanks Mike. I'm going to tackle this tomorrow now that the weather is going to finally cooperate.
post #7 of 17 (permalink) Old 12-29-2012, 05:50 PM Thread Starter
Mike, I hooked everything up like the instructions but I'm having problems.
Turned the key on to wait for the "wait to start" light to go out. Volt gauge only went up to about 9. Light went out and started up. Volts went to about 12 and when the grids came on, it went down to about 10 and then back to about 12 when grids kicked off. Took it for a short drive and the volt would not go over 12. When I got back home, I popped the hood and the alternator was very hot and I could smell it.
Maybe I don't have everything hooked up right?
I cut the 2 blue and green wires of the stock harness that plugs into the alternator and then spliced in the wires from the regulator to the harness so it would make an easy plug in. That left just the cut blue and green wires from the stock alternator harness. I spliced into the blue wire that goes between the regulator and alternator and hooked it up to the blue wire I had cut from the stock alternator harness to get the keyed 12V power.
Am I doing something wrong?
post #8 of 17 (permalink) Old 12-29-2012, 06:57 PM Thread Starter
Picture of voltage regulator mounted to firewall.
Picture of connections at alternator. Also shows ground wire to alternator from voltage regulator (black wire with red insulation)
Picture of where I tapped blue wire between voltage regulator and alternator to go to blue wire of stock alternator blue wire for keyed 12V.
post #9 of 17 (permalink) Old 12-30-2012, 09:53 AM Thread Starter
Anybody know what I have hooked up wrong? I need to get this fixed this morning or I'm going to have to put it back the way it was before and deal with the irratic voltage and pulsing gauge/dash lights.
post #10 of 17 (permalink) Old 12-30-2012, 06:35 PM
Banned
Why would one need to put in an external voltage regulator?
Isn't the PCM supposed to do this?
Pele is offline
post #11 of 17 (permalink) Old 12-30-2012, 07:18 PM
Mopar1973Man.Com
This is a poor mans way of getting you alternator back without paying a arm and leg for a PCM replacement because the internal regulator has failed.
post #12 of 17 (permalink) Old 12-30-2012, 07:29 PM
Banned
Gotcha...
Once this is added, will it keep the alternator running while the grid heaters cycle, or will that function still remain?
I have a feeling that if the alternator was still supplying power when the grids kicked in it'd shorten the life of the alternator.
Pele is offline
