Radio help please - Page 2 - Dodge Cummins Diesel Forum
Old 12-09-2012, 11:46 PM   #13 (permalink)
mfulton2389's Avatar
My vote is for a bad ground...Mine was doing the same thing, intermittently losing power but coming back on to the same cd track or radio station... BAD GROUND
Sent from my SCH-M828C using AutoGuide.Com Free App
01 3500 drw qc 5spd 4x4, 5" straight, Raptor 150, afe stage 1, Isspro fuel, pyro, boost. TST Comp/Smarty w/Revo, DAP 7X10'S, Super B, Valair DD. "Don't call what you're wearing an outfit, don't ever say your car is broke" DBT
mfulton2389 is online now   Reply With Quote
Old 12-10-2012, 02:00 AM   #14 (permalink)
khoss's Avatar
Another questions guys. Black and blue wire that is connected to back of stock stereo what djd you all do with that wire? The one that is kinda seperate from stock harness, Thats not a ground is it? Cuz I have one ground on harness
2000 2500 QCSB, 260,000 auto, bhaf, fass ddrp, power puck, silencer ring gone. In the building process other toys: 2008 polaris dragon 800 155, 1998 Lexus gs 400
khoss is offline   Reply With Quote
Old 12-10-2012, 02:08 AM   #15 (permalink)
PA VICE PRESIDENT
Ramitt's Avatar
its prob the remote turn on wire. Usually all blue or blue with black trace
2002 2500 SLT 4x4 6 Speed 4.10's. SB Dual Disk ,Fass 150,Edge Juice w/attitude,AFE intake,5in str8 piped exhaust,20% window tint,Leveled with 33's,Halo head lights w/55watt hid's, 35watt hid fog lights,Rhino liner,High idle mod.
Ramitt is offline   Reply With Quote
Old 12-10-2012, 02:15 AM   #16 (permalink)
khoss's Avatar
Thanks rammit, any idea what I should do with it? Cap it off?
Old 12-10-2012, 02:45 AM   #17 (permalink)
PA VICE PRESIDENT
Ramitt's Avatar
Should of been labeled on the harness. You can just tape it off all it does is turn on a factory or aftermarket amp when the head unit is turned on.
The Following User Says Thank You to Ramitt For This Useful Post:
khoss (12-10-2012)
Old 12-10-2012, 09:37 AM   #18 (permalink)
Always solder! Butt Splices should only be used in the field with dialectric grease for a temporary fix when soldering is not possible.
I always splice per NASA standards - never have a broken connection ever again!
MAKE | How-To: Splice Wire to NASA Standards
2002 Ram 2500 - 4x4 NV5600 - 4" MBRP Turbo Back w/ AFE Resonator and Hushpower Muffler - 1/2" Fuel system w/ Draw Straw - FASS DDRP 100 w/ Big Spring
smokin_dodge is offline   Reply With Quote
The Following User Says Thank You to smokin_dodge For This Useful Post:
khoss (12-10-2012)
Old 12-10-2012, 12:14 PM   #19 (permalink)
Pele's Avatar
Good ol' Western Union Splice.
If you do the splice right, it's stronger than the wire itself.
It's from back in the Telegraph days, hence the name "Lineman's Splice" or "Western Union Splice" it's for wires that have weight load on them, hanging on a pole.
2001 Ram 2500 QCLB 4x4 Auto. 3.54 R&P, Camper/Trailer package.
All of my vehicles are fueled by clean burning hydrocarbons. They are produced naturally by decomposition of organic matter.
Pele is offline   Reply With Quote
Old 12-11-2012, 09:00 PM   #20 (permalink)
khoss's Avatar
Ok guys, i am about to go mad. So my stereo is still doing it, its losing power for a second then coming right back on to same track or station and same volume. Replaced head unit, and second wiring harness where everything is soldered this time. my question is this i have got my ground from the stereo that i am soldering into the aftermarket harness which in turn is to stock stereo harness. should i take the ground from stereo and ground it out or leave it hooked on to the ground through harness? the only wires that i have left that are not soldered are an orange wire, blue and white wire from harness, and a blue/black wire that was hooked seperately onto the back of stock harness. any help please guys.
Old 12-13-2012, 12:45 AM   #21 (permalink)
khoss's Avatar
Anybody got an idea where i should start?
Old 12-13-2012, 01:01 AM   #22 (permalink)
Pele's Avatar
Troubleshoot the factory wiring.
The easiest way to do this is to put the stock stereo back in. Does it still have the same problem?
Orange from the stereo harness is for lighting. Not necessary, cap it off.
Blue from the stereo harness is for power antenna or amplifier cut on. Not necessary, cap it off.
Old 12-13-2012, 01:32 AM   #23 (permalink)
khoss's Avatar
Stock stereo works perfectly. Ok and what do you know about the black and blue wire that was connected to back of stock stereo? Also should I take ground from stereo harness and physically ground it or leave it soldered to ground on aftetmarket harness?
Old 12-13-2012, 03:40 AM   #24 (permalink)
Pele's Avatar
The single wire that was physically connected to the metal of the stock stereo is your Ground wire.
Connect the Black wire of your new stereo harness to that wire that used to be connected to the metal on the back of your stock stereo.
Theoretically, your stereo shouldn't work without this connected, however you may be getting a stray ground from the antenna coax. (The antenna connector has a shell and a pin. The pin is for the antenna, the shell is ground.)
In fact, try this:
Before you do ANYTHING, go out to your truck and pull the stereo out of the dash.
Remove the antenna plug and put it away so that it can't touch the stereo.
Try and work the stereo.
The Following User Says Thank You to Pele For This Useful Post:
khoss (12-13-2012)
