Truck Will Not Start. Need advice on troubleshooting - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 06-08-2012, 08:18 PM Thread Starter
1999 dodge 2500 24v cummins turbo diesel
truck started taking longer to turnover the last few days when i would start
finally it would not turn over at all
no clicks, nothing. no sounds CHECK ENGINE light is on.
took batteries off and tested...they are fine.
Now I dont know what to do. Advice is much appreciated.
sharp_brandon is offline
post #2 of 11 (permalink) Old 06-08-2012, 08:51 PM
WillM's Avatar
iTrader Score: 10 reviews
Pull the codes.
What's your fuel pressure?
Let us know a little more about your truck, like mods and what not.
Ranch Truck: '98.5 QCDRW, NV4500, 2WD, BHAF, Straight Pipe, FASS, Gauges, Steering Box Stabilizer, Ranch Hands
My Truck: '91.5 RCLB, NV4500, 2WD, Leveled, BHAF, 4" Straight, Isspro Fuel Pressure/Boost/Pyro/Tach/Oil, HX35, 24V Intake Horn, PS I/C, 3" Intake Plumbing, THD Competition 6x.013", VE Tuned, Hot Screw, Piston Pump, KSB Spacer, THD Pin, 366 Spring, Valair, A1 Studs & 60# Springs 282HP/692TQ
(w/ stock injectors)
WillM is offline
The Following User Says Thank You to WillM For This Useful Post:
sharp_brandon (06-08-2012)
post #3 of 11 (permalink) Old 06-08-2012, 08:55 PM
CGCampbell07's Avatar
sounds like starter
2015 Ram 2500 Auto 4x4 CCLB
2000 Dodge ram 2500 5spd, Airdog 150, 2wd with 353300 miles, 90hp injectors, and triple gauge pillar pod
CGCampbell07 is offline
The Following User Says Thank You to CGCampbell07 For This Useful Post:
post #4 of 11 (permalink) Old 06-08-2012, 09:12 PM Thread Starter
I dont know fuel pressure. I dont have a diagnostic scanner. Everyhting on the truck is original
No mods, automatic 2x4
2nd transmission in 2004
replaced crank case sensor last year
Not sure if it is related BUT I put new batteries in the truck in OCT 11. PRIOR to doing this I would get a surge on my RPM when I was running about 45-50 mph and staying around this speed. It would always shift through if I accelerated. AFTER putting the new batteries in I noticed that the truck did not have the surge. When my truck started taking longer to turnover here recently, The surge started back up again at 45-50mph. I literally was driving my truck and pulled into my home and 2 hours later I tried to start it and it clicked a few times then the second time nothing. I did try jumping it off.I hope that makes sense. Seems like power is being drawn from the batteries but I pulled them and had them professionally tested. They are good.
post #5 of 11 (permalink) Old 06-08-2012, 09:14 PM Thread Starter
PS The truck has 175000 miles (original)
lift pump has never been replaced
fuel pump never replaced
terminals cleaned
Could it be a fuse?
post #6 of 11 (permalink) Old 06-08-2012, 10:10 PM
ol work truck's Avatar
could be fuse check your starter conections and maybe have it tested
1999 3500 24v 5 speed manual, valair dual disk, 4x4, raptor 150, big line kit, triple ISSpro guages, quadzilla adr. stacked with smarty, BHAF, 7" Smeding diesel cat stacks
phatshaft 62/14, 100 sticks thanks to smeding and dap
ol work truck is offline
The Following User Says Thank You to ol work truck For This Useful Post:
sharp_brandon (06-09-2012)
post #7 of 11 (permalink) Old 06-09-2012, 08:15 PM
Wy Elk Hunter's Avatar
I don't think you can pull the codes on a 99. But if you can, you do it by turning the key to the on position three times leaving it in the on position. Then look at your odometer.
Lets start with starter. Have someone turn the key to the start position while you put a volt meter across the heavy cable on the starter and the truck frame. Also check the voltage from the cable on the starter solenoid to the truck frame.
If you have 0 volts you know it's not the starter.
Of course have the truck in park and the brake on while you do this.
2001 4x4 lifted, 285/75R 16, 4" SS Diamondeye exhaust, 5spd stick, 13" Valair,
Edge EZ, Raptor 100, bhaf, Boost/Pryo/FuelPSI gauges, 5th wheel, and spray on bed liner.
Wy Elk Hunter is offline
The Following User Says Thank You to Wy Elk Hunter For This Useful Post:
sharp_brandon (06-10-2012)
post #8 of 11 (permalink) Old 06-09-2012, 10:31 PM
WillM's Avatar
Yes you can. I think you can pull the codes on a '97, for sure a '98 - present. And the key trick only works on an '01 and '02. So an OBDII scanner is needed for a '97, '98, '99, and to get all the codes from an '01 and '02, because the key trick doesn't show every code.
WillM is offline
The Following 2 Users Say Thank You to WillM For This Useful Post:
sharp_brandon (06-10-2012), Wy Elk Hunter (06-10-2012)
post #9 of 11 (permalink) Old 06-09-2012, 11:35 PM
runit02's Avatar
IIRC there is a fuse and relay in the box underhood. Turn on your headlights and try to start, if they dim, it's drawing juice. I had a terminal fail on my 99 at 140k. Connection looked good.
Official CF repair crew
[QUOTE=JearBear;19022602] I have always and will always love men, cats, and single cabs.
runit02 is offline
The Following User Says Thank You to runit02 For This Useful Post:
post #10 of 11 (permalink) Old 06-10-2012, 01:34 PM
there should be a fuse for the starter, check to see if it popped. i came home one day and then went to go some where 30 min later and nothing, checked my fuses and the starter was burnt put in a new one and clicked and the fuse popped. took starter out and it was bad. the truck only had 150k of that most on it
sharp_brandon (06-12-2012)
post #11 of 11 (permalink) Old 06-10-2012, 09:24 PM
the key trick doesnt work on 99
