ac/heater blower works some times and sometimes doesnt? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-17-2012, 03:30 AM Thread Starter
BuiltByWrenchesNotChopStX
redlining01's Avatar
Just like the title says most of the time my blower doesn't work but when it does its blows properly on all setting from low to high where should I start looking at connection and or wires?
redlining01 is offline
post #2 of 5 (permalink) Old 09-17-2012, 07:13 AM
NightMare99's Avatar
you sure its actually not working? or is it going to defrost vents and you just cant feel it? if this is the case check your vacum pump for leaks and check your vac lines.
99 Sport. BHAF. 4"TB into 7"ss Mitres. BD Sponge. BD Boost Builder. Custom Wastegate Elbow. FASS HD Titanium. ARP Studs. FireRings. ReWorked Head. C.D 100 Stix. ATS Intake. Smoked Lights Allround. Projector Angels. Leveling Kit.
NightMare99 is offline
post #3 of 5 (permalink) Old 09-17-2012, 09:22 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
Either a vacuum leak because of position problems or blower motor resistor because of speed issues.
Mopar1973Man is offline
post #4 of 5 (permalink) Old 09-17-2012, 02:48 PM Thread Starter
When it does work all the position work and the controls to go from defrost to foot and both upper and power from low to high also work fine so i guess i should should look at the resistor for the blower itself...?
While doing 80 MPH in traffic!
99VP(still), More Fuel, More Than enough Air, Billet Parts and That White Mist on a Button on the Steering Wheel
post #5 of 5 (permalink) Old 01-19-2013, 08:29 AM
Bush_242
mk38tech's Avatar
had the same problem, untill yesterday. when i sat in the truck and turned the key on to wait for my fuel prime my fan was blowing on the lowest setting, then when i cranked up the thing just stopped. now i cant get it to work at all so im going to replace the relay and resistor just because they are old, maybe the motor too but that thing was blowing strong as hell last time i took it out about a year ago. just moved to va from florida though, everything seems to be different with my truck up here in the cold. i got some of that sweet bright red spectre vacuum line i think it is, from summit. at like neg 10 deg its still flexible as all get out, so im still working getting all my lines replaced with this stuff. will update later
99 2500 QCSB 3.54 Suncoast 47re,adrenaline,airdog(old version), isspro, flexalite,coolant filter,sump,ARBs/300M RCVs/EMS 35spl hub conversion,285/18 dune grapplers.
05 Jeep KJ 2.8 CRD. GDE tunes, EGR delete, Glowshift, rustys lift, coolant filter, flexalite.
mk38tech is offline
